Question about Coleman Powermate Premium Plus 6250W Portable Generator
Powered up Coleman Generator. Generator made grinding noise
Followed by burning smell. Prime mover works fine, but no power to outlets.
    Problem Solver:
  • 10 Answers
I don't know what unit you have, but I would say it was overloaded and shorted out the stator, burned up the voltage regulator, exploded the capacitor, or had a loose connection that caused some wires to burn up. Maybe remove the end plate off the generator end and take so pictures and will go from there.
Posted on Feb 03, 2009
I have a coleman powermate 6250-5000 running watts-generator. The generator starts and runs but does not produce current to outlets,the outlets are fine-they have continunity,I removrd the armature and...
You may have just lost residual magnetism in your rotor. Start genset then apply 12 vdc to 120 v outlet for less the 1 seconds. This will be enought to restore the residual magnetism to the rotor and the unit should be producing power now.
Nov 17, 2009 | Coleman Powermate Premium Plus 6250W...
6000w gas generator putting out low voltage
Your voltage regulator is at fault. Make sure you replace it with the exact same brand name and serial number or you will burn out the generator.Thank you, Dana
Oct 06, 2009 | Coleman Powermate Proforce 6,000 Watt 12...
Coleman 5500 W/Yamaha MZ300 engine, runs great, no power produced
next is...brushes..
if they were fine check AVR
don't hesitate to write to me for further information:
sal_kh_sab@yahoo.com
Aug 29, 2009 | Coleman Powermate Premium Plus 6250W...
Coleman PM0433500 Brushless Generator will not make power
Bad capacitor. They cost 13 bucks. Call 800-445-1805 to buy one.
May 31, 2009 | Coleman Powermate Powermate 5000W...
Replacing engine on Powermate 5000W Generator
I would say, yes (given everything bolts up okay), but I wouldn't connect a full 5000-watt load to it.
May 30, 2009 | Coleman Powermate Portable Generator...
Coleman 5KW gen motor shuts down when A/C switch turned on
Sounds like a problem with the wiring of the outlets after the circuit breaksr. Take apart the outlet box and have a look for burned or broken wires, melted outlets, and/or small critters stuck in the wiring.
I recently had to repair a generator that had its voltage regulator taken out by a frog!
Regards,
Carl
Feb 28, 2009 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate only puts out 110V
If you haven't seen it yet, here is a page that may help with a manual or parts list.
This problem sounds kind of bad, generators don't do well when the engine stops under load.
Start by checking the circuit breakers in the distribution box (outlet panel) - you need ot do this with an ohm meter. After that check the power windings of the stator with the ohm meter, be sure to check between the 2 windings (should be open), and from each one to ground with the winding isolated.
Whining, a burning varnish smell, and breakers that trip all the time are indicators of long term overload problems. This could happen if you had most of the load on one winding for a significant amount of time, or if the one winding mostly powered motor-like loads with high startup currents.
You may want to look at this answer I posted some time ago.
Regards,
Carl
Jan 06, 2009 | Coleman Powermate Powermate 5000W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
186 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Phil Walker
Phil Walker
Tim Garcia
Tim Garcia
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
