Question about Maytag Portable Air Conditioner M6P09S2A
Water leaking from portable air conditioner
When the portable air conditioner is running the water condensation fills up the top reservior. However, it does not seem to go into the bottom reservior. Instead it overflows and leaks out of the back of the unit.
  • becka_fel Jan 21, 2008
    our porable air conditioner is a dimplex is is one week old and the last few nights it has been leaking water everywhere and we keep drainning the water and then it is fine for 10 mins then it will start leaking again can you help me
  • Anonymous Jul 12, 2008
    similar situation
  • 105 Answers
First, make sure the unit is level. If so, you have a blockage or kink in the drain tube. Careful inspection should reveal any blockage, & you may be able to poke it thru with a piece of coathanger wire. Don't use excessive force, any block should be easily freed.
Posted on Jul 15, 2007
  • Ken Wang Sep 02, 2013
    No detectable blockage in the bottom drain, per your instructions. Next step?
I have the LG LP1200DXR and it is leaking near the wheel and i cant figure out why, when we drain it no water comes out what could the problem be?
All air conditioners collect condensate. It has to drain somewhere. Try connecting tubing to the drain hole or port. In order for air conditioners to remove heat from a space, they also remove humidity, which is water vapor in the air. Like placing a cold beverage in a warm room, it will form condensate (water) around it. The water that you were trying to drain out already leaked out. This is a normal thing for condensation to form when cooling. The condensate needs to be emptied regularly or piped with flexible tubing to a window or plumbing.This is the same as water dripping from your car while the A/C is on.
Aug 30, 2013 | LG LP1200DXR Portable Air Conditioner
Leaking water
Connect the proper sized tubing, and run it to a desired drain area. Make sure no outside air is entering the conditioned space.
Aug 30, 2013 | GE APN08AA Portable Air Conditioner
I have an Amcor 12000M portable air con unit. How do I top up the water tank?
There is no need to top of the water tank. When the unit is running it collects condensation and fills the tank with water. When the tank is FULL the Full indicator will illuminate and the unit will shut OFF. You will ten need to drain the water from the rear drain hole.
To further assist you, in case you have misplaced your Owners Manual. I have included a link to it that you can download & print for future reference.
http://dl.owneriq.net/a/ab0f1f5c-8efe-41da-a834-ba11df36ca35.pdf
I hope this information has helped you and thanks for choosing FixYa.
Aug 22, 2011 | Amcor AMC12000 Portable Air Conditioner
Air conditioner leaked a lot of fluid that looked like water after being on all night. Do you think this is an easy fix, or what do you think is wrong with it? Thanks
All air conditioning units have built in drains. When the drain is clogged the water fills the drip pain and spills out. An easy fix is to open you unit and just wipe the drains. If you cannot find the drain find where the water is coming from and trace the water to the source. The other possibility is that the unit has a dehumidifier that is not properly sealed and it is leaking the water it collects if so find the dehumidifier (usually labeled) and pull the cover off clean the seal and put cover back on (may snap into place) and see what happens the next day.
Aug 21, 2011 | DeLonghi PACA110 Portable Air Conditioner
My amcor air conditioner is leaking water all over the floor. I drain it and it will only last less then 24 hours till it turns off, leaks all over an needs to be drained. Help!
I figured out the problem. My Amcor portable started leaking after the fill light came on for the first time in years. After doing some research I saw that it uses the water to cool some other part of the system to evaporate out the exhaust. So I took the ******* apart and messed with things. Finally I started pouring water into different trays and noticed it would not drain down from the top tray even when running. So I removed the top part and found the drain hole. Blasted that sum ***** with some compressed air and WAMMO it works again.
-madmanmarz
Jul 06, 2011 | Amcor PLM-14000E Portable Air Conditioner
Water leaking all over
The water leaks all over the floor instead of running into the water containner. if that is right then your condenser drain pan tubing is blocked or the pan is rusted out that cause the water leaks all over instead of running down the tubing into the water containner . You've to dismantle the panels to get into this condenser drain pan to have a good clean out . Hope this will help . God Bless.
Jul 23, 2009 | Heating & Cooling
Everstar portable ac fills the overflow water bucket in one day. Why?
Air conditioners cause the moisture in the air to condense on the evaporator coil. The water that is created needs to have somewhere to drain. If the unit is in a humid environment, it will create allot of condensation. This kind of operation is not uncommon.
Jul 06, 2009 | Danby DPAC8020 Air Conditioner
No water
If the air conditioner is putting out cold air, don't worry about it making water. You may not have enough moisture in the air to produce more water than it requires.
In some types of air conditioners, the water taken from the air is used to assist in cooling the condenser unit. The excess is run off.
Jerry G.
Jun 21, 2008 | DeLonghi CF210 Portable Air Conditioner
Sounds like the drain line is blocked you would have to take this unit apart in order to check this. I would use a can of air to blow out the leakage. Also make sure the unit is level
Jan 23, 2008 | Heating & Cooling
Heating & Cooling Logo
1,632 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Marvin
Marvin
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
