Question about Sharp R-1480 Microwave Oven
Vibration sound everything works and heats but has a loud vibrating sound with carousel in and out of microwave.
  • Sharp Master
  • 5,568 Answers
There are two possible sources; the fan, which may have a loose sleeve bearing (fan must be replaced), or a transformer with loose laminations. The latter is a rare occurrance since most transformers are 'potted' or treated with epoxy resin.
After pulling the plug, the housing will be fairly easy to remove with a half-dozen or so screws around the edge of the back panel.
If the fan is then accessible, you could block the blades with any insultating material and briefly turn the unit on. Keep fingers clear of ANY part inside; danger of electrocution. If the vibration is missing, then the fan is at fault.
Posted on Jan 26, 2009
I have a "continuous" humming sounding when units are heating. The sound is very loud
The humming sound that occurs may be similar to the annoying buzzing my GE microwave produces at random. It could be mechanical vibration. Doesn't seem to affect cooking.
Nov 16, 2016 | Microwave Ovens
Jvm1790sk01 GE Microwave Broken - Manufactured Aug 2005. Working fine until tonight. Loud vibrating humming sound coming from Right Side and Burning Odor... No heating on high power. Just burning odor. ...
Sounds like you Magnetron has failed. The only way to repair this is to replace the part. Some microwaves have an extended warranty on this part. Check your manual and Call GE for service if it does. If the warranty has expired you might as well buy a new microwave unless you are very attached to this one. Hope this helps
Sep 01, 2011 | Microwave Ovens
Is it time to replace the microwave if it makes a loud vibrating sound followed by a pop which is followed by the sound of broken glass?
Yes it is time to replace it, the magnetron has failed and there are two more parts of concern, the high voltage capacitor and diode are also a factor. The high voltage capacitor and diode work with the magnetron to produce the high voltage that heats the food. The vibrating sound is further evidence the magnetron is culprit.
Feb 10, 2011 | Kenmore 69399 Microwave Oven
Purchased microwave in 2005, just stopped heating and now its making a loud noise
if the loud noise is like a vibrating noise then it sounds like the high voltage diode.
Mar 23, 2010 | Kenmore 63252 Microwave Oven
Vibration
Need a new magnetron
Sep 03, 2009 | Samsung MC5694 Microwave Oven
Loud pop and microwave doesn't heat anymore
I have a GE Profile Spacemaker model JVM3670WF001, purchased I think in 2003. Pop sound, no Heat. Light goes on, carousel goes around,
Repair or new microwave
Jun 03, 2009 | GE Profile Spacemaker Over-the-Range...
Dacor DMT2420s when started makes a loud buzzing sound
The fan could have an obstuction. I have heard of tech sheets getting into the fan and causing a vibration and vibrating sound.
May 12, 2009 | Dacor DMT2420SS Microwave Oven
Microwave does'nt heat up everything else works,just don't heat up
WHAT IS WRONG WITH YOUR MICROWAVE?
small_6_37.jpg For a detailed Microwave illustration, click below.
redarrow.gif Counter top
redarrow.gif Built in
Danger! You can receive a serious electrical shock from the components inside your microwave oven--even when it's unplugged. Only a qualified appliance repair technician should perform any repair.
It doesn't work at all
It sounds normal, but there's no heat
I can't adjust the power level
The carousel won't turn
I have intermittent cooking problems
The display flickers
There's no heat, but it buzzes loudly
It quit after I slammed the door
It looks like there's lightning (arcing) inside my microwave
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 10, 2008 | Panasonic NN-S541 Microwave Oven
Microwave made a loud pop,won't heat,sounds like it's only on half power, makes a low intermittent hum
This is almost certainly a blown high voltage diode.
Please reply back with your brand and model number so we can help you.
May 31, 2008 | Microwave Ovens
Vibrating noise when cooking
In order to try to set your mind at ease I will have to explain the Basics on how a Microwave Oven Functions.
When a Microwave Oven is set to COOK ...START. It cooks at 100%. There is no lowering of the heat as with a Range ( Cook Top) Control. So in order to do the other things such as DEFROST, WARM, or anything other than 100% COOK. A COOK ON- COOK OFF system was utilized. To DEFROST, the Microve COOKS at 100% for 30% of the TIME, then IDLES for 70% of the TIME. COOK ON 30% of the TIME, COOK OFF 70% of the TIME = DEFROST This is why you can hear the CYCLE. More power is required during the ON CYCLE, thus the lower vibration. The Vibration occurs when the High Voltage Transformer is turned ON ( COOK ON).
The VIBRATION seems to have got louder with age. This is somewhat normal as there is a vibration from the High Voltage Transformer present every time the Microwave is used. screws and other metal parts seem to get loose with this vibration. There is no solution, unless you can tighten EVERY screw, nut, and bolt in the unit.
Sorry!
Dec 07, 2007 | Kenmore 62642 / 62644 / 62649 Microwave...
Sharp R-1480 Microwave Oven Logo
278 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
