Question about HP Pavilion DV4000 15.4" LCD LEFT AND RIGHT HINGE SUPPORTER - 403921-001 (403921002) CD-ROM Drive
Replace hinges on a HP dv4000 laptop
I removed all the screws on the bottom of my laptop but can not remove the back cover ot gain access to the base of the hinges.
    Problem Solver:
  • 5 Answers
Don't worry. HP have a repair manual. You can see the manual firstly.
h10032.www1.hp.com/ctg/Manual/c00530488.pdf
Hope this can help U
Posted on Aug 18, 2009
Removing back cover of hp dv 6915nr
Back Cover?
1) Display Cover: The plastic cover that is on the opposite side of the LCD screen. Sometimes referred to as Top Cover.
Display Assembly is removed from laptop first, then LCD screen assembly is removed from the Display Cover.
2) Base Enclosure: The plastic bottom part of the notebook.
A laptop is disassembled from the Top down to the Bottom.
The bottom 'cover' (Base Enclosure) is not removed first. It is last.
3) There is no back cover per se. Half of the cover for the back (Bottom half) is part of the Base Enclosure. The top half is part of the Palm Rest.
(The back has the Vent in it)
http://www.insidemylaptop.com/remove-replace-lcd-screen-inverter-hp-pavilion-dv6000-laptop/
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-compaqhp
[Use the dv6700 service manual. Go down to the subheading HP Pavilion dm1 (dm1 is in blue)
Scroll to the right, click on dv6700. Note that it is a PDF file, and may take up to 30 seconds, before you see the first page come up ]
What is it you are trying to do? What hardware component are you trying to access?
Post back in a Comment.
Regards,
joecoolvette
Display assembly is removed. Palm Rest Cover is removed, and so on.
Jan 14, 2012 | HP Pavilion dv6915nr Notebook
Howto change a belt
Remove the top or bottom cover of the power nozzle/base of the vacuum. The screws will be on either the top or bottom of the base. Remove these screws to gain access to the brushroll. Remove the brushroll and attach your belt then putting the belt around the brushroll and using the brushroll to stretch the belt into place. Replace the top and bottom cover.
Jan 10, 2012 | Vacuums
How do i change the hinge on thhe refrigerator door? Thanks for your help!
Unplug the refrigerator and remove all food and utility bins from the doors. With the door open, remove the grille from the bottom of the refrigerator. Close the door.
Step 2
Remove the cover from the top hinge with the putty knife. Remove the three screws underneath, then remove the hinge. Take off the freezer door.
Step 3
Remove the three screws from the center hinge, then remove the hinge. Take off the refrigerator door.
Step 4
Remove the two screws from the bottom hinge, then remove the hinge. Replace with the new hinge and insert the two screws.
Step 5
Seat the refrigerator door on the bottom hinge and close the door. Fasten the new center hinge with the three old screws.
Step 6
Seat the freezer door on the center hinge and close the door. Fasten the top hinge and replace the top hinge cover.
Step 7
Replace the base grille, and plug the refrigerator back in.
Good luck in solving the problem with the solutions provided....
Aug 03, 2010 | Sanyo SR-4910M Compact Refrigerator
Best way to removed driver side door
I have a 1994 Grand Caravan and have done this several times.
1. Disconnect Negative side of Battery.
2. Remove all screws.
a. There are screw covers to remove first before
gaining access to the screws. I use a pick
driver.
b. One in recess of the door arm rest. Round
Cover.
c. One is behind the door latch release. Pull/Hold
open to gain access. Then remove the cover
d. Two are located on the Map pocket. Round
Covers.
e. One is located up near the side mirror.
f. One is located on the upper portion on the door
handle. It has a square cover.
3. Pry up and out the window/mirror adjustment cover and unplug the connection.
4. Use a wide flat screw driver to carefully pry on the bottom then side edges of the trim panel to "pop" the retainers out of the door.
5. Once all retainers have been freed: Lift up the door trim up off the upper ledge.
6. Peel back (but do not entirely remove) the rubber/plastic watershield cover.
7. Disconnect all wire connections to the door trim.
8. Pry off the plastic retaining clip to the door handle metal bar and remove the "L" bar out of the plastic connector.
9. Set the Trim Panel off to the side.
10. Remove all wire holders from the door.
11. Move the wires inside and towards the front lower access hole.
12. Peel back the rubber wire guard between the door and the A-pillar frame.
13. Pull out as much wire as possible out of the door and let hang..
14. While someone else is supporting the door: (If no one can help: with the door fully open: use a jack and block of wood to support the bottom outer edge of the door
a. I use a Breaker Bar or long Wrench
Extention and Hammer or Mallet.
b. Tap Up the Bottom Hinge Pin first.
c. I also use a flat Screw to tap up the Pin Head.
d. Remove the Bottom Door Hinge Pin.
e. Remove the Upper Hinge Pin the same way.
f. Make sure the Door is being held in place.
15. Remove any left over wires out from the door.
16. Carefully move the door away from the hinges.
Good Luck!!
If you have not replaced the Hinge Pins, and Guides, now would be a good time to do it!!
Nov 14, 2009 | 1994 Dodge Caravan
Left hinge busted
Dunt open and close lcd too muh otherwise it will damge your lcd cover and lcd bezel than it will cost u more. Remove all lcd screw cap and remove screws than slowly pull out lcd bezel and check is really hinges is gone or screw is loose. For Key u have to check it that any of latch of behind key is broken or fine. If its fine than just put that parallel to other keys and press it. it will seat back on jumper.
Jul 28, 2009 | HP Pavilion dv4000 Notebook
Removing the LCD from a Compaq CQ60-215DX
I have a CQ60-220US HP Compaq and access to the LCD screen was different than others I have disassembled and replaced the display. The bezel is snapped on, the lid does not lay back flat to access the two hinge screws, but there are 2 screws with rubber covers down by the hinges, not all the way around.
I used a right angle phillips screw driver and was able to remove the bottom screws, popped off the bezel the remainder of the way around the screen, it is different, but don't be fooled there are a few screws just not the amount you might be used to, and then gaining access to one of the hinge screws on each side can be an issue as the lid did not lay back flat, but with a good right angle screw driver you can get it done, I did. I am not sure if the proper method is to not just remove the entire top cover and hinges, but the right angle screw driver and finding that this model had only a couple bezel screws made it much easier to tackle.
Jun 16, 2009 | Compaq CQ60-215DX Notebook
Tightening HP Pavilion DV9000 17'' LCD Hinges
you may find the hinges parts from eBay which is cheaper price:
http://shop.ebay.ca/?_from=R40&_trksid=m38&_nkw=HP+Pavilion+DV9000+hinges&_sacat=See-All-Categories
how to replace your laptop hinges:
1) take out the screws at back of laptop under the hinges base
2) or take out the screw at side of laptop near the hinges base (if you find any screw there)
3) there are two cables connect between LCD lid and laptop base
you do not need disconnect those canbles. just careful them
4) take out all scews on the front of lid cover( the scews is covered by thin plastic cover), then take away front lid cover.
5) take out the screws at beside hinge base and side of LCD panel(2-4 scews at one side), you need check the back of lid cover can separate to LCD panel a little., be care replace only one at one time .
6) put back all screws step by step.
hope help you fix it, please take a rating let me know how much you are helped, thanks! any question please let me know!
May 18, 2009 | HP Pavilion dv6000z Notebook
Need to remove case from HP Pavilion dv-7 notebook. Case is cracked. I have a new one, but can't figure out how to get the old one off.
You need to remove the battery, the hard disk and the covers. Then remove screws at the bottom to release the keyboard and the upper casing.
Follow detailed instructions on pdf for dv4000 here , the procedure is the same : Service Guide HP Pavilion dv4000 Notebook PC Compaq Presario V4000 Notebook
Apr 01, 2009 | HP Pavilion dv7-1132nr Notebook PC
HP Compaq nx9010 CD drive replacement
You are correct.
The screws for the dvd drive is under the keyboard.
there should be 2 tabs one above the f4 and the other above f12 take a regular head screw driver put it where those tabs are and gently pull down towards the touchpad and the keyboard should come up easily.
Now under that keyboard in the center you will see a opening and inside that opening you will see 1 philip head screw remove that by turning counter clockwise.
Right below where you removed that screw you will see another opening which has another philps head screw in it.
Remove that screw counter clockwise and the dvd rom should pull straight out with ease.
To put it back together just reverse the steps.
If you need further assistance do not hesitate to ask.
Dec 03, 2008 | HP Compaq Business Notebook NX9010
Compaq Presario Laptop (M2000 series) hinge
Hello Wendy names Nick and just done hinge work on the Presario V5000z and readin up on your problem my suggestion would be lookin on ebay or various sites for the hinge then go about replacing it.
Steps involved in replacing the hinge start with removing power and battery
Next come the more difficult step, removing all the screws fron the bottom of the unit (this is done to gain access to the wireless cables which run from the wifi card to the lcd display)
once the base is removed then you carefully use a flat head screw driver an near the top row of keys (while pressing a few of them down) you will see a few notches which you can pry off the top cover giving you access to the lcd screen connector and bracket anchoring screws.
hopefully you disconnected your wireless antenna leads by now, and also disconnected the lcd cable from the board.
now you have the lcd display free from the base, now to change the hinge.
under the lil rubber circle pads are screws holding the brazel to the front of the lcd, this should be removed to get access to the lcd itself and thus the hinge brackets.
remove replace carefully i might add. then do everything in reverse to get the system reassembled and there ya have it
hinge has been replaced
P.S. careful steps should always be taken to prevent shock damage to any computer system when working on internals, also mind bending and pincing cables since they can most times be easilly damaged
Aug 18, 2008 | HP Compaq Presario V5000Z Notebook
Computers & Internet Logo
253 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
