Question about Cameras
Have a lumex dmc-tz3 worked great until 1 month ago now pictures have a blue tint/hue
July 13, 2009
Panasonic TZ3
Did you ever find a solution to the blue tint that shows up on your pictures? We have the same camera and also have this blue tint
thing going on. Wonder if we have a menu setting wrong?
Posted on Jul 13, 2009
Panasonic Lumix DMC - FH20 Outdoor pictures have a blue tint to them. Why? and how can I get rid of this?
Hi could you post the sample picture? I am certain that it is circuit fail or white balance selection. Thanks and best regard!
May 25, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
When trying to take picture....screen looks pink-tinted , not clear...I was thinking a button or feature had mistakingly been touched...but cannot figure out what has changed the focus on screen...is...
This is likely a problem with some settings with your camera, or some damage to your lens. I personally haven;t used one of these camera's but if you can check the settings look for things like color, hue, tint, etc. If it is not a settings issue, you may want to consider having an electronics store take a look at it to check the lens for damage.
May 05, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
Pictures are shadowy with panasonic tz3
Is the flash going off? Have you tried slow shutter sync with your flash indoors for some great shots.
Nov 22, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Our Sony Grand Wega suddenly has a green-yellow tint.
IF IT IS HOOKED UP WITH COMPONENT CABLES (GREEN, RED, AND BLUE) FOR PICTURE AND RED AND WHITE FOR AUDIO, MOST LIKELY THE RED ONE IS NOT SEATED PROPERLY, CHECK BOTH ENDS THE ONE CONNECTED TO THE TV AND THE ONE CONNECTED TO WHATEVER THE SOURCE IS ( SATELLITE BOX, CABLE BOX ETC.
Oct 06, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Blue hue accross bottom of screen - Sony KF-50WE610
You can try doing this, turn on the Tv and select the service menu, if that tint also shows on the menu, it's most probable to be your DMD board, but if it doesn't it might be the video board..
Jul 03, 2009 | Sony Televison & Video
Blue dots and blue screen on Hitatchi 50"
Bad Light Engine Call UED for rebulit one 1-800-648-6657 They are not cheap.
Dec 26, 2008 | LG RU-44SZ51D 44" Rear Projection...
Blue photos from a Panasonic Lumix DMC-TZ3 digital camera
It might be an idea to check whether your "white balance" is not set to "fluorescent light" or "custom white balance". "Auto" is the safest option here. Incorrect white balance would cause blue/yellow cast on the picture. Otherwise the problem might be more severe (i.e. sensor failure-not common in TZ3 though).
If you're still getting blue cast with white balance set to auto, you can try to set "custom white balance" with white sheet of paper (refer to the manual for details) - this will override auto white balance.
Raf
Dec 18, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic DMC-TZ3
We are in the Charlotte area but sent the camera into Panasonics' digital camera repair in Elk Grove Village, IL.
Jun 14, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Kf-42610 blue hue and blue dots on screen
Hi Guys
The Blue dots or discolouration you are seeing is due too the Blue LCD screen having cracked from excessive heat. This normally happens when you have a power failure while the Television was on. This obviously because the Blue LCD sits next to the lamp - the main cause of heat. The correct part number on the 60" is A-1086-952-A. It is very, very ,expensive.
Sorry to have been the bearer of bad news. Good luck : )
Aug 29, 2007 | Sony XL-2100U Projector Lamp for...
Cameras Logo
231 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
