Question about Garmin nuvi 200W GPS Receiver
The garmin was left in the vehicle that was very cold overnight.
Garmin does not turn on at all. Is it frozen for good? I purchased it in early november, is it under under warranty? Would warranty cover it?
Thank you.
Rob Hirsch
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    1. Is it fully charged?
    2. Have you tried pressing the reset button on the bottom where the decal is?
    There is a (1) year warranty on Garmin products. If you still can't get it to turn on, please go here:
    http://www.garmin.com/garmin/cms/site/us...
    - Jim
    SHARCNET-USA
  • 333 Answers
Your warranty would cover that and should be good for a full year after purchase. Also it is possible that the unit overheated in the car. Especially if you're in a hot climate. Electronics heat up very easily when left in the hot vehicles. It's usually 50 - 75 degrees hotter inside the car than it is outside the vehicle. My best suggestion is to call garmin and have them exchange it.
Posted on Sep 15, 2009
How do I turn on my Garmin Nuvi?
Go to Garmin and download and install Garmin Express, Plug your GPS into your PC. The GPS should power on and Garmin Express should identify it and tell you of any updates. If the GPS does not power on (it should go into usb mode), then contact Garmin for warranty work. You can also check the power adapter in your vehicle. If the red light does not come on, the adapter either has a blown fuse or went bad, causing your GPS battery to be discharged. It is quite possible that your battery is discharged. You might leave it plugged into your PC overnight if the battery is dead.
Mar 28, 2017 | Garmin nuvi GPS
I plugged in my Garmin Nuvi 40LM to the computer and got the updates. But my keyboard is still not responding correctly. I push 5 and get a 6 or push T and get a Y. Any ideas?
Try recalibrating the display. Turn off the Nuvi. Place your finger on the upper left-hand corner of the screen and hold it there while pushing down on the power button to turn the unit on. Release the power button when the Garmin logo appears. Continue to press on the upper left-hand corner of the screen until you see the calibration screen.
Press all of the dots as they are presented. Once completed the Nuvi will display Calibration Complete
This will recalibrate your touchscreen to the LCD display. If this doesn't resolves your problem. then your touchscreen may be defective.
Feb 25, 2016 | Garmin Nuvi 40Lm - Gps Receiver
Nuvi 775 GPS Receiver: My Garmin nuvi 775 will come on with the Garmin lo...
Try resetting the unit and also charge it using only the wall charger overnight. Here's how to reset -it just puts everything back to factory settings - 1- Turn unit on WHILE HOLDING your thumb in the lower right corner as shown in picture. 2-Select YES PLEASE Take the time to vote me up this is my only reward for trying to help. Thanks
May 03, 2010 | GPS
My Garmin Nuvi 260 is frozen on the Garmin screen
with the garmin off, hold down the right bottom of the screen and turn the garmin on, it will then ask you if you want to perform a hard reset. Choose yes and that should fix your problem.
Jul 27, 2009 | Garmin Nuvi 760 Car GPS Receiver
Forerunner 405 completely frozen
I had exactly the same problem. i looked through this site and found some advice that said to hold both buttons (quit/enter) for 7-10 seconds, which resets, but apparently doesn't wipe your info - happy days :)
Jul 12, 2009 | Garmin Forerunner 405 Handheld GPS...
My Garmin Nuvi 255W is frozen on. Won't shut off won't do anything!
You can try a soft reset. Remove the SD card if you have one installed (this might be the cause of the problem)
Slide the power key to the left
Hold it in that position for about 10-15 seconds
And see if it reboots normally. If it does you probably will have to charge the battery and should go to Garmins support center to check for any system updates that will fix the problem. Sometimes it will just freeze and be annoying but there isn't a problem that needs to be fixed. Other times it can be custom maps or the nuvi's operating system needs a update.
Good units tho. Have one myself.
Jul 09, 2009 | Garmin nuvi 255W GPS Receiver
Brand new unit.Garmin c330, Will not stay on.
Since I didn't hear from anyone, I contacted the co. I purchased from. I was advised to send it back.
May 12, 2009 | Garmin StreetPilot C330 GPS Receiver
Frozen screen screen is frozen and wont power off
2 OPTIONS
ONE, RESET IT !!! (See resetting instructions below)
TWO, let the battery die out!
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Feb 28, 2009 | Garmin StreetPilot C330 GPS Receiver
Street pilot c330
It took a nap...
Feb 21, 2009 | Garmin StreetPilot C330 GPS Receiver
My gps was working last night and now it jsut wont turn on.
Hi, Has it got wet or frozen overnight? How old is the battery? Can you plug it in and try after an hour or so of charging?
Most likley your battery is dead.
Jan 09, 2009 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
79 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
