Question about Kirby Heritage II Vacuum
Kirby Heritage II Vacuum Carbon Brush Placement
I had to replace the fan in our vacuum cleaner and unfortunately, before I figured out the proper disassembly procedure I removed the armature from the motor plastic housing. My question concerns the proper location of the carbon brushes in the housing in relation to the armature. Do they just "float" around the commutator or is there a proper location. Are they supposed to be loose? Also I assume that the Finger spring and washer seat in the back of the plastic housing and the end of the armature rest on it. Does the finger spring go in first and then the other washer or vice versa?
Any help would be appreciated.
Thanks,
Garry
  • 231 Answers
Yes the carbon brushes float on the commutator and are spring loaded. the spring washer goes in the housing first then the other washer. let me know if you have any other questions
Posted on Jan 03, 2010
How to remove a Kirby Heritage II Armature
The armature that holds the fan on is reverse threaded. It turns to the right to remove it. You can put a nail or nail punch in the hole on the armature and tap it gently to the right. this should loosen it enough to unscrew. There's a washer, then the fan, and a spacer that fit over the shaft.
Sep 02, 2012 | Kirby Heritage II Vacuum
Got this Heritage II Kirby vacuum that when running for about 5 minutes it will stop and smells like burning from the motor. Is the brush out needing repair or something else.
It sounds as if the carbon brushes in the motor are badly worn and will need replacement. DO NOT operate the vacuum in this condition or you may damage the motor armature beyond repair.
Jul 26, 2011 | Vacuums
Motor light comes on but motor does not start on Kirby Heritage II
Remember that the motor will not run unless the vacuum head or hose are properly installed. If this is not the problem, the most likely problem is that the carbon brushes in the motor are badly worn and will need replacement. A less likely problem is that the front safety switch is out of adjustment. While the light is on, remove the head and push the metal rod on the switch next to the fan inward to see if this causes the motor to run.
Jul 06, 2011 | Kirby Heritage II Vacuum
How do we change the belt on our Kirby Vacuum Cleaner
Here is a link to a video explaining how to change the belt on a Kirby vacuum. It is at the bottom of the page
http://www.totalvac.com/videos/kirby-vacuum-cleaners-videos.htm
Jun 02, 2010 | Kirby Heritage II Vacuum
My Kirby vacuum cleaner will only run for a few
could be caused by bad bearings in the motor or bad carbon brushes and a worn commotator on the armature. check the cord where it connects to the top of the handle on the swivelling strain relief. usually the cord fails there .
Jan 03, 2010 | Vacuums
How do you reattach the front end of a Kirby Heritage II vacuum cleaner so that the brush is engaged. ( Manual missing!)
you need to make sure the belt is on the roller correcty, make sure is at the red position when putting the part back on with the belt on the hook, push the pedal to highest (off the ground) position to ensure you put it on correctly, then turn the fixing clip thing to secure it, then once its on turn the panel around to green position, belt will be back on, once you get used to it you'll be ok,
May 08, 2009 | Kirby Heritage II Vacuum
Carbon Brushes wearing out quickly on Kirby Heritage II
4 possible reasons.
1 – one or both bearings are worn so armature (rotating part) wobbles as it is spinning and cause motor brushes to wear fast. Solution – change bearings too.
2 – Whoever replaced brushes – did not use some brush seating sticks to make cmutator smother and contour brushes to the shape of the comutator (not likely). Solution – appropriately install new set of brushes.
3 – Comutator is so warped that seating sticks do not help anymore – solution – new armature or turn the old armature.
4 – The fact that ONLY ONE brush was worn may mean that there is something wrong with the brush or housing. Maybe it could not move freely within the housing? I think this may be most likely cause it it may be a combination of all 4.Is it worth to fix? Hmm depends how much will it be. If this is 100+ - I’d say get newer Kirby for 300 ad enjoy the tech drive (Heritage does not have tech drive so it is much harder to vacuum with than the newer models)
Nov 05, 2008 | Kirby Heritage II Vacuum
Kirby heritage II
As long as it is Kirby belt - you should be fine. Make sure that the shaft is clean and that you do not vacuum something greasy or wet (grease or oil will lubricate the belt and shaft will loose the grip -heat up and burn). Make sure that brush roll spins freely.
I am assuming you know how to put the nozzle on properly (if you not sure - go here)
Good Luck
Rocky
Aug 22, 2008 | Kirby Heritage II Vacuum
Kirby Heritage 84
http://geeksquad.fixya.com/ThreadView.aspx?prdid=11562&thid=699518
Kirby Heritage 84
Posted by sixbrocks on Jun 23, 2008
I can't figure out how to get the belt engaged on my Kirby Heritage 84. There are very simple instructions on the front assembly; however, the belt doesn't engage with the rotor, and the beater bar does not spin. When I have the front twisting section on the "Belt On" setting, it seems as though it actually disengages the belt. I see no faults in any of the mechanical parts, but just can't get the belt to go on the rotor.
(I purchased this machine @ a garage sale on Saturday. It's in perfect condition.)
My vacuum cleaner is a Kirby 84 Legend.
Help! Jennifer
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You can always check your owner’s manual but the Kirby has a dial on the front of the machine and you needs to dial the belt off of the fan pulley counter clock wise and to check to see if the Kirby bell housing will release @ the top so that you can remove the bell housing. If not then remove the bottom plate and take out the brushroll on one side and then slide the belt off of the brushroll. Then you can slide the new belt onto the brushroll to the center and then re-insert the Kirby brushroll with the screw heads facing downward then you can replace the bottom plate – then use the Kirby spoon or hook to dial the belt onto the fan pulley clock wise. Once that is done then plug in the Kirby and try to vacuum to see if the Kirby is picking up properly, if not repeat the process. If you have a question, feel free to contact your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/ Customer Service – United States & Canada 1-800-494-8586
Hours 8:00 am to 5:00 pm (EST) U.S. & Canada Fax # 1 (216) 529-6146
Mail To:
Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 23, 2008 | Kirby Heritage II Vacuum
How do you use and what attachments for upholstery cleaning with the Heritage II
Generic problem for all Vacuums
How do you use and
Kirby has a spin brush that is round on the newer Kirby’s and it works on the suction from the vacuum and it fits on the end of the vacuum hose but it does not fit into corners very well or your can take some Kirby shampoo in the spray water bottle and use a kitchen scrub brush for the corners. Other wise you can use the actually Kirby Shampooer of which is very hard and unfriendly; the spin brush would be my selection. You can check with your local vacuum cleaner dealer in your area and also in the yellow pages. Also you can call the Kirby factory to see if they can direct you. The Kirby factory is listed below:
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
Apr 18, 2008 | Vacuums
Vacuums Logo
439 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
