Question about GE (PSS26MSRSS) Side by Side Refrigerator
REFRIGERATOR IS GOING FROM COLD TO WARM
I HAVE A GE PSS26NSTD AND THE REFRIGERATOR IT GOES FROM -0 ON THE FREEZER SIDE TO 20 AND ON THE BOX SIDE IT GOES FROM -37 TO 50 AND UNFREEZES MY FOOD, CAN YOU TELL ME WHAT IS WRONG? IT IS ONLY 2YRS OLD
  • yaay Feb 21, 2009
    I HAVE BEEN HAVING THE SAME PROBLEM FOR THE LAST ONE YEAR EVERY COUPLE OF MONTHS ON A 2 YEAR OLD REFRIGERATOR. THE TEMP ON BOTH SIDES GOES UP, A THIN LAYER OF FROST FORMS AND WATER DISPENSER WOULDNT WORK. I WILL DEFROST THE WHOLE FRIDGE AND TURN THE PLUG OFF. WAIT FOR 6-8 HOURS AND PLUG IT BACK AGAIN AND IT WILL START WORKING. LAST FEW DAYS THE TRICK IS NOT WORKING AND I AM LOST. i MIGHT BE FORCED TO CALL GE SERVICE. I WOULD NOT BUY THIS PRODUCT AGAIN.
  • 71 Answers
Look in the freezer on the back wall if you see frost (looks like a thin layer of snow) you have a defrost problem . the cooling coils Behind the back freezer wall get cloged with frost and block the air flow to the ref side. The problem moast times is The defrost heater.
Posted on Jan 14, 2009
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
I have a GE GSS25QGTABB side by side. Despite the digital thermometer being set at 0 degrees (freezer) & 37 (fridge), my freezer does not go below 11 degrees, and the fridge at 48 degrees. Compressor...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 26, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
The freezer doesnt work, i have a ge side by side serial number sr23vsta, the digital temperature should be 0 for the freezer but is 20. I tried changing the temperature but it still doesn't work.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Jan 15, 2011 | GE Refrigerators
My GE TFX30PP is constantly running and doesn't turn off. The freezer is very cold but the frig side isn't cold enough. A repair guy put in a new "cold contol" sensor but it didn't help.
This is a very common issue, If the freezer compartment is cold and making ice the
problem is simply airflow from the freezer into the refrigerated section.
Typically when one senses the refrigerator is warm they max out the settings
on both dials the thermostat with its 1-10 settings as well as off for the compressor.
This controls the compressor and temperature.
The additional setting or dial is for colder freezer or refrigerator as well , However
it simply opens or closes a flapper door between the freezer and refrigerator boxes.
When that dial or setting is maxed , it closes and makes the freezer colder, yet leaves the refrigerated section starved for sufficient airflow to maintain a cold box in the refrigerated section.
Just set the dial that does not turn the compressor off to the middle setting.
One can leave the thermostat that does control the compressor in the max setting , just not the colder freezer setting, If you notice colder isnt colder refrigerator, Its actually colder freezer, A common issue found on 25% of all refrigerator calls a simple setting adjustment.
Its easy to think that maxing out the settings makes for a colder refrigerator, it doesnt, it makes a colder freezer and warm rerigeration section.
If a freezer is making ice, theres nothing wrong with the unit other than airflow setting.
I would also clesan the condenser coils off.
Add a comment
Dec 24, 2010 | GE Profile Performance 29.8 cu. ft....
Refridgerator side is set to 34 but temp reads 52 last night freezer was at 20 when set to 0 cleaned coil of dust now reads 0 but fridge side still wont come down it is a GE side by side
your evaporator coil in the freezer behind the rear panel is iced up and cold air cant flow thru ice,defrost the evaporator coil,then check continuity of the heater element under the coil,if its good,then suspect the defrost control,usually located in the refrige side on the upper area
Jul 18, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE bottom freezer model PDS22MBRBWW gets too warm
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 12, 2010 | GE Profile PDS22SBRR Stainless Steel...
ZFSB26DRESS water runs warm and freezer not staying cold.
It sounds like the condenser coils , the coils by the compressor , need cleaned badly . This (and the compressor cooling fan) , can cause the compressor to cut off on overload (due to the heat) , thereby not circulation refrigerant thru out the freezer coils .
The water line goes from inside the freezer door ( cold ) , under the refrig ( warm ) , then to the inside refrig water reservoir ( cold ) . After that , you should get cold water , until the reservoir is drained of cold water .
Nov 19, 2009 | GE Monogram Side by Side Refrigerator
Ge fridge GSS25LFGww, fridge part freezing food
Hi, Change the controls back to normal settings. Make sure the freezer is getting 0 to 5 above. If the freezer is getting cold enough, try and turn the cold control to 1 and see if the refrigerator shuts off. It sounds like the cold control in not working properly and will need to be replaced. NOTE: The freezer temp has to be right temp or the fresh food side will not work proper.
I hope this helps. Please let me know if I can assist you further.
Vic
May 30, 2009 | GE GSS25JFM Side by Side Refrigerator
Water freezing at bottom of refrigerator/Temperature not right
thats a water tank holding water dfor the dispensor, if everything in refrig is freezing quite possible that the water in tank froze as well, which would explain no water,
Feb 24, 2008 | GE PSS26NSWSS Profile 25.5 Cu. Ft....
GE Arctica fridge PSS26LRBSS - temp control blinks '0'
set to 0 for freezer, and 37 for fridge. give it 24 hours to stablize. blinking could mean it is adjusting.
Sep 09, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
172 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
