Question about Toshiba e-Studio163 Copier
TRAY SELECTION We are using toshiba e-studio 163, we are selecting casset 1 for A4 size printing but it goes to bypass casset instead of casset1 kindly send your solution
  • Mohd. Tareq
    Mohd. Tareq May 11, 2010
    I couldn't get your issue...please tell me where are you facing the problem....Printer Properties>Printing Preference>Paper Quality? put that as automatically select....further please comment
  • didi2005 May 11, 2010
    What is the default paper size for drawer 1 & bypass ?
I cant using bypass tray for printing. I set A4 for paper size to every places. But it tells the papersize is mismatch?
Posted on Sep 12, 2010
Bypass feed
this is set by the computers driver
or its detecting no paper in the main drawers
Jan 10, 2015 | Toshiba e-Studio 350 Copier
Special paper tray is empty error
Sounds like someone requested A4 size paper in a print job instead of the normal Letter size paper...
Try putting regular letter size paper in the bypass tray and then set it up as A4 size...the print job should then print out on that paper.
Apr 09, 2014 | Xerox WorkCentre C2424DN All-In-One Laser...
How do I get the printer to print automatically using the bypass tray
you can set the bypass tray the size you want then set paper size setting in the printer driver at your PC.
Hold down the [PAPER SIZE ENTER] key more than 5 seconds to
set the selected paper size.
The currently selected paper feed location indicator will blink and the
corresponding paper size (which is currently set) indicator will light
steadily.
All other indicators will go out.
If the machine has two paper trays, use the [TRAY SELECT] key to
select the paper tray for which you wish to change the paper size
setting.
Each time the [TRAY SELECT] key is pressed, a paper tray will be
indicated with a blinking paper feed location indicator.
Use the [ORIGINAL SIZE ENTER] key to select the paper size you want to set.
The indicator of the selected paper size lights up.
Press the [START] key and then the [PAPER SIZE ENTER] key.
To change the paper size setting of another tray, repeat steps
after pressing the [START] key
Make sure that the tray's paper size setting is the same as the tray's
paper size setting in the printer driver. For example, if the tray's paper
size setting is A4R (LT-R), set "Setting Paper Size" to "A4-R".
Jul 01, 2011 | Toshiba E-Studio 161 Copier
Hello sir, how to take print on A4 page? please help me
Hi The A4 paper size is an internationally used paper format. Although not often used in America, it is by far the most commonly and widely circulated paper size. At 8 1/4 inches by 11 3/4 inches, it is similar though not quite identical to the American standard U.S. letter size, which is 8 1/2 inches by 11 inches. Because of its ubiquity, all printers and programs have the ability to handle the size, and getting a printer to print to it is a matter of adjusting the settings.Put the A4 sized paper into the automatic feeder in the printer. You may have to adjust the tray guides to fit the paper in snugly. Close the tray firmly when finished.
  • Step 2.Set the printer to register the A4 sized paper inside the the tray. This varies from printer to printer but generally involves going into the print menu, scrolling to the automatic feeder and designating the tray as an A4 tray.Step 3.Select "File" and then "Page setup" in the program you are using.Step 4.lick on the drop down menumag-glass_10x10.gif next to paper size and choose "A4.Step 5.Select "File" and then "Print." Click the "Print Summary" button to ensure the file is set to print to the A4 size.
  • Step 6.Press "Print" to print the photograph.
  • Jul 31, 2010 | Toshiba e-Studio163 Copier
    Print enevolopes
    You are correct. There are no settings listed for envelopes at the Toshiba Interactive Tutorial.
    Mar 29, 2010 | Toshiba E-Studio 3511 Color Copier
    E-Studio 3511 will not print a3
    check to make sure on the display panel the paper tray is showing A3 PAPER SIZE>> the paper size indication should match up to what is in the trays if not the machine will be asking for A3. Also try putting in another tray to see if there is a fault with the paper tray .. if it works with other paper sizes it may just be the size hasnt been set properly for that tray.. Hope this helps A
    Jan 18, 2010 | Toshiba E-Studio 3511 Color Copier
    Change default tray for E-studio 520
    go to Control panel, select printers and faxes (windows XP),then select es520,right click properties, select Tab advanced,then you should click on printing defaults. then will open toshiba driver defaults,go to paper handling tab. THERE IS option called "destination" and there you can chose exit tray (inner,tray1,tray2...etc). After selection you must click apply and then ok. and that it. every time after that documents will be printed out to selected tray.
    Jul 25, 2008 | Toshiba COPIERS E-STUDIO 520 Copier
    Ricoh CL3100N
    Have you setup for double-sided printing?
    Jul 15, 2008 | Ricoh Aficio CL3500N Laser Printer
    E Studio163 - Printing - "No cassette with paper of size requested is available"
    after changed one of the sensors ,the same problem-"no cassette with paper of the sieze requested is available" has happened,alway paper jam.
    any ideas why?
    machine:e studio0259
    Aug 27, 2007 | Toshiba e-Studio163 Copier
    Toshiba e-Studio163 Copier Logo
    565 people viewed this question
    Top Toshiba Office Equipment & Supplies Experts
    didi2005
    jasbo
    jasbo
    Branko Djurdjevic
    Branko Djurdjevic
    Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
