Question about Maytag Atlantis MDE7400AY Electric Dryer
Belt came off try to replace but to big
The dryer wasnt turning I opened up and saw the belt was off. Slid the belt back into place but have at least an inch of play.
Ordered a new belt which came and is the exact same size and when installed has the same problem. Can I get a diagram that shows the belt configuration.
  • 979 Answers
You may have a tension pulley on it which you will have to run the belt through to make it tight. This is primarily for making it easier to put on. Also check the motor bracket that turns the belt and see that it is still in place and not loose. This can happen over time with all the vibration that occurs. Let me know how this turns out.
Posted on Jan 21, 2009
How do i get to the belt
Posted on Apr 28, 2009
Tumbler not turning
Hello, W/D here.
When you turn the dryer on, listen for the sound of the motor running. If you an hear the motor, the belt is probably broken.
Disconnect the power, and open the back. If the belt is broken, it should be obvious. Get a replacement belt from your local appliance parts store. Place the belt on the drum (you should be able to see where the old belt was running on the drum). Place it on the motor pulley. Lift the tensioner pulley past the belt, and slowly bring it back to the belt, placing it in tension. Roll the drum several turns by hand to get everything in alignment, and close the back up.
Best regards, --W/D--
Apr 01, 2011 | Roper Dryers
My dryer stop working, it made a big noise and is not spining anymore, ts sounds as if it is out of place or something, and after 3 minutes it starts smelling like burn My dryer is a Maytag...
TRY SPINNING THE DRUM BY HAND. IF IT SPINS EASY, YOU HAVE A BELT BROKEN.
MOST LIKELY THE BANG WAS WHEN THE BELT BROKE. YOU NEED TO PULL THE DRYER OUT, OPEN IT UP AND REPLACE THE BELT. A SERVICE APPLIANCE REPAIR WILL NEED TO BE CALLED. - - SORRY
Feb 20, 2011 | Maytag Atlantis MDG7400AW Gas Dryer
My creda simplicity t622cw condenser dryer wont turn
Broken or belt has come off. If can open back and fix or replace. You may need to remove the top. Careful of the heat element, lift out drum and place new belt on motor holding it while you put the drum back keep hold of belt and place around drum replace top and should be ok. Hope this Helps
May 25, 2010 | Dryers
Dryer won't start.
Try turning the drum--if it turns easily, the drive belt may be broken.Open the top to check. Older GE's have a pair of spring clips near the front corners that must be depressed toward the back with a putty knife, while new ones have several screws in the back edge that must be removed and the top slid rearward.
Feb 01, 2010 | GE DBXR463EDWW Electric Dryer
Need instruction for replacing a drive belt on a electric dryer Model No. DE482 Serial # 07
Best to move the dryer to a big room (hopefully cardboard if carpet is not available) as you will need to move around and move IT around some. Once you've got a nice clearance to work in, place the dryer onto its FACE-to clarify, the side that has the door that you open to access clothing articles should be on the ground. You will need to remove the back panel. This is the only way that you can replace the belt as there is a belt tensioner you will need to access also. The belt is long but not very wide or thick. There will only be one way you can fit the belt in place, have it be nice and tight, without having any slack. You might need a friend to hold the belt in place around the large DRUM (the area clothes are placed for drying) while you are routing the belt into place. There are only 3 places that the belt needs to contact: The DRUM, the motor shaft (this is what causes the belt to turn the drum), and the belt tensioner. The drum (with a friend holding the belt in place) and the motor shaft should be a snap, it might take a couple of tries to figure out how to correctly route the belt through the tensioner. When you have routed the belt correctly, the belt will be snug, the tensioner should flex (a little), and should be in the same spot the old one was. There is NO WAY you can install it backwards. Before putting the back panel on, turn the drum by hand a little to make sure you haven't missed or forgotten anything. Not a big job, not time consuming, just be careful you don't take any shortcuts and it should turn out great!
If you need more help, I found parts breakdown prints here:
http://www.appliance-parts-warehouse.com/maytag-parts/model_view_cats.cfm?model=DE482
Hope this helps!
Nov 08, 2009 | Dryers
Frigidaire Dryer Drum Making Noise When Turning
that big spring in the back of the drum is your heating element.the part number is 131553900.not sure where to get it up there but marcone appliance parts in st louis missouri might be able to help you out ther phone number is 1-800-482-6022.good luck with your dryer i hope this helps
Sep 07, 2009 | Frigidaire Dryers
I need to put the belt of my dryer ithe correct place
take out all the screws on the out side of back panel pull the drum back place belt over the front of drum and slide on release spring place belt behind pulley and replace spring
Jan 31, 2009 | Kenmore 64732 Electric Dryer
Dryer will not move but power good
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Oct 05, 2008 | Samsung 7.3 Cu. Ft. Super Capacity...
Replace belt
A belt replacement problem solution has been posted above. However, to install a new belt the top and back of the machine will have to be removed so that the belt can be slipped off the back of the drum.
Before replacing the belt, I recommend checking the tensioner pulley that is located at the back of the dryer motor. The tensioner pulley is a plastic pulley with a spring attached. Your belt may have come off the tensioner pulley which would mean that it is too loose to drive the drum.
Hope this helps
Jun 05, 2008 | Asko T700 Electric Commercial Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
141 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
