Bush btv180t- connections
Would it be possible to connect my bush 180t tv/video combi set ,to the sky digibox downstairs?
I have just purchased a tv link /magic eye and a length of coax.
thanx
Hi ,
Thanx for the reply.
managed to sort it second time around.
Just ran the coax from the rf socket downstairs to the back of the tv link ,which is attatched into the ariel socket in the back of upstairs tv.
the tv link comes with good instructions,but need reading carefully first.
Posted on Jan 20, 2009
Wil my tv work with out remote
There are quite a few ways to connect cable box, DVD, receiver and TV together. At a minimum---Connections between DVD and a/v receiver: For Audio, either digital coaxial, digital optical or simple RCA (CABLE ONE); If you did not use RCA you need to connect Video with either component or s-video (CABLE TWO). For connection between a/v receiver and TV: either component, s-video or RCA (CABLE THREE) You did not mention how your cable (or sattelite) box is connected. You could use same set-up as between DVD and a/v receiver for another one or two cables depending on set-up used.connecting the speaker wires of an RCA TV to an amplifier: The signal that is fed to the speakers is not designed to be fed to the line-level inputs of your amplifier. You'd need some kind of conversion and I can't tell you exactly what that would be.
Get some double-screened satellite cable and fit a female TV plug to it (or a male plug with an adapter). Connect it to RF Output 2 at the rear of your Digibox. Fit a TV plug to the other end and plug it into your TV.
Temporarily disconnect the aerial feed from the Digibox aerial socket. Switch the Digibox on to get a picture on your main TV. The Sky Digibox normally sends its signal out on UHF channel 68 so go to the second TV and tune it to 68 (or tune it till it finds the Sky picture).
Now plug the aerial cable back into the Digibox. If there is now interference on the Sky picture on the second TV (or on the terrestrial channels) your Sky signal on 68 is causing interference. Press [services] 401 [select]* and set the RF output to a different UHF channel number. You need to connect it via a Scart lead on your main TV in order to see the menu.
*In the new EPG (April 2009) it's [services] 001 [select]
Try each RF output channel number in turn (21 - 69) and retune the second TV until you get clean pictures on the terrestrial channels and the Sky channel. Also check the picture from the VCR (if connected).
This is just a brief overview. If you need a real in-depth explanation you should read the "Piping TV Around the House" Ebook by satcure.
Nov 22, 2011 | AOMNI Corporation Televison & Video
I've got a goodmans tvc202ts with no remote can i still tune it in and how? or can i tune it in if i set up my sky remote?
Hi, if you connect your sky box to the TV by SCART the TV will automatically switch to aux so you can watch sky that way. The same goes for DVD players, digiboxes etc, but not anything that connects with component video like my Playstation :(
May 02, 2010 | Televison & Video
We receive satelite tv through dish and digibox. We have suddenly
Try unpluging from the mains for about 2 mins,if still a problem then the LNB on the dish may be at fault
Oct 27, 2009 | Televison & Video
Equipment and Locations (Denons are physically 15ft apart) Room 1 Sky Plus Satellite Digibox; (without HDMI outlet), but with one optical, one scart-video, and two Scart outlets. Panasonic DMR-EX77EB DVD...
Hi Martin,
A wiring Schematic is not that you should be looking. What you need is large feeders to understand hot to connect to various ports to give your desired output.
Jul 03, 2009 | Denon Audio Players & Recorders
Sky+ remote codes
hi
i have here some writeups i found during surfing for your sky remote.
Not every TV is included in the code list. In fact, although it was claimed that "95 percent" of TVs could be controlled by the Digibox remote, the true figure is probably "95 percent of last year's models" and the standard remote will NOT control your Video Recorder or any other equipment.
UPDATE October 31, 2006. The latest versions of the remotes are SKY Rev.8 and SKY+ remote are Rev.6 and Sky-HD are Rev.8 (Sky-HD also operates the SKY+ Digibox and contains codes for more recent Plasma and TFT screens). Look at label inside the battery compartment. These remotes contain codes for more recent TV sets and omit codes for TV sets that are now several years old. We do not stock earlier revisions.
seems here that they may have no codes for your tv.
i will just update you if ever i find codes and ill post it here.
Jan 23, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Connecting a dvd player to a BUSH Bush BTV180T 14in TV/VCR Combi
if there is a scart connection on your bush tv then
you can use your panasonic dvd player on it, trust me
just look all over the remote carefully for an AV button, or failing that press channel up or down whilst the DVD is powered up and playing a disc and you will have solved it
hope this helps mate
Nov 05, 2007 | Bush DVD142RC 14 in. TV/DVD Combo
Digibox connection
Try looking on the links from a thread on connecting a PVR on bbc.co.uk's POV digital pages
Sep 17, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Televison & Video Logo
151 people viewed this question
Top Televison & Video Experts
Electro Med Services...
