Question about Yahoo Messenger
Internet connection.. using yahoo messenger messenger encounter connection problem. please check the network connection and then click "Try again". (81003004)
  • 3 more comments
  • rajk1980 Jan 26, 2009
    i am unable to connect my yahoo messenger as the messenger encounter connection problem. please check the network connection and then click "Try again". (81003004)
  • Anonymous Feb 06, 2009
    I got a new yahoo ID and Password and it still don't work
  • Anonymous Feb 16, 2009
    I am experincing the same issues on a Windows Vista with a Belkin router.
  • Anonymous Feb 27, 2009
    Whtat should i do shall i format my comp
  • cookie girl Feb 27, 2009
    Please do I remove dial up from yahoo messenger......I have broadband.
    Am having problems connecting to yahoo messenger chat rooms...after logging on i see...disconneted
  • 27 Answers
internet explorer might be offline... open iternet explorer and connect it to the internet... it worked for me
Posted on May 29, 2009
  • mic_lazo Jun 14, 2009
    Well you can open internet explorer and check if your internet explorer is working offline... connect your internet explorer to the internet...go to File, uncheck work offline... this worked for me....
When I Try To Sign In, It Says "Messenger Encountered A Connection Problem, Please Check The Network Connection And Then Click "Try Again", (81003004)
Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences."
2. Enable the "No network detection" option and then click the "OK" button at the bottom of the window.
3. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button.
4. Enter your Yahoo! ID and password and click the "Sign In" button.
you may have a registry problem download registry cleaner reginout to fix the issue
Dec 30, 2010 | Yahoo Messenger
Messenger encountered a connection problem. Please check the network connection and then click "Try Again". (81003004)
Check your firewall and anti virus settings, Some programs block yahoo messenger from connecting to the internet.
Sep 09, 2010 | Yahoo Messenger
Please check your internet connection setting if your network is enable and working properly. To solve this just click on your internet network or connection icon and click on repair, to repair it , if not you can get internet connection which means you can connect the internet.
Aug 09, 2010 | Yahoo Messenger
Messenger encounter a connection problem.please check the network connection and then click try again 8100 300 4
Please check that you are not having any Proxy in Connection setting ....if you use socks proxy please clear/delete the proxy from network connection>Lan Setting>Unselect Use Proxy Server.......etc. or check the Connection Preferences in the messenger window and select Connect directly to the internet and save....or if it's still the same please contact your network admin or ISP....hope that will help you...
Good Luck
Nov 21, 2009 | Yahoo Messenger
When logging in to yahoo messenger it always says network problem
to find out what network connection are YM can get in. Go to your preferences then check your network connection.
There is 3 connection in there:
  1. DIAL-UP
  2. LAN
If you have this type of connection, select it.
Then you can enter you yahoo back to normal. Good luck!
Jul 29, 2009 | Yahoo Messenger
When I try to sign into Yahoo Messenger 9.0 I get this error message "Messenger encountered a connection problem. Please check the network connection and then click try again. (81003004)" I've changed my...
You might have some options to fix it: firstly; this error occurs when your connection preferences are not properly set. I'm not talking about your Yahoo! ID and Password here, but you may need to adjust certain features depending on what network you're on. Maybe, i think you should check your firewall settings. If you use Personal Firewall, make sure it allows your connection to receiving incoming connections and allows you to use yahoo messenger,check it out, may be it blocked your yahoo messenger. if a firewall protects your network, it may block yahoo messenger when it tries to connect to the server. You need to change your connection settings, click the Messenger menu in yahoo messenger and select Connection Preferences. Select Firewall With No Proxies. Select your Internet Connection type from the pull-down menu at the bottom and enter your Home Country if the adoptions aren’t grayed out. Click OK and login again using the new settings. If this option doesn’t work, click Connection Preferences in Yahoo! Messenger again and select No Network Detection. Try to login again using the new settings. In some instances, you may need to provide yahoo messenger with the IP address of your firewall or proxy server (you can get this information from your network administrator or from your Internet service provider). Click Messenger and select Connection Preferences again. Select Use Proxies. Enable either the HTTP Proxy or the SOCKS Proxy as needed and provide the proper address. Click OK and login again using the new settings.
Or other way, open your Internet Explorer>Go to File>Then, 'uncheck Work Offline', make sure your Internet connection is not working offline. Then, close Internet Explorer, try to sign in your yahoo messenger.
thirdly, if you are using IM9 there are sign in problems. This is what yahoo has to say. Try an updated version of Yahoo! Messenger 9.0( This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code“81003004” when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, I recommend installing this latest version. Hope it was helpful and it works to solve your problems.. Please kindly support me.. Thank You!
Jun 10, 2009 | Yahoo Messenger
Login error 81003004 from Yahoo Messenger
Change your messenger connection settings. I had to check "Connect via a proxy server " in order to sing in.
Goto Connection  Prefrences and use a http proxy.
thank you
Jun 02, 2009 | Yahoo Messenger
Are you behind a firewall (like one in schools) or using proxy??
If so, see any options are available to change the connection settings in yahoo messenger before connecting.
I cant log into my yahoo messenger
May 03, 2009 | Yahoo YHT-630 System
Messenger problem
click the "messenger" menu and select "connection preferences" Select "Firewall with no proxies" click "Apply" you should see a message asking you to sign in again click "oK"
info found in yahoo help here is the link
Feb 26, 2009 | Yahoo Messenger
Yahoo Messenger Logo
233 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
