Question about InFocus SC-MANGRY-106H MANUAL PULL DOWN
Power lose of my tv
When my dougther stand by our tv thourgh remote control, our tv dont want to open anymore she just use the remote to turn it off and now it doesn't turn on even we use the main power on
  • 50 Answers
Your tv has a problem with its power, you need a professional technician to fix it out, because the problem is inside of your tv, not in the remote control
Posted on Jan 14, 2009
Humax HDR-7500T will not power on
power adapter first control is should not give a stable dc anymore by bad capacitors. is the most most common defect by this The capacitors are enabled by continuity of day and night and thus they lose their self-healing capabilities because they are too tight tolerance
May 29, 2016 | Televison & Video
Had my samsung dlp tv repaired today. tvs fine now but the remote does not work(still works on dvd player) direct tv remote does power on tv either or control volume anymore
It sounds that the remote control should be programmed once again with TV with its setup codes. Setup codes for Samsung TV are:
0105 0077 0076 0109 0007 0009 0004 0005 0085 0172 0942 0358 0012 0015 0080 0104 0106
Check these codes, and select one which have maximum functionality with your TV.
Jun 28, 2012 | Samsung TV Remote Control
Turn stand by off without remote?
If the set is turned off to standby by its remote control, you must have its remote cotnrol to power it ON. No buttons on the front panel will work at this condition.
May 16, 2012 | Televison & Video
I need help I just won a tv but it didnt come with a remote but I have a RCA remote transmitter. Im trying to program it for the tv but I dont have the book anymore can you please help me The tv is on but...
This Web page should allow you to find the codes for any devices you want to add for this remote.http://remotefinder.rca.com/default.aspx?site=rca
Other than that there is an easy way to program this remote.
1. Turn on the device by hand. 2. Hold down the device name key.(hold the TV button to program a TV) 3. While holding down this key also hold down the power key until the red light turns off and comes back on. Then release both buttons. 4. From here hit the power button repeatedly until the device turns off. 5. Hit the stop key at the bottom. Now the remote is programmed for that device.
May 05, 2011 | Televison & Video
My remote does not control the TV. It is in the cradle to charge and when I remove it I get a message that says, "Battery level low Place remote in recharging stand to charge battery". The...
Seems the battery in the remote is shot. Could even be a lose wire inside of it as well. May need to replace remote or dare ti take it apart and see if all wires are hooked up properly
Oct 27, 2017 | Logitech Harmony 890 LCD Remote Control
My tv won't turn on anymore. The power light and the opc light blink twice at the same time and then the opc blinks once and it keeps doing that. Please help!
Hi
Make sure the AC cord is not loose or disconnected. Check to ensure the cord is firmly plugged into the outlet at one end, and firmly connected to your television at the other end. The AC cord connects to the television about midway across the back of the set, near the bottom of the back panel. The hole for the AC connection is shaped like a figure eight. Try powering up the TV with the cords firmly connected.
Check the "Main Power" to ensure it is on. Locate the button on the top of the television among the "Volume" and "Channel" buttons. Press the button to switch the television on. If the "Main Power" button is off the remote will not turn on the television. Wait to see if pressing "Main Power" will activate the TV.
Press "TV Power" on the remote control to power up the TV from stand-by mode. If the power light on the front of the television glows red when you press "TV Power" on the remote, press the "Main Power" button on top of the television to remove the TV from stand-by. If the TV is accidentally in stand-by mode it may not come on when pressing certain buttons.
Check the circuit board. If your set still won't turn on and you hear a clicking noise when you plug it in, you most likely have a defective circuit board.
Oct 23, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
RC00013 remote, channel change and power not working, how to fix?
hi,
your power button lose its contact or misplaced to its proper position. open your remote control and turn back your power button it its correct positioning. having a new one is probably the instant solution to your problem.
regards,
kaybicks
Feb 27, 2010 | One For All URC-4605 Remote Control
I have a rcr3273 universal remote. my tv is rca. i had the remote programmed before and somehow it became unprogrammed. i dont have the instructions anymore and i cant get it working
hold down tv button and power button together until the lcd light turns on. then press the play button every 5 seconds until your tv turns off. press reverse every 2 seconds until it turns back on. press stop to save the programming code.
Nov 09, 2009 | RCA Universal Remote Control
Universal remote.....
I have the code sheet... the codes for the Toshiba TV... 049, 071, 072, 105, 109, 117, 118, 160, 162, 201, 207, 232
Hold down the MAGIC key until the red led lights up, then release.
Press the TV key once
Put in the first code... then press the power to see if the TV turned off... if not, repeat.
Aug 31, 2009 | Televison & Video
I don't know how to program my remote anymore!
I had the same problem and typed in the model of my vcr instead of the remote model. This is the site I found, although my tv is not on the list, I followed the steps at the bottom of the page and found that code 08 worked for my Phillips TV. I hope this helps all of you with finding your codes and programming your remotes.
http://www.remotecodelist.com/remotes/sharp/sharp_vch982.html
Jan 14, 2008 | Sharp RRMCGA342WJSA Remote Control
Televison & Video Logo
74 people viewed this question
Top InFocus Televison & Video Experts
rostit
Are you an InFocus Televison and Video Expert? Answer questions, earn points and help others
