Question about APC Back UPS 650 (APWBK650MC) UPS System
APC 300 0 PROBLEM
OK APC 3000WAT
OUTPUT IS SAFE BUT WHEN BACK UP OCCURS
FROM 220V TO UPS THE OUTPUT BECOMES TO ZERO ALLOF RELAYS IS SAFE
ONE RELAYS BLINKS OFF AND ON
    Scholar:
  • 64 Answers
Your inverter is blown on the ouput. If it is a 300VA get a new one, 3000VA, you will need a local UPS repar company.
Posted on Sep 08, 2009
Do not turn on even connected to the power outlet.please help!
check the batteries,make sure ups run on battery before input mains.report
Oct 02, 2015 | APC Back-UPS RS BR500CI-AS...
How can you tell if the system is bad on apc back ups es 650
plug something (other then a computer)into it, turn the gadget on, then unplug the UPS. If the gadget continues active the UPS is OK. Generally after you have punched every button (circuit breakers). After that put a Volt/Ohm meter on the batteries (and the charging wires to check the charging curcuit is OK.
Apr 29, 2014 | APC Back-UPS ES 350 - UPS ( external ) -...
Apc xs900 will work off batteries not off ac
So something happened to this apc and the first thing is to replace batteries...
I'm going to guess major circuit board failure.
go to apc site, download Power Chute software and pray there are useful diagnostics.
Mar 31, 2014 | APC Back-UPS XS900 (BX900) UPS System
APC RS 1500 82v output
Many UPS Systems have a squared wave when working on batteries. Cheap multimeters do not give the correct measure on squared waves. Connect a 100 watts resistive lamp to the output of the UPS, if the light is almost the same when UPS is working on batteries, everythinf is fine.
Dec 23, 2013 | APC BX 1500 Back-UPS XS 1500 (APNBX1500)...
My ups 1000 watts suddenly get off for few minutes than again starts itself .it happens 2-3 times in 24 hours.
Back up devices on the computer creates copies of every new features that are performed. The backup devices default settings may allow to save data every often like 2-3 times in 24 hours. also, the backup devices save settings can be altered to suit user speciifcations. for example, important projects on important files may require to save every few seconds lest any malfuntion that occurs to the computer is misplaced. back devices are considered external structures and should be locate on the computer systems control panel area with a unique description. Clicking on the backup devices logos would allow to manipulate either create urgent backup or space the backup to make the computer faster where back becomes attainabel durign idle hours.( for example, set the computer backup to first tthing in the morning or last at close of computer usage.)
Feb 05, 2011 | APC Back-UPS RS 1000VA UPS System
APC SmartUPS 3000VA
APC do not release cct diags and these are not easy to repair, if the battery fuse was open and there is some board damage, the thing is toast. Even if you get it going the battery will not be able to be calibrated, unless there the board/processor is 100%, I know this as we have a similar model on the bench right now with new batts in and the unit will not recalibrate, so even though the batts are new, as soon as the mains is dropped it goes to very low battery and shuts down in 2 mins.
Buy a new UPS save yourself a lot of time. Hope this helps
Thanks for using FixYA
Aug 02, 2010 | APC Smart-UPS 3000VA UPS System
APC 280 UPS problem. No A/C output when power interupted. Battery charges OK.
Have you load tested the batteries? DCV is not a good enough test for the batteries, they could still open right up under load. If the UPS is over 3 years old, I'd swap the batteries. Your power is drawing solely from the batteries on AC line loss, so if the UPS is failing when that occurs, almost certainly is the batteries.
Aug 20, 2009 | APC INTERNATIONAL BACKUPS PRO 280...
No output
bacause is overloaded. There is a reset switch inside the ups, locate that and reset it.
Jul 26, 2009 | APC Smart-UPS 1000XLI (SUA1000XLI) UPS...
APC Back UPS 650 (APWBK650MC) UPS System Logo
155 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
