Question about Olympus WS-311M Digital Voice Recorder
I have an Olympus WS-311M but cant record after playing back file
The instruction manual tells how to pause a recording (press REC button) and then press again to continue the recording.But no instruction given how you replay part of the existing recording and then start recording from that point thereby deleting existing recording and replacing it with new recoding e.g. I want to playback to paragraph 3 of a recorded letter and replace this paragraph by recording a different paragraph 3. How can I do this?
    President:
  • 919 Answers
Unfortunately that is not possible with this recorder to be able to replay a part of a recording and record over it. If you pause it will just allow you to continue from the point where the device was stopped. You might want to check out the DS-2300 or the DS-2400 model recorders as those devices have the ability to do what you are asking.
Posted on Jan 14, 2009
OLYMPUS Digital voice recorder ws-311m memory is full despite all folders being deleted
I had the same problem on a WS 311 and this worked for me as well, thanks so much!
Sep 19, 2012 | Olympus WS-311M Digital Voice Recorder
I do not know how to use it, i have the manual, but i do not find it
The recorder takes 2 AAA batteries. Press Menu/Folder (on the right above the jogdial (Stop, Rewind, Fast Forward, Play)) to select the folder to add a new recorded item. (The folders are A,B,C, or S. Folder S will come up with a date and you can select another date for the recording.) Folders A, B and C can hold 100 files each; Folder S has 365 dates which can hold 15 items each.
Press and hold the Menu/Folder button for a second or longer. The Screen should show the Mode menu. Press Play and then the Fast Forward and Rewind buttons to set the recording quality. HQ is the high quality recording and will fill up the available storage on the organizer more rapidly. LP will record for the longest period.
Set the Microphone sensitivity by pressing and holding Menu/Folder. Then press the Fast Forward or Rewind button until Mic appears on the display. Then press Play and use the Fast Forward or Rewind buttons to select Low or High sensitivity. (An external mic often gives better results.)
Once you have set the folder for the next recording and the recording quality and microphone sensitivity, press Rec (center above the jogdial) to start recording. Press Stop to end the recording or Rec to pause it. (It will stop if the Pause is longer than 10 minutes.) Press Display to see how much longer you can record before using up the available storage space.
To play back a record, locate the item in the folder then press Play.
The manual for the Olympus VN-1800 is available from the Olympus support site: http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=841 . The direct link to the English version of the manual is http://www.olympusamerica.com/files/oima_cckb/VN-900_VN-1800_VN-3600_Instructions_EN.pdf .
I hope this helps.
Aug 30, 2011 | Olympus VN-1800 Digital Voice Organizer
All the files in voice recorder ( model is olympus digital voice recorder WS -300M) were locked and everytime I tried to transfer or open them, I can't, the computer says that the files are corrupted. How...
Yes, the files are likely corrupted. You can try a file recovery program such as PC Inspector Smart Recovery. Search snapfiles.com for a free download.
Apr 26, 2011 | Olympus WS-311M Digital Voice Recorder
Lost serial number for olympus recorder ws-331m
It should be on the side of the recorder,visible after you remove the battery or it may be on a decal on the back of it
Mar 18, 2010 | Olympus WS-311M Digital Voice Recorder
Dear Sirs, I have just purchased the audio recorder WS-311M with the short manual. The short manual tells me to get a FULL manual from your internet site but all I can find is the short version. Please can...
Check out this link below to download a PDF manual, and more for your recorder. Just copy and paste into your browser.
http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=1308
Hope this helps, let me know if I can do anything else for you.
JimmyC
Oct 13, 2009 | Olympus WS-311M Digital Voice Recorder
MyMusix MP3 Player
All documentation for this product is available at www.mymusix.com
Voice record
Use the built-in microphone to record voice in the voice mode.
1) Press "Rec" button to begin recording
2) Press "Rec" button again to stop recording
3) Press " play/pause" to pause or resume recording
4) Recorded files are stored as default files VXXX.WAV, XXX numbered from 001
-Tha Mp3 Doctor
Apr 03, 2008 | MyMusix PD-6030 MP3 Player
Ws 200s deleted files but still full
I had the same problem. I downloaded the instruction pamphlet at http://www.olympus.co.jp/en/support/imsg/vtrek/download/manual/ws/man_ws100_ws200s.pdf and reformatted the recorder. It seems to work fine now.
Formatting the Recorder (FORMAT)
If you format the recorder, all function settings will return to their defaults.
All files stored in the recorder will be deleted.
If you have important files that you want to save, connect the recorder to a computer and
transfer those files from the recorder to the computer before formatting the device.
1 Press the MENU button.
2 Press the FF or REW button to choose “FORMAT”.
3 When the PLAY button is pressed, “nO” is displayed.
4 Press FF or REW to select “yES”, and press the
PLAY button.
After “ARE yOU SURE” is displayed, “nO” will be displayed.
5 Press FF or REW to select “yES”, and press the
PLAY button.
“DONE” displays when formatting ends.
s It may take up to several tens of seconds to finish the initialization. Do not remove the battery or detach
the battery compartment from the recorder during that time. Otherwise data may be damaged.
s Never format the recorder from a PC.
s When the recorder is formatted, all the stored data, including locked files, are erased.
Mar 20, 2008 | Olympus WS-200S
Olympus WS-311M  Digital Voice Recorder Logo
228 people viewed this question
Top Olympus Audio Players & Recorders Experts
pankaj rautela
pankaj rautela
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
