Question about Toshiba Satellite Pro M300-S1002X Notebook
Computer not booting up
I have a toshiba M300 running vista .
now it won't boot up, only with the Vista recovery cd but it still won't boot upwithout coming up with start up repair mode .
Tried re-installing it but to no avail keeps just coming up with thr program that I am trying to repair is not compatible.
Not sure what to do next without having to re-install every thimg did not get a OS disc to do this it's only 4 months old.
Tosheiba laptop vista recovery disk won't load. I put image files on c drive try to start try to ruin tosimagex new errors
Hi! Welcome to www.fixya.com.
What you have to do is to change the boot sequence on boot option. Restart pc then hit f2 go to boot option and choose DVD/CD to be your first boot option then press f10 restart and it should load automatically. Check your recovery if its running on other pc. If not. call your manufacturer and get a new recovery disc.
Hope this resolution fix the problem on your computer. Thanks for contacting Fixya. Bye for now.
Jul 19, 2011 | Toshiba Satellite A215-S7422 Notebook
I want to undo a windows 7 upgrade and revert it to vista
If you have a recovery disk for windows Vista you can downgrade.
Follow this trouble shooting:
Boot from Disk
1. Insert the Recovery CD in to the ODD of the computer
2. Turn off the computer
3. Turn it back on and keep tapping F12 to access the boot menu
4. Once you're in the boot menu select ODD/CD/DVD and keep tapping enter until the file is loading
5. Just follow on the standard procedures of installation until it finished.
6. reboot the system
7. now ready to use...
Hope it helps you.. please rate it.
thank you.
May 12, 2010 | Toshiba Satellite L45-S7423 Notebook
Toshiba Satellite with no OS will not restore to factory with CD
go to bios settings by pressing F2 on start and choose under the boot device to first boot from cd ..this will make it choose the boot from cd first ...and get into recovery mode if this is the kinda disk you are using ..
Another thing is that many laptops came with recovery cd but this will not have a operation system on it ...in this case you have to use a operation system cd first and after that restore drivers and settings with the recovery cd ..Be sure you use the same operation system it came with ...so in this way you can use the drivers from the recovery one...if you change for example from Vista that came with ...to XP the drivers may not be on that disk if it was on vista from the manufacturer...
so ...if you do not have a bootable disk with operation system just go to pirate bay ..and download an image with the operating system you need and burn it using a program like Nero to make it bootable ...after that just run it first (boot from cd also ) and will work
Apr 17, 2010 | Toshiba Satellite M55-S135 Notebook
Vista will stop after sign-in at a blue screen. Runs in Safe Mode OK.
First open cpu cabinet refix RAM memory.
Then when you power up the computer press F8 key then enter in safe mode.
Then go to start menu then type in run "chkdsk /r"
then press "y"
then restart then it fiox error on harddisk.
Then if still same issue then you have to need recovery disk.
Boot your computer with recovery disk and then repair your vista.
For booting when you power up the computer press F1 or F2 or "del" then ente rin bios .
Then go to boot option and set first boot device as your cd or dvd rom then save settings and exit.
Then put recovery disk so it boot with disk.then follow the procedure then repair vista.
Let me know if you need more assistanse.
Thanks.
Sep 13, 2009 | E-Machines eMachines Desktop PC
How do I start to reinstall my Toshiba P300 laptop? I've had trouble with my laptop. Whenever I try to open a zip file, the computer crashes. I've had the Windows techies on and they didn't fix it so i've...
So to install HDD recovery, please do as follow:
  • Start your notebook after the bios screen press F8 to enter “Advanced boot options” (if you get the timing wrong, just restart and keep pressing F8)
  • Choose the first offered option “Repair my Computer” to enter Vista “System Recovery Options”
  • Choose the last option – Toshiba recovery option
  • Follow the menu on the screen
Please note that whole HDD will be deleted and if you have some important data please back it up
Aug 05, 2009 | Computers & Internet
Toshiba Sat A135-S2386 System recovery downloads??
i guess that the computer has installed vista ultimate and the creation of recovery cd option has gone with it. the new recovery cd will solve all your problems.
Nov 27, 2008 | Toshiba Satellite A135-S2386 Notebook
Compac deskpro Pentium 111 - 600
I'm not completely sure on what you are exactly asking here, but I'll do the best I can. If you have the Recovery CD, you need to boot from the CD and run the Recovery. When you go to do the recovery you will have two options, the normal recovery or the destructive recovery. If there is nothing important and everything can be wiped, run a destructive, but if you need everything run the other one. If you do not have a Recovery CD but have a Windows Vista disk that matches the version on your computer (IE: Windows Vista Home 32 bit is on your computer and you have a Windows Vista Home 32 bit disk) and you DO NOT need anything saved, just reinstall Windows. There is a product key for Vista on the sticker attached to your case. If you have neither, then you can probably get a new recovery disk by contacting HP (since they bought out Compaq). If you can not get a new Recovery CD, you will need to go out and buy a new copy of Windows Vista.
Feb 20, 2008 | Compaq Deskpro EN PC Desktop
Toshiba Satellite Pro M300-S1002X Notebook Logo
113 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
