Question about LG LRFD25850 French Door Refrigerator
Door Latch The plastic clip at the top of the french doors that latches the doors when closed is broken on one door. I ordered the replacement clip which is integrated into a larger assembly that is nearly 4 ft long and runs the length of the door...The part does not appear to be difficult to access with one exception...I cannot figure out how to remove the door gasket...the gasket appears to be seemed at the corners and has no obvious breaks...the gasket must be removed in order to replace the clip assembly. any suggestions on how to remove the gasket without damaging it? the mfr will not sell a service center and the nearest LG certified repair place is almost 50 miles away...
  • Lawrence Harmish Jun 18, 2007
    Thanks...It worked...not sure if the spring is inserted correctly (i just tucked it in between the assembly and the door frame), but the door latch seems to have the same tension and return as the otherside...
    President:
  • 878 Answers
Larry, I believe you have to remove the inside door frame cover, starting at the top and working your way down. The cover should snap out and away from the door. Next would be the gasket bracket clips. With a flat tip screw driver insert into the seam between the gasket bracket and the door frame and pry out until the clips snap out. Then proceed to remove the gasket from the channel. Catriver.
Posted on Jun 15, 2007
SOURCE:
Can I order the door to replace my broken one?
do you mean the door latch , google the door latch as its easily replaceable an obtained
May 19, 2014 | Equator EZ 3720 CEE
My Bosch Dishwasher door sticks shut at the end of the cycle. I can open and close it with ease during the cycle, but once it finishes I have to pull really hard to open it.
see all this steps and fix it. God bless you
Door or Lid Latch Assembly
If the door won't latch, the latch assembly might be defective. Inspect the latch assembly to see if it is cracked or worn out. The latch assembly is normally replaced all as one part.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Hinge
If the door won't latch, one or more of the door hinges might be bent or broken. If the door hinges are not working properly the door won't close squarely and then the door won't latch.
Door Catch
If the door won't latch, the door catch might be out of alignment or broken. If it appears to be OK, reposition it as needed. If appears broken it should be replaced.
Door Lock
If the door won't latch, the door lock assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door lock is broken, replace it.
Door Latch
If the door won't latch, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
Door Strike
If the door won't latch, the door strike might be defective. These are normally made of plastic or metal and cannot be repaired. If the door won't latch and the door strike is broken, replace it.
Apr 05, 2013 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Door wont shut
Door Hinge
Door Catch
Door Lock
Door Latch
Door Strike
Apr 05, 2013 | Miele Dishwashers
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Microwave will not cook/start when start button is pressed.
You can get the latch itself from either partstore .com or repairclinic .com
Apr 19, 2010 | Emerson MW8168B Microwave Oven
Latch Hooks Not Working
This is a VERY common problem, and the fix can sometimes involve replacing the door.
The following site should have the latch/gasket assembly: http://www.repairclinic.com
AFAIK, the top latch can only be replaced with the entire door gasket assembly, but it's not too difficult to do.
A google search on 'GE refrigerator latch' will find you thousands of other (former) GE customers who have had this problem.
Oct 23, 2009 | Refrigerators
Our French Door model after almost 2 yrs pops open the one door after closing the other, and it doesn't set off the door alarm because it doesn't pop it open far enough to trigger the alarm. This causes...
We solved this problem by replacing the plastic parts on the top & bottom of the door that 'latch' the door closed.
On the top of each door is a white plastic 'cam' that latches into a receiver at the center point of the refrigerator chamber. One of mine was broken.
Additionally, on the bottom edge of each door is a white plastic hook-shaped 'stopper' that provides spring tension. I replaced both of those and now all is happy.
Got the parts from RepairClinic.com
Item #: 1266811
Description: Door hinge cam (left)
Price: $2.40
Item #: 1266810
Description: Door hinge cam (right)
Price: $2.40
Item #: 1267543
Description: Stopper,door
Price: $2.40
Aug 16, 2009 | LG LRFD25850 French Door Refrigerator
LG LRFD25850 French Door Refrigerator Logo
944 people viewed this question
Top LG Refrigerators Experts
Steve Allison
Steve Allison
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
