Question about Alpine TDA-7554
Tape is stuck in the cassette player.
I have a Dolby B NR Auto metal AM/FM Cassette radio. I can not get the tape to eject out of the cassette player. How do I get it out without breaking the tape or cassette player up?
4 Suggested Answers
  • 277 Answers
SOURCE: Wiring on tape deck Alpine tdm-7543
hi there is a manual in the model page click on it page 2 there is a description how to connect the unit good luck
Posted on Mar 21, 2006
Eagleeyes
  • 199 Answers
SOURCE: Jammed CD unit
argh!!!
not good. have not worked on this model but a few models with nthe same mech, your best bet is to take this to a repair agent. there is no easy solution
Sorry
Mark
www.blueice-electronics.co.uk
Posted on Feb 24, 2008
SOURCE: MP3 Cassette Adapter Not Working
hi.....can you check if the rola ( that has teath and roling the tape ) in ur cassette adapter is actually turinig easy because whith the new cassettes if it is hard they swich the sides thinking that the tape finished if they hard try to losen them......hopfully that wil work
Posted on Aug 24, 2008
How can I fix my 2002 Honda Civic cassette player from ejecting cassettes. I tried a cassette deck cleaner and that gets ejected the same.
The auto-eject feature is normally triggered by the tape reaching its end. This causes the tape to tighten and then activates a trip lever that starts the eject cycle. Most auto tape decks that are not auto-reverse eventually have this problem. It is not usually the deck's fault, but it is with the tapes themselves. After many plays the tapes get wound too tight on the reels and drag, causing the auto-ejection. This is especially true with the thinner, larger tapes found in the C-90 and C-120 varieties. Try taking the tapes to a regular tape player and then fast-forward them from one end to the other and them a full rewind as well to loosen the tape on the spindles and re-distribute the tension. Hopefully this will work.
Sep 25, 2015 | Audio Players & Recorders
How do i remove a stuck cassette tape from a 1994 chevy truck player?
Does it make noise or move when you hit the eject button? If so, slide a butter knife under the exposed edge of the tape drive adaptor about an 1/8" and hit the eject button. Just a little upward pressure should help it release. It the eject button has no effect, you may need to pull the radio out, open the cover and manually turn the eject drive assembly.
Sep 05, 2014 | 1994 Chevrolet Silverado 2500
1990 lexus ls400 cassette player will not read or play my cassetes. i put in my cassettes but my front tape flap doesn't close and it automatically switches back to the radio.
The player has to seize the cassette as it is inserted and seat it in the correct position to be played. Sometimes the manual eject linkage becomes defective or misadjusted, preventing the cassette from seating correctly. The eject button may depress fully without causing ejection or it may depress but not cause ejection.
Dec 03, 2013 | Nakamichi 90 94 Lexus Cassette Tape Radio...
Tape is stuck in my 1990 buick reatta
Turn the power on the radio Cassette hit eject turn the power off turn the power back on. The cassette may come out unraveled but that's only way I can think of you will get it out.
Jul 19, 2013 | Car Audio & Video
2001 Tahoe cassette tape cleaning
I think you need to remove the unit and have it repaired, it is faulty.
Jun 07, 2017 | 2001 Chevrolet Tahoe
Tape stuck in player - error code e13 shows
I just got a tape unstuck myself. Everytime I would hit eject it would make a clicking noise.
Here is what I did:
First I watched these videos to remove the radio.
http://www.youtube.com/watch?v=29MTa4FLjtk&feature=channel
http://www.youtube.com/watch?v=fqvk_PNo9Kg&feature=channel
Then I unscrewed the bottom panel of the radio.
Unscrew the brass screws holding in the cassette player portion of the radio.
Now flip the cassette player over to see your tape, etc.
When I pressed the eject button, I noticed a little motor with a worm gear would move a a gear which moved several other gears until it eventually moved a black gear which has a little post that moves the metal arm which moves back when pushing in a tape and moves forward when ejecting a tape. But I would get a clicking sound which seemed to be due to one gear trying to move a stuck gear.
I forgot the exact details of how I managed to get the tape out, but when I did get it out I noticed when I turned on the radio, it would act like it was trying to play a tape. But when it found out it couldn't, it would try to eject but would fail once again with the gear clicking sound.
I think I tried moving the black post on the black gear that moves the arm that pushes the tape out. Eventually I got to the point where the arm was pushed forward like it should be when a tape is ejected. At that point I was able to insert and eject a tape without any problems.
Mar 22, 2009 | 1998 Buick LeSabre
Have a cassette stuck in my 98 Buick Century Custom
sometime you can get luck by taking out the tape player and there will be a small hole somewhere on the player that you can stick a paper clip through to release the tape player. Otherwise gnetly stick a screwdriver under the tape to see if you can get it to release. no guarntees on that last one
Jan 08, 2009 | 1999 Buick Regal
Cassette tape is stuck in player-car is a 95 buick lesabre.Can you help us to get it out?
This is what I NEED is a solution to this problem---THERE IS A CASSETTE TAPE STUCK IN A CAR STERO. The cassette player will not eject the tape. Does anyone have any ANSWERS?
Sep 07, 2008 | Car Audio & Video
Cassette player
the tape is very tight
get a pen and try to loosen up the tape
100 % is the tape not the radio
May 15, 2008 | 1999 Ford Taurus
I have a bose stereo in my 96 nissan Maxima that works poorly
there is a problem in the tape drive - possibly a bad belt- thats why the cassette adapter keeps ejecting itself- most add on xm tuners have the ability to broadcast its signal wirelessly-you press the menu button then turn the tuner to select the menu option that you want then press on the tuner control again to choose broadcast (fm signal and which channel you want to broadcast to the factory radio-try www.xmradio.com for more detailed info
Apr 16, 2008 | Car Audio & Video
Car Audio & Video Logo
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
