Dell Latitude C400 Notebook Logo
Angela Shelton Posted on Dec 15, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to connect wifi
Adding laptop to wireless device
Peng Xiong
Level 2:
Sergeant:
  • Expert 236 Answers
  • Posted on Dec 17, 2012
Peng Xiong
Expert
Level 2:
Sergeant:
Answers
236
Questions
Helped
52988
Points
599
This video will show you how to connect to a wireless network using Windows XP with Service Pack 2 or above installed.
http://youtu.be/AwzYwz7aGho
As regards to the wireless security please make sure you use your own security settings.
4helpful
2answers
My acer aspire wont connect to my centurylink wifi
Try re-installing the wireless card driver and the configure the wireless card to the wireless router's wireless settings. You can also have a look at the wireless card settings in the computers that is connecting to the wireless router/Internet and then apply these settings to the wireless card in the Acer.
I have acer laptop 5580. 3 year old. Recently i have installed Windows 7. Wireless was working nice. Now, system is identifying the wireless, but not connecting. After troubleshooting it is giving...
If your device can detect other acces point then, your wifi device is correctly installed. If not, os will tell your wifi have problem. If you try connect, and have problem with connection, it came from your acces point(wifi router expample). Maybe it have password that have not match with your pc. If that access point is yours, then you can try check the password for wifi using cable connection.
If that acces point(wifi router) is not yours(public), then you cant get the password unless you try hack using air-ng, backtrend using wifi device that can capture and monitor the network(wifi *** support a/b/g exmple) if it only support b/g, you cant get wep encryption password.
If it does not have password, and you try to connect, but it still problem, that mean, it have restrictly to MAC address in wifi router.
How do i unlock my internet so i can acess wireless off it
Are you trying to connect a wireless capable device to a wireless connection?
If Yes of if unsure, to connect a WiFi capable device to a wireless connection you will need the following: a cable modem, a wireless router, Ethernet, a WiFi capable device.
You would connect the wireless router to the modem follow the installation manual instructions for the router to properly setup the router, different brands require different setup procedures.
Once the router is up and running find the SSID (wireless network name you gave the wireless router during setup) for the wireless signal. Click on the SSID in the list of available networks and enter in the passphrase when prompted to.
If all is successful you should connect to a wireless network
Let me know if that helped or if you need additional information or clarification.
I’m happy to help further over the phone at https://www.6ya.com/expert/james_d4449ffdf318a2c3
11helpful
4answers
How do i turn on wireless on acer aspire 4810tz
It has a touch panel at the top above the keyboard touch it to turn on also go into the control panel and select wireless devices select wireless you see a wire connection and a wireless connection right click on it select properties and you will see an option to enable or disable enable it an it should come on
2answers
Wifi connection problem
Windows WiFi Fix,
Windows Zero Wireless Configuration is one of the best programs to run a WiFi in Windows XP or Vista. Most of the other software packages that come with the different adapters have been poor at best in keeping a connection through Windows. Here is the best guide to get you back up and connected.
Windows XP:
Click Start
Right click on My Computer
When a window pops up click on properties
Click on the Hardware tab
Click Device Manager
Click the [+] next to Network Adapters
Find your wireless card and right click on it.
Click Disable
Windows may warn you that disabling the device may make it stop functioning.
Continue disabling the device.
Wait 30 seconds or so.
Right click on your wireless again and click Enable.
Exit the device manager.
Reconnect to your router.
You should now be able to connect to the internet.
Windows Vista:
Click Start Logo
Right Click Computer
Windows will ask you about opening Device Manager Click Continue
Click Disable
1helpful
3answers
Cannot seem to get wireless connection . ethernet connection works fine . do i need usb adapter to bring my 3 year old laptop up to N standard ? Ray
If your laptop does not have a wireless card built into the computer then yes I would go and buy a usb wifi adapter because you cant get wifi if you dont get one.
Wifi goes down with zyxel G1000v2
It is not compatible at all wifi is a wireless connection and you are adding another device called zyxel it is like i have adsl unlimited and am adding a new connection with adsl normal of course it will go down not same speed at all wifi connection is 54 mbps normal speed where as zyxel is too slow with only 10 mbps
Cant connect wireless
If the stick is the solution, why are you avoiding the solution?
From what you have said, the internal wifi in the Evo doesn't work, while
an external usb stick does.
Assuming that your internal wifi is properly configured and functional, it is
incapable of picking up your home wifi signal, though it might be functional in other situations ... Buying an external usb stick gives you a better antenna position and takes nothing away from your system, while adding functionality and sheilding the innards of your system from viral
attack as a first line of attack that is detachable.
Buy the USB stick.
Bue
2answers
Problem in wireless network
what exactly are you connecting too,
Axis Point ???,Wireless Device ???,Wireless Network???
Make and model thanks.
This will help better understand your problem thanks
I have been using Netgear for approximately 6 months. Two weeks ago, all Internet Service was stopped for both my HP Windows Vista desktop and Acer Aspire 9300 Windows XP laptop. Think either Net Gear or...
Try to use your laptop in the other wifi connection if it's work the problem is your router wifi configuration. But if cannot work try to check in device manager if your wifi device is working properly. in the RUN type DEVMGMT.MSC and look for your wifi device there if there is a ? mark it's mean that there is a complex configuration in the wifi. remove the wifi device in restart your computer the windows automatic detect the device in install it. try to connect if it is work but if still not work check for the ip and gateway configuration in the wifi setup.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
