Question about Western Digital 320GB MyBook External USB 2.0 Hard Drive
External USB Hard Disk is 120GB is not dected in winxp pc.
My new External usb hard disk 120 GB is not getting detected in any of PC's.When inserted in the USB port the hard disk LED blinks but it is not reconginized in the OS.
Please Help.........................
  • miki69 Jan 31, 2009
    i have a 80 gb hdd,and same problem,,;-(
  • 19,396 Answers
There are two possibilities:
The Mybook USB/ATA controller board is faulty.
In this case you can simply take apart the enclosure and mount the disk into a new enclosure. WD Mybooks are SATA, but double check the hard disk connector to ensure.
The hard disk inside is faulty.
In this case repair may be expensive. You need to locate a data recovery facility with a 'clean room' , the cost is usually more than $800.
If this happened after a power surge, then the problem is most likely a faulty controller board.
If instead you have dropped the hard disk it is possible an hard drive failure, in that case repair will be expensive.
A replacement enclosure will stfrom art about $20 on Ebay or Amazon, and must not necessarily be WD .
Check if your disk is Sata or PATA (IDE) before buying the enclosure.
Posted on May 04, 2009
Hi there i hav ea maxtor onetouch 4 mini 120 gb.
Remove the hard drive from the Maxtor case, purchase an USB hard drive adapter case, and install the hard drive inside this case. Then you can connect this to the computer's USB port and if the hard drive is OK then this computer will detect it as an external USB hard drive, then you can open the folders and files and back them up.
Jun 29, 2010 | Maxtor OneTouch 4 Mini 120GB External USB...
External Hard Drive stopped working
u might have to format it in safe mode or buy a new one, if you try it on some one elses comp. and it works it ur comp. but it is most of the time a software issue
May 08, 2010 | Toshiba 120GB USB 2.0 Portable External...
320 GB transcend external Hard dics is not at all detected
First of all make sure that the USB port that you are using to connect it to your PC is a USB 2.0 port, and not USB 1.0.
Also if it came with an external power, connect it to the external power before putting on your PC.
This is because the voltage supplied by USB 1.0 is lower than that of USB 2.0 and therefore might not be enough to power up your USB Drive.
After making sure about this, power up your system, and plug the external drive, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your external drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
This should make your external Drive to be detected automatically.
Hope this helps you out.
Nov 16, 2009 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
My PC or Laptop will not recognize my maxtor one touch 111 120GB hard drive. it was working fine befor and now i get an error from windows that says: thre was a problem installing your new hardware
It is your driver related issue.
Check your operatign ssytem version is winxp sp2 ?
SP2 is perfact for usb 2.0
Also you can try to uninstall all usb driver and install inf update utility it is comes with motherbord disk.
You can uninstall usb drivers from computer with device manager .
For that go to my computer proeprty then hardware then device manager then uninstall all usb drivers.then restart the computer then check.
Also check your harddriver usb cable is working fine tryt all usb ports of computrer 1 by 1.
Also try in another computer.
Aug 24, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Toshiba 1Tb USB does not detect in My Computer - WinXP
you must install the drivers frist
click here for the official site
Jul 01, 2009 | Toshiba 120GB USB 2.0 Portable External...
Toshiba 120 GB USB 2.0
check if you have another drive which has the same alphabet as your external drive, if so then go to disk management and change the name of the disk.
Apr 22, 2009 | Toshiba 120GB USB 2.0 Portable External...
Hard drive detection
You should not need a driver for it. Assuming you are using XP or Vista, the disk should be supported directly by the OS.
Have a look at external HDD troubleshooting.
Jules
External Hardisk Maxtor 4 One Touch not detected
Have you tried different USB cables with the drive? If the drive is self powered (no ext power supply) which I think that one is, then it needs a really good cable to draw the 5 volts from the USB port. If you have tried a known working cable, then it could be the USB controller or the disk itself. You can buy the USB box on eBay really cheap and move the drive over.
Apr 13, 2009 | Computers & Internet
Western Digital 320GB MyBook External USB 2.0 Hard Drive Logo
423 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
