Question about GE GSS20IEP Side by Side Refrigerator
Compressor does not cut off.
This happened after it was repaired from a burnt live cable that goes into the thermoswitch.
on repair it was suplied with a new solid state relay and a ....
  • bob collins
    bob collins May 11, 2010
    You noticed that too huh!
  • Danny Clark
    Danny Clark May 11, 2010
    and a....????
My freidge compressor runs continiously without stopping making a slightly higher hizzing noise.
Posted on Jan 21, 2009
I have a maytag side by side refrigerator freezer with a Embarco EGY 100 HLP compressor
Probably not. Sounds like compressor would have to be replaced. It's an expensive repair. It would depend on age if unit
Oct 12, 2017 | Maytag Refrigerators
My air conditioning compressor doesnt cut off that resulted to burn my compressor
There is a sensor, typically in the dash, that engages and disengages the clutch on the compressor. If this sensor goes out several things could happen, compressor never shuts off or it never turns on, or as happened when I had problems it kept shutting off the compressor and the car would not cool off. This has to be repaired by a shop. Or you do like my brother did and put a toggle switch on it and turn it on and off as you want.
Jan 06, 2013 | 2004 Mazda Tribute
Compressor runs but the air bleeds out think it might be stuck reed
If your compressor reaches the cut-out pressure (or very close) , most likely not reed valves. Usually air leaking when compressor is shut off is result of leaking check valve at the tank. Look for brass valve and remove. Somtimes the valve is repairable if debris is keeping valve open. Clean or replace as needed.
Oct 21, 2011 | Porter Cable C2002 150 Psi 6 Gal...
Porter cable 135 psi 6 Gal model no. d27420 (homedepot) motor fried ! Can't find replacement, and if i do is it worth fixing? Looks like parts cost as much as compressor
These units are disposable so if the motor is gone, it is garbage. I would try a power tool repair center to see if they have any used motors to repair your unit. Save the tank and use it as a slave unit for a new compressor. This way you will have more volume and the compressor will run less overall making the new unit last longer. If you burnt the motor out on this one, consider buying a larger unit the next time. Hope this helps.
Mar 21, 2011 | Porter Cable C2002 150 Psi 6 Gal...
How to repair HP 1702 lcd monitor with broken VGA cable
u can cut 15pin vga socket and u can replace with new
Jan 22, 2011 | HP L1702 17" LCD Monitor
The compressor goes to start then cuts out
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. The relay is a small usually black cube shaped electrical part plugged into the compressor or wired to it nearby. It may appear burnt or rattle when shaken if it's bad. The two connections should show continuity with an amp meter. If it's good then it's most likely the compressor causing the problem.
Dec 29, 2010 | Refrigerators
Compressor doesn`t stop and only goes to 60 pounds
Your compressor goes on and off based on the pressure. If it only goes to 60 # and no more, I would say it is worn out. The rings most likely. It can be repaired ... but before you go get the parts, consider that if the rings are worn, so too is the rest of the machine ... Consider the price and time to repair your machine and compare to a new machine before you get started.
Nov 01, 2010 | Porter Cable C2002 150 Psi 6 Gal...
Burnt up the compression ring and would like to replace it with l
Years ago a felt hat was used to make repairs, little strips were cut off and inserted behind the rings.
Feb 05, 2010 | Coleman Powermate 27 Gallon Air Compressor
Electical module to compresser burnt out
That is the compressor start relay and klixon. This happens most of the time when a unit os several years old due to the contacs on the relay and klixon getting loose from heat which causes more heat and then results in a failure. It can also happen when the compressor itself fails to start due to a failure of the compressor. The Klixon is a tthermal protector that controls a start winding period It heats up and then opens the circuit if the compressor does not start.
You did not mention any symptoms prior to your discovering the burnt electrical module so I am assuming there were none visible inside or out.
It is worth the effort to have this checked out by a qualified repairman. Many times it is as simple as replacing the start realy and klixon (interlocked as an assy when installed) Other than the service call and labor the parts required to attemot repair of this unit are less than $50.00. Once again it is worth an initial attempt at repair if the unit is less than 8 years old.
Jan 04, 2010 | GALAXY Microsystems 25.4 cu. ft....
Doesnt turn on anymore.
Hi..there,
It's seems your backlight inverter is burnt out... need to be replaced with a new one or you can repaired yourself by testing all the capacitors to see which it has been burnt out or has a leaked. After that just replaced the bad caps... Good lucks, Have nice a day!
Aug 16, 2008 | Fuji FP-988D 19" Flat Panel LCD Monitor
GE GSS20IEP Side by Side Refrigerator Logo
43 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
