Question about Hotpoint Aquarius WMA42 Front Load Washer
Water is leaking from soap dispenser only at beginning of cycle
Hotpoint Aquarius 1200 washer dryer
  • Hotpoint Master
  • 3,463 Answers
Remove dispenser drawer, and check for soap blockage.
Locate and clean filter, check to see if there is one located behind bottom kick strip, if no filter there, then you will have to remove lower rear cover of washer, and locate and remove the large black hose on bottom of tub.
Remove filter and plastic ball,clean and replace.
Refit filter, ball and hose ,ensuring it is fitted correctly.
Test for leaks.
Plz ratev my solution.
Thanks.
Posted on Jan 14, 2009
I have water leaking from the dispensing tray, only on the pre wash filling..any suggestions I have a hotpoint washer dryer wd64
Check the level of the machine, may be leaning slightly forward allowing water to leak on that one fill cycle. Lift the front a little by using the adjustable feet and see if it stops.
Feb 16, 2010 | Hotpoint Aquarius WD640 Front Load...
Hi I own a Hotpoint WM61 machine and water is leaking out of the soap dispenser. Can this be fixed? What part do I need?
The pump filter probably requires cleaning.
Remove lower panel of washer.
Remove large black on bottom of drum.
Removw and clean filter inside hose.
Remove hose onto pump.
Check for blockage or obstruction here and in the pump.
Please rate my solution.
Thanks.
Nov 20, 2009 | Hotpoint Aquarius WD640 Front Load...
Water leaking from detegent drawer big time at start of cycle then lessens further on in cycle.
Take out the dispenser drawer get a babys feeding bottle brush and make sure that the hose from the dispenser to the drum is clear
As there are a few comments on the site re the same machine with the same problem it could be a design fault however it could also be congealed soap powder
Jun 14, 2009 | Hotpoint Aquarius WD640 Front Load...
Major leak after 20mins into wash cycle!
Have a good look at door seal., and see if you can see any hole or tear in rubber.If o/k, then remove rear panel, and watch whilst it is running, and see if you can see any sign of water coming from anywhere.
Make sure the water is not running down the front from the dispenser, which would suggest a blockage in the dispenser drawer.
These are the steps I would take first.
Also make sure the waste outlet is clear
Plz leave rating and any comment you may have.
Thanks..
Jan 21, 2009 | Hotpoint Aquarius WD640 Front Load...
WD 63
Remove dispenser drawer from m/c, and thoroughly clean it and all accessories.Clean all residual build up of undesolved powder and conditioner in drawer compartment..
If it still leaks, then remove top cover, locate large black hose at bottom of dispenser, and give it a good squeeze to clear any possible blockage in the hose itself..
If still no better, could be due to exceptionally high water preesure forcing the water out of the drawer.
Turn cold water valve down a little to reduce pressure.
Plz rate my solution.
Thanks.
Jan 09, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint wd440 aquarius
Not all programes fill with hot water.Try on 95 degree wash if it takes hot water ,you are dialing a prog,that does not take HOT.
Oct 31, 2008 | Hotpoint Aquarius WD63 Front Load...
Water leaks from the soap dispensing tray on Hotpoint WMA 56 model
In the sump hose there is a filter, remove the hose and clean out filter insert, water is being forced up dispenser hose because it cannot empty fast enough.
Dec 24, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Soap dispenser
Some softeners are too thick, you could dilute this with water before you add to the machine. Note: Your tube to the softener drawer could be loose or something, you could check this by taking the top of the machine off to examine. Actually simple.
Oct 07, 2007 | Hotpoint Aquarius WD63 Front Load...
Water leaking (Aquarius 1200)
don't think using quick wash should make a difference as water intake is the same take drawer out and wash thoroughly especially the rinse compartment. if gunged up the water overflows the compartment and leaks down the front. otherwise, you may have a blockage in the hose from the drawer to the tub. take top off, remove this hose and clean disconnect from mains when you do this
Apr 01, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WMA42 Front Load Washer Logo
319 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
