Question about Coby DVD-588
Wrong region keeps telling wrong region although its say it can play region 2
    Sergeant:
  • 366 Answers
Check with another dvd you know the region.
check same dvd on another (not region 2) player and see if itsn't working.
find if you have to follow special instruction to activate the "all region"feature.
find on line instructions do remove the region lock.
confirm make /model/ sn where you bought it and I can help to find instruction.
Posted on Jan 14, 2009
  • Pat Batta
    Pat Batta Jan 17, 2009
    thank you for telling how do you fixed this issue.
  • Pat Batta
    Pat Batta Mar 16, 2009
    I'm zafraid you didn't fixed the issue bcause you don't know what you R talking abolut.
DVD says wrong region ?
hi Nigel.
Region codes prevent playback of DVDs in other geographical regions. If you receive a region error while playing a DVD with RealTimes, this means that the region code of the DVD does not match the region code of the DVD drive. ... You can play Region 2DVDs only on a DVD drive that is set for Region 2.
Region errors when playing DVDs with RealPlayer - SUPPORT
https://customer.real.com/.../204041263-Region-errors-when-playing-DVDs-with-RealPl...
How do you change the region on a DVD?Click Performance and Maintenance, and then click System. On the Hardware tab, click Device Manager. The DVD Region tab might not be available for all DVD drives. To configure your DVD drive to play discs from other regions, select a geographic area from the list of regions.
(you could try this link but what ever it tells you to do you do so at your own risk.)
Make Your DVD Player Region Free in Seconds
Nov 18, 2017 | Televison & Video
SET UP GUIDE
I am sorry to say that there is no way for you to get into the region selection menu once you have changed your region once . The only people who can fix/change this for you are the folks at Hitachi. It's a pity that you changed your region from all to 2...I always prefer all regions...
Dec 25, 2007 | Audio Players & Recorders
Can't play dvd--wrong region
Commercial DVDs are released with region codes that restricts in which part of the world they can be played. Consumer DVD players sold in those regions are pre-configured with the correct region code for the given sales area. The United States, Canada, Bermuda, and U.S. territories are region 1. Europe (except Russia, Ukraine, and Belarus), The Middle East, Egypt, Japan, South Africa, Swaziland, Lesotho, Greenland and region 2.
sources:
http://forums.techguy.org/miscellaneous-tech/972005-dvd-wont-play.html
Jul 20, 2012 | Samsung Televison & Video
I have a dvd from England and my old Sony DVP-C670D keeps giving me a prohibited message4 every time i try to play it. How do i unblock the region code.
Although no guarantee, this 'region hack' is rumoured to work:
1. Place the DVD player into 'standby' mode.
2. Using the Sony remote, press the following button sequence: Title; Clear; Power (green button); 0 (zero button)
3. Using the remote, Open the disc tray, then close again.
Now insert your disc and attempt to play - allow up to 2mins to load/play. If no response, open/close tray and try playing disc again.
Cheers,
Jun 22, 2011 | Sony DVP-C670D
I have just bought a Toshiba SD590EKB dvd player and it will not play certain discs, it keeps on saying wrong regional code. How can I solve this problem?
Check the back of the dvd player and it will have a small sticker with a small picture of a globe (or earth) and it will have a number being one through to six, this will determine what region discs you can play in you machine. Ill list the regions and their codes, i hope this helps.
Region 1 - The U.S., U.S. territories and Canada.
Region 2 - Europe*, Japan, Middle East, Egypt, South Africa, Greenland.
Region 3 - Taiwan, Korea, the Philippines, Indonesia, Hong Kong .
Region 4 - Mexico, South America, Central America, Australia, New Zealand, Pacific. Islands, Caribbean
Region 5 - Russia (former USSR), Eastern Europe, India, most of Africa, North Korea, Mongolia
Region 6 - China
Good luck.
Nov 25, 2009 | Televison & Video
Samsung H1080R plays wrong region
Same problem, no support from Samsung Netherlands.
No solution yet, sorry
Nov 12, 2009 | Samsung DVD-H1080R DVD Player
Trying to play dvd but says wrong region soneynhv-dx350ab?
Hi, if its saying wrong region. then either your player or disk is incompatable. region 1 ntsc ( USA ) Region 2 ( UK ) et,c. check your players region coding is compatable for your country, and that you are also playing a dvd with the same region coding as the player. alternatively is to try and find a region free or multi-region solution. Mike @ Compurepair.
Jun 12, 2009 | LG RC897T DVD Recorder/VCR Combo
WRONG REGION on the screen
Have you checked the region in your Disc Properties? Go into Disk Management, find your dvd and right click on it. Go into the properties and you will see a heading for Regions. In there it explains a bit about regions, which should be at 2. If it is not, then change it to 2. Let me know if this doesn't help.
Feb 02, 2009 | Philips Phillips 16X External DVD 2XRW...
DVD Player region coding changes
You can only change the region code 4 times then it locks on the last change.
There are some firmware upgrades that can change the drive to region free, if you can screw it up or put in the wrong frmware upgrade then the DVD drive will be a piece on junk.
I suggest you install a region free software that will allow you to play and region DVDs.
Go to www.dvdidle.com to get their Region-Free software, it is not very expensive.
Nov 17, 2008 | HP Pavilion dv9000z Notebook
Ps3 region code
Although the PS3 itself is not region locked, PS2 games are and unfortunately the region lock will still be enforced. No idea what 'lennox' may be (Linux?), but there's no way you can play that game on your PS3 I'm afraid.
Sep 25, 2007 | Sony Playstation 3 (PS3) Console
Coby DVD-588 Logo
207 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
