Question about SanDisk Sansa e200 MP3 Player
It seems i have over charged my sand disk player so right now when i switch it on it says battery too slow and then it shut down it self, please i need a help to this problem .
    Problem Solver:
  • 37 Answers
Hi teddyabout,
There are few reasons your SanDisk Player is acting up. Here are some things to try out.
Make sure the HOLD switch is turned off before you power up your player. This will sometimes cause errors in booting.
If that doesn't work you can try a soft-reset by holding the power button down for 15 seconds then try turning the player on normally again.
Finally, if you are brave enough, you can take the battery out of the player to force a complete reset of the player and battery. This is done by taking the four screws out of the back of the player and removing the battery. After 30 seconds, put the battery back (be sure the it is seated properly) and replace the screws.
Good luck
-SHG
Posted on Jan 14, 2009
3 Suggested Answers
SOURCE: problem with my battery
how to convert my photos to sansa e 260
Posted on Jan 15, 2009
  • 5 Answers
SOURCE: probem with my battery
If you over charged it, leave it shut down, unplugged. It will continue to drain some battery. A day or two should be fine.
Posted on Jan 16, 2009
N5010 battery issue
i can advise u few steps to make the battery life better
1. drain battery completely then charge it
2. run a battery self test (charge and discharge battery 3 times)
3. switch off wifi and bluetooth when not in use
4. scan pc weekly to check for virus
5. use power save option
6. shut down when not in use or atleast put to hibernate
Feb 13, 2012 | Nokia N Computers & Internet
After I power on the archos it powers down right away...I plug it in to charge and it does not say it is charging...I also can not get the power light to shut off... I have tried plugging it in to both car...
Hello :
Simply you need to replace your media player battery with new one . It seems that the battery life is ended . When battery life is ended , it can't be recharged anymore .
If that didn't help , then you need to check if the power charger is in good condition . If the power charger is in good condition , then the problem will be with the charging jack . For charging jack problem , you need to take your media player to a repair shop .
good luck .
rate please !
Mar 19, 2010 | Archos 504 500870 Digital Media Player
HP 530 Notebook will shut off by its self and when you restart it and will show you that windows was not shut down properly. Could it need a new battery?
The problem lies with the power supply system either in the power adopter or inside the laptop. When AC power is plugged in, the system shows that the battery is being charged (Yellow Light Indicator switches ON) but practically niether the battery is usually being charged nor the computer is being run by the AC power. Its a little bit of energy left in the battery that keeps running you computer for some time and as soon as the battery is discharged the note book shuts down by itself.
However, the Taskbar battery indicator gives the correct picture of battery charge and the charging process. Better rely on that.
Its a hardware problem pertaining to power supply and charging system and doesn't have to do any thing with Mother board, RAM, Hard disks or other hardware installed in the PC.
Do tell the above details to a repair workshop man to rectify the problem.... Best of Luch
Aug 18, 2009 | HP 530 Notebook
Turns off right away
You probably didn't get all the sand out and now it's preventing the lens from opening correctly prompting the camera to shut down.
Aug 16, 2009 | Polaroid T831 Digital Camera
Problem with my battery
Jan 14, 2009 | SanDisk Sansa e260 MP3 Player
Probem with my battery
Won't start--No Sandisk display.
my sand disk shows the sand disk display and turn offs.please give me a solution.
Dec 30, 2008 | SanDisk Sansa MP3 Player
Iriver pmp 120 use the wrong charger
try this. the iriver doesn't boot at times ( wrong charger or using the right charger abroad), unlatch the battery and hold down the power button for about 20 seconds. also reset the instrument. hopefully that might work for you.
Dec 30, 2007 | iRiver PMP-120 Digital Media Player
SanDisk Sansa e200 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
