Question about Kenmore Oasis HE 27082 Top Load Washer
Water not going into machine
The panel lights up but no water comes into the machine. In October 2008 Sears came out and said I had to call a plumber Did that everything is alright with the plumbing. Then Sears changed the water pump. Now 3 months later the same problem. Sears came out 01/13/2008 now the repair man says it is my door lock have to wait another 3 or 4 days for the part. These repair guys dont carry any aparts with them. Called Sears and they are telling me that the same part must be changed 4 times before the replace the machine. I will never buy any thing else from SEARS.
  • 15,935 Answers
The repair guys are right.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Hi My toilet back up so I plunged it ,water went down, then once filled clean water bubbled in toilet, then nasty toilet water started coming in my bathtub which sits next to it. I have now plunged &...
If water is backing up into the tub then you have clog downstream from that bathroom group. If water backs up when you ran water in the rest of the house then you have a clogged sewer service. With either case the house drain and / or sewer drain will need to be snaked. Most of the time it will be the sewer drain.
Jan 18, 2011 | Plumb Pak 1-3/8 Bath Waste/Overflow Assy...
Waste drain does not take in water, spills out.
Replace the clogged drain pipe. You need a plumber. Washer is ok.
Jul 05, 2009 | Maytag Centennial MTW5807TQ
Admiral washing machine no cold water
HI, this is a faulty inlet valve assembly. you should replace this failing component asap if possible.This will fix the issue.
Jun 22, 2009 | Admiral Washing Machines
Matag washer may be leaking, esp when in use.
Remove the front panel from the washer. Fill the tub with water and then set it for spin.
Look for water coming from the machine. If so, report back as to where the water is coming from.
If no water is coming from the machine......
While the water is pumping out, look at the drain line in the wall and see if it backs up.
If so, call a plumber to clean your drain lines.
Mar 04, 2009 | Maytag Washing Machines
Washing machine not taking in water
could be air in line washer thinks no water try taking supply off and let air out till water comes out then put back on washer make sure you turn off first lol, and first check to see if the plumber turned supply off for washer by mistake .
Jan 13, 2009 | AEG Washing Machines
Cool water comes out on warm water setting.
The water that is coming from the hot water pipes is likely not hot because it cooled down while sitting in the pipes. We had similar issues with hot water not being ready when our appliance needed it. We heard about Redytemp from our plumber. We have yet to have anymore problems with having hot water when needed.
Dec 09, 2008 | Frigidaire FEX831CS Top Load Stacked...
Kenmore Oasis HE 27082 Top Load Washer Logo
53 people viewed this question
Sal De
fordexpert
Robert Rankin
