Question about Pioneer Audio Players & Recorders
The display on my old Pioneer stereo multi CD receiver fades
Pioneer XC-P410M - works well in all respects except the display fades on and off. First power on it is usually on, then after a few moments fades out. A small tap on the display screen brings it back, sometimes. Sometimes stays on for several minutes. Sometimes just pops on and then off. Can I easily remove the front face of the device t see if there is a loose wire or connection.
  • fortinl Jan 15, 2009
    Thank you for the helpful suggestion. I located a small independent repair shop in Brockville, Ontario (about 50kms from me in Smiths Falls). He will attempt the fix for a bench fee of $25 plus up to $40 for the soldering. He doesn't think any parts are needed.
  • 4,234 Answers
The problem is a bad solder connection probably on the display itself. These are not the easiest to open up. I would not suggest you attempt this if you haven't done these before. This is a simple fix for any shop that handles audio repair. Call around for a shop that works on Pioneer gear and request an estimate over the phone. Indicate that the dispaly has bad connections that need to be resoldered. You may find a shop that will repair this for short money. Where are you located? Perhaps I can suggest a shop.
Dan
Posted on Jan 14, 2009
Pioneer XC-IS22CD 100w CD/Tape/Radio Stereo what is the size of this
dear sir this is it all
Dimensions (W x H x D) 215 x 372 x 274 mm (S-IS22 speakers)
Dimensions (W x H x D) 160 x 300 x 237 mm (M-IS22 Amplifier)
Dimensions (W x H x D) 204 x 300 x 237 mm (XC-IS22CD head unit)
just tell me if i was helpfull
Aug 12, 2011 | Pioneer IS-22CD CD Shelf System
I cant set the clock on my pioneer deh 21001b cd player
Adjusting initial settings
1 Press SRC/OFF and hold until the unit
turns off.
2 Press MULTI-CONTROL and hold until
CLOCK SET appears in the display.
3 Turn MULTI-CONTROL to select one of
the initial settings.
CLOCK SET (clock)—AUX (auxiliary input)
# To return to the previous display, press
DISP/BACK/SCRL.
# To return to the main menu, press and hold
DISP/BACK/SCRL.
# To cancel initial settings, press BAND/ESC.
Setting the clock
Use these instructions to set the clock.
1 Use MULTI-CONTROL to select
CLOCK SET in the initial setting menu.
Refer to Adjusting initial settings on this page.
2 Press MULTI-CONTROL to display the
setting mode.
3 Press MULTI-CONTROL to select the segment
of the clock display you wish to set.
Each time you press MULTI-CONTROL, one
segment of the clock display is selected.
Hour—Minute
As you select segments of the clock display,
the selected segment blinks.
4 Turn MULTI-CONTROL to put a clock
right.
Sep 26, 2009 | Pioneer DEH-2100 CD Player
Display says ATT-
Disconnect the battery for an hour. This will reset the stereo and usually the problem will go away when you reconnect the battery.
Jul 20, 2009 | Pioneer DEH-P690UB CD Player
Can't set clock
1. Power the unit off (See instruction manual page 11, "Power ON/OFF") - Crucial missing instruction.
2. Use MULTI-CONTROL to select CLOCK SET. 3. Press MULTI_CONTROL to display the setting mode. 4. Press MULTI-CONTROL to select the segment of the clock display you wish to set. 5. Turn MULTI-CONTROL to put a clock right
May 17, 2009 | Pioneer DEH-P4000UB CD Player
Setting clock
Use MULTI-CONTROL to select click.Clock appears is the display.
Pushing MULTI-CONTROL left or right will select one segment of the clcock display: Hour - Minute
As you select segments of the clock display the segment selected will blink.
Pushing MULTI-CONTROL up will increase the selected hour or minute,down will decrease the hour or minute
Mar 24, 2009 | Pioneer DEH-P6900UB CD Player
Can't set clock on stereo
Here's the answer I found straight from Pioneer:
If your car CD player is a 2006 model or newer:
  • With the ignition on and radio OFF,
  • Press and hold the MULTI-CONTROL button for 2 seconds
  • Rotate MULTI-CONTROL button until display reads CLOCK.
  • Push MULTI-CONTROL button up or down to adjust hour and minutes.
  • Press ESCAPE or SOURCE button to exit
If your car CD player is newer than 2000 but older than 2006:
  • With the ignition on and radio OFF, press and hold the FUNCTION button, until the display pops up, then release the button.
  • (If you do not have a function button, use the AUDIO button instead).
  • Press the FUNCTION button again until the clock shows on the display.
  • Press the UP and DOWN buttons to adjust the hours.
  • Press the LEFT and RIGHT arrows to move to the minutes.
  • Press the UP and DOWN to adjust the minutes.
    When you've completed all the steps, just press the SOURCE button to exit
If your car CD player is 1999 or older:
  • While holding down the CLOCK button, press the number preset button to set the hour.
  • While holding down the CLOCK button, press the number 2 preset button to set the minutes.
  • Pressing the respective buttons consecutively or continuously will advance the hour and minute.
Feb 10, 2009 | Pioneer Car Audio & Video
I own an Pioneer CD tuner XC-L11 with a stereo power amplifier M-L11. Recently it won't switch on with the standby button flashing red. Nothing happens after that and the system doesn't work. Could you...
On the first board (where the power enters) there is a tall 3 pronged switch, if you turn the board over and solder a piece of wire to the 2 outside prongs, you will find that the Amp works normally apart from that the display reads Cd closed when in Cd mode.
Aug 28, 2008 | Pioneer Audio Players & Recorders
563 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
