Question about Acer Aspire 3680 Laptop
PXE problem I have 2 computers Toshiba's and they are both giving me the PXE-E61 and PXE-M0F problems. Reading from another that this is a boot error, so how do I fix it, since I am not able to diable the network boot?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, this error indicates that the system through its BIOS/CMOS could not communicate with the Hard Drive. Though am a bit curious that said errors are displayed on a Toshiba machine. Might you want to try and enter the CMOS/BIOS setup/configuration and determine if the hard drive could at all be autodetected.
Pls post back with the model numbers of the Toshibas and if you have access to a 2.5IDE to USB adapter.
Check and perform preliminary visual or necessary inspection. Pls post back result(s). Good luck and Thank you for using FixYa.
Posted on Jan 14, 2009
  • Acer Master
  • 13,433 Answers
Your trying to boot from network? seems the hard drive is not detected or not on the boot order so it boots from network, or do you have a server you can boot from? check the bios and see if the hard drive is detected.
PXE-E61 error
Check the boot sequence looks for the HDD first in the bios.
Dec 22, 2013 | Toshiba Computers & Internet
Wile I am trying to boot it up it goes in to a loop
Hello.
That error message usually refers to a hard disk failure. Your hard disk cable could be loose or faulty. Or, your hard drive would need to be replaced.
I'd suggest to check the cable and run your system's hardware diagnostics (often F2 or F12) when your system boots.
Hope this helps.
Nov 26, 2009 | Compaq Presario M2000 Notebook
My tosiba a70-kl1 starts up with a black screen and error messages stating "PXE-E61: Media tes failure, check cable" and "PXE-M0F: Eiting PXE rom"
You haved enabled the capability for your computer to "boot" itself by reading from a boot-server connected to your network-cable.
But, the network-cable is unplugged, resulting in the "check cable" message.
What this _could_ mean is that the computer primarily tried, and failed, to boot from your disk-drive, and secondarily tried, and failed, to boot from your CD-ROM, and so it made a tertiary triy, which failed, to boot from the "network", i.e., that your hard-drive is not functioning.
Reboot, and enter "BIOS setup", and disable the "boot from network" option, to get rid of those error-messages. But, it's still possible that your disk-drive is malfunctioning.
Sep 14, 2009 | Toshiba Satellite A70 Notebook
Toshiba Media test failure, operating system not found error
That message means it is not reading a drive. Most likely the HDD. I would suggest you replace the HDD. That is likely the problem.
Feb 20, 2009 | Toshiba Satellite M305D Notebook
Toshiba Satellite M305D S4831 PC Notebook
go to the bios of your laptop , check whether the hard disk is detecting or not, if not, then its the problem of your hard disk,
Oct 27, 2008 | Computers & Internet
No boot disk
when this error is showing give me details
mujahed@imsindia.co.in
Sep 27, 2008 | Acer Aspire 5315 Notebook
Error Message: PXE-E61 Media Test Failure Check Cable
Not always the Hard drive, boot into the bios setup utility and de-select network bootfrom the boot options. If it tries to network boot first you will always get that failure.
Apr 12, 2008 | Compaq Armada E500 Notebook
PXE-E61: media test failure, check cable.
Save your self a lot of reading, do this first.
Check in BIOS rom for start up sequence and check if there is an asterist (!) in front of the hdd. If there is, it’s disabled. Select the hdd and press shift key plus “1′ This removes the ! and you can then use the hdd to re-format or….
Dec 15, 2007 | Toshiba Satellite A105-S4004 Notebook
Trying to start my computer
you have a failed hard drive and will require a replacement.
Oct 15, 2007 | Toshiba Satellite P25-S5263 Notebook
Acer Aspire 3680 Laptop Logo
19 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
