Question about E-Machines eMachines Desktop PC
Pc wont boot
My pc had been turned on for about 25 mins, I was gaming (not very system intensive) and the pc shutdown instantly, the monitor retained power so not a spike. System tried to rebbot itself but re-shut down half way through boot process, it tried to reboot again, only this time it only managed about 7 secs of boot process. This repeated itself about 5 times with the mount of time the pc booted for reducing each time until it does not boot at all. I still have a light come on at the on button but have nothing happen when switched on (no fans, drives, operable)
What has broken?
My system specs are:Win xp - sp3, 650W atx psu, e6600 duo processor and motherboard(pd5k asus i believe?? came with the pc), 9800gt g/card, 2x sata hd drives, 1x optical drive, 3gb ram. I installed ram, g/card and psu about 2 months ago and all has been very well till now.
  • 151 Answers
Power supply.
Posted on Jan 14, 2009
When playing games on laptop hebirnating or shoting dawn
Graphics might be over heated. So it will shutdown.. go for advance version graphics chipset motherboad,. for better game xperience.,
solution: use heat sink., and check cpu fan., monitor cpu temperature..
System Shutdown During Gameplay
Jun 06, 2015 | Computers & Internet
Windows xp sleep suspend hibernate
make sure the cables have not come loose, then turn the monitor off then back on, if that doesn't work is where the fun starts. boot up to safe mode with networking. If that loads up and the screen is still black then either your monitor or video card need replaced. Hook up a different monitor if that works it is naturally your monitor, if not then it is your video card. Unless you are into high end graphics design, gaming, or hooking up to a flat screen tv, they are not too too expensive and can be swapped out in a matter of minutes
Aug 25, 2012 | IBM ThinkCentre M51 PC Desktop
Notebook Crashes to PowerOff state when lid is closed
Running intense program with the lid closed will cause a sharp rise in temperature making the laptop hotter than it should be leading it into a shutdown. The second issue, windows should be shutdown properly rather than closing the lid, this makes the operational system unstable and will cause files to corrupt eventually.
May 23, 2012 | ASUS N82JQA1 14 HD Notebook Intel Core...
I have HCL Beanstalk Desktop, Monitor - Samsung Syncmaster 794MG. I don't have a ups. I get frequent powercuts in here resulting in interrupted shutdown of the computer. Sometimes while playing a game...
You seem to have a corrupt display card. Is it on board or do you have a separate graphics card installed in your PC. Either way on restart graphics processor is not turning on. What does the Power and HDD indicator on the PC show during boot up. You could also have damaged the Hard Disk because of your abrupt shutdowns. You can open the side cover and try disconnecting the HDD power (Yellow, Black & Red ) cable and IDE ( 40 pin flat ribbon wire ) cable and try restarting. If your monitor starts up and shows BIOS page you have a faulty HDD. Also see if the processor fan is a working when you start the PC. If not you have a failed mother board. Are you getting the boot up RAM beep. If not before you do any of the above mentioned things Just pull out the RAM ( with PC unplugged ) and reinsert into the slot. It might get your PC working after all
Mar 08, 2011 | MSI Computers & Internet
Alienware Aurora Desktop does not boot, has no HD activity
If the activity light on the front of the tower is not glowing than it can be an issue with the power supply of the PC. Try to open the tower and try to reseat the Power supply cables and check.
You can also try to Reseat the RAM (memory) sticks. If you have 2 Memory stick you can just try to boot the pc with the help of one stick and vice versa. If still the issue persist you can try to do a test on the Motherboard. Simply take out the Memory cards and power on the pc . if you hear a beeping noise than the Motherboard is fine and if you dont hear a beeping noise that it is a faulty Motherboard.
Jul 06, 2010 | Alienware PC Systems Alienware Aurora High...
I have a dell dimension 2400. My starts up fine
Most likely a motherboard issue.
Also ensure the CPU Heatsink is firmly attached. If the heatsink is loose, replace the plastic heatsink retainer
If it is secure, then the motherboard is the most likely failure point
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
May 19, 2010 | Dell Dimension 2400 PC Desktop
I install symantec antivirus but its disable auto protect in tray show icon red round
You got a virus that designed to disable Norton. Do yourself a favour, uninstall Norton. Here a link to an excellent free piece of software for home users. Download it, install it, update it, schedule a boot-time scan, you wil be amazed by just how much it finds & it wont slow your system by being too labour intensive like symantec. http://www.avast.com/
Oct 02, 2009 | Symantec AntiVirus 10.0 with Groupware...
Monitor goes black
this is a no bot issue & check if any other device like any peripherals are connected with the computer like a printer or a camera or an external pen drive etc are not connected with the system at the time of booting up the computer,in case they are connected then try disconnecting them & also try doing the Flea power ie removing the main power cable and then pressing the power button on the cpu for about 20-25 mins & then turning on the computer.this will help you out.
Apr 24, 2009 | Microsoft Windows XP Professional SP2 for...
When i start to play a game after 5 mins of playing,it will automatically shutdown the monitor
can u tell me wat games do you play?
and the system requirments of the game and specs of your pc.
Mar 06, 2008 | Smart Modular SV3170A
E-Machines eMachines Desktop PC Logo
88 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
