Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Hoover SpinScrub50 F5915-905 ulphostery hose won't squirt? Right out of the box!
I had Hoover tech suppoort on the line for over an hour. Tried this: Verify hose attachment to front of water recovery box. Verify that cover on recovery box is well seated/sealed all around (did this 3 times). Verify that trigger orifice is no plugged up by blowing through it..Verified that liquid hose prongs are clipped firmly. In my view, the unit is not pumping water.. When they had me lower the hose, without the trigger, into a bowl, where the bowl was lower than the clean water tank, liquid flowed out of the hose no problem. How does the unit pump water? Other suggestions, please?
    Top Expert:
  • Hoover Master
  • 43,113 Answers
Replace it under warranty as factory defective.
Posted on Apr 20, 2017
5 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: hoover steam-vac model #F7458-900 "All-Terrain"
Check the valves at the bottom of the tank(43513026)also check for cracks in the tank(42272104). Another thing to check is the handle asm. is a rod that pushs on the resevoir asm(tanks sits on) to make sure that it is stuck in the on position. Depressing the trigger and watching, you should be able to see if it is moving up and down ok.
Posted on Feb 14, 2008
SOURCE: recovery tank not working
recovery tank empty where do you look to see where the hair ball is so i can clean it
Posted on Apr 04, 2009
VacuumRepair
  • 438 Answers
SOURCE: My Hoover Steam Vac Spin Scrub aw/ Clean Surge
Greetings,
A few more things that you can try on your SteamVac. First remove the dirty water solution tank from the machine completely. You should see where the solution tank was just sitting, a plastic casing with a whole in it. This is actually where the suction from the motor goes into. Turn the machine on and feel the hole there for any suction coming out. Did you feel suction coming from the hole? If yes, then your issue is going to be something with the dirty solution tank, because without the tank it's sucking fine. If you didn't feel any suction from this hole, it may indicate that there is something more serious that needs to be taken care of.
One other place you may look on your machine (as long as the upholstery hose for stairs and furniture is already attached to the machine, and you don't have to hook anything up to the dirty water tank to use the attachments) while the dirty solution tank is out of it, is where the attachment hose makes connection with the vacuum. If you recline the handle down while you have the dirty water tank out, look in the back of the handle housing for a hose that enters the housing 3/4 down the housing. Now follow the hose on the inside of the handle not the outside, follow it up to the point where it goes into the neck, near where the suction hole is. Right at the end of the hose, right before the hose cuff, is this ripped, or damaged here?
Please feel free to request a clarification to this repair if you still need addtional help. If you can leave me the model number exactly that would help me help you, lol. I hope that this was helpful to you. If this was helpful to you, may you please click the helpful Thumbs Up Icon in the lower right hand corner of this repair?
Thank you so much,
Chris J.
Posted on Mar 21, 2010
  • 405 Answers
SOURCE: Have this F7425-900. The pressure pump
HI.What seems to be the problem? Was it. Thge motor won't rotate in order to pump water.Does it means that when you turned it ON,all the switches work aside from the Motor.Is that what you mean?
Posted on Jul 26, 2011
I had my hoover steamvac pinscrub fo 6 weeks an now the motor won't turn n or anything?
look around for a small rese button it may have nearby somewhere
near the motor itself . It may need to be reset again
Aug 31, 2014 | Vacuums
I just bought a hoover steam vac model F5914900 and the clean water tank is leaking. I tried pressing the clean surge button and the trigger button that was suggested by someone else but it won't
Go to Hoover.com and find a local Service Station. They will replace it at no charge. MUST be a warranty location to get it free. Take your sales slip with you.
Jul 28, 2012 | Hoover SteamVac F5914-900 SpinScrub...
Soap leaks thru handle
It sounds like a hose or water line has come loose.
Jul 05, 2012 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover S3765
If you light and nozzle motor both go off at the same time, you might have a bad power cord. Mine had this problem which I could verify by jiggling/twisting the cord near the strain relief on the nozzle. It would go on and off as I did this. The cord is cheap to replace, around $13 for the part shipped. Part number is 59134072.
May 30, 2012 | Hoover S3765-040 WindTunnel Bagless...
Hoover Model SH80520 starts and won't quit
that's how it's supposed to operate, switch on turns the unit on. switch off turns the unit off. thier is a wire that is connected to the leads on each outlet that turns the unit on when the hose is inserted and the switch is in the off position.
Mar 30, 2012 | Vacuums
I need to replace my hose to my steamvac model F5842 can you help? Ordered a hose but I don't think it's the right one
Hi Chris,
Your Hoover SteamVac model F5842 needs the Hoover SteamVac replacement hose part number 40309007. You may find a link to the correct hose for your model below on our website:
Hoover SteamVac F5842 Replacement Hose Assembly
In terms of replacing the hose, this is an older style SteamVac, which attaches the hose to the front of the Dirty Water Solution Tank.
Here is are instructions on how to attach the hose to your machine:
http://www.fixya.com/support/t4699742-dont_manual_u_connect_hose
Hopefully this was helpful, and answered your question. Please don't hesitate to request a clarification, or add a comment if you have any further questions or concerns.
Thanks,
Chris Jones
Oct 07, 2011 | Vacuums
THE STAIR HANDLE WILL NOT SQUIRT WATER AND/CLEANING SOLUTION
The hose or nozzle could be plugged. The hose can be disconnected at the machine end there is a clip on the bottom of the connection. The fluid is dispensed by a pump which could be bad. If you disconnect the hose and put a rag at the opening to catch the fluid, then turn the machine on briefly the fluid should squirt out if the pump is working.
Nov 12, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
