Question about HP Photosmart C3180 All-In-One InkJet Printer
Each time I activate computer it prints out a test page
It eats up all my ink. What do you suggest I do? Thanks, Margie
  • Bill Speer
    Bill Speer May 11, 2010
    Are you saying everytime you boot up the PC it prints out a test page from the printer? If you unplug the printer and boot up, then plug it back in does it do the same thing? Is it connected via USB or parallel cables? What OS do you have?
  • 3 Answers
With a lot of the all in one printers they want to scan the test page aftert printing to check the alignment. Next time it prints out a page, if a dialogue box appears saying scan now with the option of scan or cancel, select scan. If a dialogue box does not appear, check the menu on the software and look for alignment. That should fix it.
Posted on Jan 14, 2009
I replace my cartridges it says refer to printer documentation and will not print
These types of severe HP 74 black or HP 75 color ink cartridge errors (i.e. refer to documentation / incompatible cartridges, print cartridge(s) problem, etc.) typically indicate the internal micro electronics of the respective HP 74 black or HP 75 color cartridge are damaged. The cartridges electrical wire runs at rear and lower side of the ink cartridge, are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal micro electronics failure. I suggest you first run a Tap 41 diagnostic test to check cartridges electrical health (this is a special forced service test, refer to video so you understand how to read the print out). You may also bypass the error (temporarily) on most models which use HP 74/75 cartridges.
NOTE: Unfortunately, alignment pages and internal self test prints will usually print Ok even if the cartridge is internally electrically damaged. Do not use these test pages as a proxy for determining whether a cartridge is good or bad, only the 'Tap 41/43' diagnostic test report can yield this information.
CONTACT CLEANING / SERVICE TEST DIAGNOSTICS:
A. Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B. Print Self Test Page:
1. Press and hold the CANCEL button.
2. Press the COLOR COPY button. Release both buttons.
3. The self test page should print. The printed pattern will verify printer is generally functional
--- The self test page is a 'forced' test print whether the ink cartridges are good or bad. Inspect color bars to verify proper nozzle/jetting health. If normal/regular printing is still not permitted then the problem is with either one, or both, of the ink cartridges. Activate Tap 41 test to confirm which cartridge is causing the issue.
C. Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test. Refer to video procedure or .pdf document at the following links on how to activate and read the service test report: http://inkjet411.com/?page_id=536
1. Load Letter/A4-size paper into paper feed tray.
2. If any lights are blinking, first press Cancel to attempt to clear.
3. Press and HOLD the Cancel button, press Ok button once.
4. At 'Mfg Commands' menu, click Right Arrow once until 'uiaux service' menu is displayed.
5. At 'uiaux service' menu, click the Right Arrow until Special Reports menu is displayed.
6. Select Ok, then click Right Arrow until the 'print-mech button tap' menu is displayed.
7. Select Ok (Code = 0 will be displayed); click and hold Right Arrow until 'code = 41' is displayed. Use the Left Arrow if you need to decrease numerical count.
8. Select Ok. Within one minute the Tap 41 diagnostic test report should be initiated and print (whether ink cartridges are good or not, i.e. this is a forced print test). See following 4 paragraphs (or video) on how to interpret diagnostic report.....
NOTE: You may also refer to this document for specific printer model 'Tap 41' diagnostic & 'Cartridge Error Bypass' step-by-step instructions: http://inkjet411.retailinkjet.com/wp-content/uploads/2013/04/HP-74-75-Problem-Resolution_v10.pdf
--- Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 75/75XL color cartridge should display 600 good nozzles, while a good HP 74/74XL black ink cartridge should show 672 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to video on how to read the printout.
---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
You can also test general printer performance by running the 'Tap 10' diagnostic test, use same procedure above and enter "code = 10". Both the 'Tap 41' and 'Tap 10' tests are 'forced print tests' - the printer will make every attempt to print the pattern whether the ink cartridges are good or bad...the patterns should be utilized to diagnose cartridge health. If 'regular' printing is still not possible then one or both of the ink cartridges is damaged.
ERROR BYPASS OPTION (TEMPORARY ONLY):
NOTE: It is possible to 'temporarily' bypass the cartridge error message (for emergency printing purposes only), please refer to link above/below for video/documentation instructions: http://inkjet411.retailinkjet.com/wp-content/uploads/2013/04/HP-74-75-Problem-Resolution_v10.pdf
However, if the cartridge is determined to be electrically damaged, largely dependent on the 'Tap 41' diagnostic test results, the cartridge will eventually need to be replaced with a new one. With a marginally performing ink cartridge, this typically results in allowing 1 entire print job to be printed at a time. If this does not permit any print operations then the cartridge has severe internal electrical damage and will need to be replaced.
*Many cartridges eventually do encounter problems or failures, especially after their original ink is gone and they are re-used, and this is often unrelated to the refill process. The "Incompatible Print Cartridge(s)" / "Print Cartridge(s) Problem" / "Refer to printer documentation" / "Cartridge Error: Cartridge must be replaced" / "Cartridge in left/right slot is not intended for use in this printer" / "Now printing alignment page" error messages are typically indicative of failed micro-electronics internal to the ink cartridge(s). Also note that it is common to have a marginally performing ink cartridge (which was performing ok before) in the adjacent slot (i.e. color), then when a marginally performing cartridge is installed into the other slot (i.e. black), both of the ink cartridge(s) then get flagged with electrical errors. Running the 'Tap 41' cartridge health diagnostics test will confirm the active electrical state of both cartridges.
For additional printer diagnostics information please visit: http://inkjet411.com/?page_id=1813
NOTE: If you are interested in the top 'refill friendly inkjet printer models', our suggested list is posted on-line and our internal labs have verified there are no issues (with ink compatibility or color output/richness) with all of these models: http://inkjet411.com/?page_id=3585
CAUTION: Be advised, the use of compatible/clone cartridges (i.e. sold thru the internet from overseas) are known to be problematic and may cause printer errors. We do NOT suggest refilling these types of ink cartridges.....refilling of HP 74/75 original/genuine ink cartridges is only suggested!
HP 74/75 Ink Refilling Services & Additional Cautions:http://www.youtube.com/watch?v=WqnHRFpbo0w
If you ever need to purchase a new HP 74/75 ink cartridge(s), we suggest you try a remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA, have a high reliability rating and provide a 1-year warranty and free shipping over $20 (products available to US residents only).
HP 74 Cartridges:
https://inkplicity.com/shop/?slug=advanced_search_result&keywords=HP%2074
HP 75 Cartridges:
https://inkplicity.com/shop/?slug=advanced_search_result&keywords=HP%2075
For any additional questions please contact us directly: Inkjet411help@gmail.com
-Thank you
May 21, 2015 | HP Photosmart C5280 Printer
Printing ok from computer but photocopier printing very faded
Select "Copy" from the touchscreen and then select "Settings..." Adjust the "Lighter/Darker" setting and see if that helps.
Mar 31, 2015 | HP Officejet Pro 8600
Hp J5780 all in one - I cannot get the printer to attach to the bottom portion.
Regarding your recent inquiry about the HP 74, 75, 74XL or 75XL ink cartridge error message ("Cartridges Not Aligned" or similar printer alert condition) and inability to print with your HP OJ J578 printer, this type of error is normally associated to an electrical connection issue between the printer and the cartridge, or more likely, an internal micro-electronic failure inside one of the ink cartridges (.....it is very rare for both cartridges to fail at the same time). An electronic failure of the cartridge would be unrelated to the ink cartridge refill process; these same failures can (and frequently do) occur with brand new ink cartridges.* To help identify the root cause, and to confirm/determine which of the two ink cartridges is causing the failure condition, please run the 'Tap 41' cartridge's electrical diagnostic test below (refer to C.)
Please first verify the age of the ink cartridge(s)....look at imprinted date on front of ink cartridge. If this 'warranty expiration date' has expired, then potential internal electrical cartridge failures can occur due to internal corrosion, etc.
DIAGNOSTIC STEPS:
A.Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B.Print Extended Self Test:
    1.Press CANCEL + OK buttons at the same time.
    2.The extended self test page should print.
    --- Verify all colors and all stair-step nozzles are firing (i.e. no missing horizontal lines should be visible in the stair-step grid patterns). (NOTE: the self test page is a 'forced' test print whether the ink cartridges are good or bad). Inspect color bars to verify proper nozzle/jetting health. If normal/regular printing is still not permitted then the problem is with either one, or both, of the ink cartridges. Activate Tap 41 test to confirm which cartridge is causing the issue.
    C.Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test. Refer to video procedure (or .pdf document) at the following links on how to activate and read the service test:
    http://inkjet411.com/?page_id=544
      1.Press the * and # keys simultaneously.
      2.Enter 124 (or 123) at keypad.
      3.Use the arrow keys to navigate to the System Menu. Select Ok.
      4.Use the arrow keys to navigate to the 'print-mech tap test'. Select Ok. Should display 'code = 0'.
      5.Use the arrow keys to enter 'code = 41' (or just enter 41 on keypad). Select Ok. The Tap 41 diagnostic test pattern should begin to print.
      NOTE 1: The 'Tap 10' (extended self test) can also be activated by pressing CANCEL + OK buttons at the same time. Whether ink cartridges are good or not, i.e. this is a forced print test). Refer to following 4 paragraphs (or video) on how to interpret diagnostic report.....
      NOTE 2: You may also refer to this document for specific printer model 'Tap 41' diagnostic & 'Cartridge Error Bypass' step-by-step instructions: http://inkjet411.retailinkjet.com/wp-content/uploads/2013/04/HP-74-75-Problem-Resolution_v10.pdf
      NOTE 3: It is possible to 'temporarily' bypass the cartridge error message (for emergency printing purposes only), please refer to link above/below for video/documentation instructions. However, if the cartridge is determined to be electrically damaged, largely dependent on the 'Tap 41' diagnostic test results, the cartridge will eventually need to be replaced with a new one. With a marginally performing ink cartridge, this typically results in allowing 1 entire print job to be printed at a time. If this does not permit any print operations then the cartridge has severe internal electrical damage and will need to be replaced:
      D. Cartridge Error Bypass ( Emergency Printing Only - http://inkjet411.com/?page_id=544 ):
      1. Press the * and # keys simultaneously.
      2. Enter 123 (or 124) at keypad. The 'Underware' menu should be displayed.
      3. Use the arrow keys to navigate to the Information Menu. Select Ok.
      4. Use the arrow keys to navigate to the 'checksum for relock data input'. Select Ok. LCD should display a 5-digit number after a few seconds.
      5. Attempt to send a print job to printer
      NOTE: with a marginally performing ink cartridge, this typically results in allowing 1 entire print job to be printed at a time. If this does not permit any print operations then the cartridge has severe internal electrical damage and will need to be replaced.
      *Many cartridges eventually do encounter problems or failures, especially after their original ink is gone and they are re-used, and this is often unrelated to the refill process. The "Incompatible Print Cartridge(s)" / "Print Cartridge(s) Problem" / "Refer to printer documentation" / "Cartridge Error: Cartridge must be replaced" / "Cartridge in left/right slot is not intended for use in this printer" / "Now printing alignment page" error messages are typically indicative of failed micro-electronics internal to the ink cartridge(s). Also note that it is common to have a marginally performing ink cartridge (which was performing ok before) in the adjacent slot (i.e. color), then when a marginally performing cartridge is installed into the other slot (i.e. black), both of the ink cartridge(s) then get flagged with electrical errors. Running the 'Tap 41' cartridge health diagnostics test will confirm the active state of both cartridges.
      For reference, the following page provides a complete review of the majority of cartridge error messages you may observe on your printer at one point or another:
      http://inkjet411.com/?page_id=509
      However, if your printer works routinely after inserting a brand new HP 74 and/or HP 75 ink cartridge in it, then this will confirm root cause of failure as being limited to one of the ink cartridges.
      For additional HP OJ5700 printer series diagnostics information please visit: http://inkjet411.com/?page_id=1813
      If you need to purchase a new HP 74/75 ink cartridge(s), we suggest you try a remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA, have a high reliability rating and provide a 1-year warranty (remanufactured ink cartridges which have been thoroughly tested; purchases are only available by USA residents).
Feb 17, 2015 | HP Officejet J5780 All-In-One InkJet...
Need help in fixing HP Photosmart C5280 Printer two springs on the side of carriage bar
We suggest you contact 'Parts Here' as they provide most parts for the C5280 printer, including carriage assembly parts, along with the C5280 service manual: http://www.partshere.com/models/hpprinters.asp?printer=Q8330A
C5280 CONTACT CLEANING / SERVICE TEST DIAGNOSTICS:
A. Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding - refer to Inkjet411's support page: http://inkjet411.com/?page_id=1519
NOTE: If you need to purchase a new ink cartridge(s) and are trying to cut costs, we suggest you try a remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA, have a high reliability rating, come with a 1-year warranty and provide free shipping for all orders above $20 (available for US Residents only).
-Thank you
Oct 15, 2014 | HP Photosmart C5280 Printer
How to reset inkje even with new refilled cartridge
Regarding your recent inquiry about the Canon 240 (black) or 241 (color) ink cartridge ink alert/error condition and the inability to print to your Canon MX452 printer, to reset the cartridge ink low/empty alert message condition, depending on your printer model, we suggest you follow the documented procedures below and/or provided on Inkjet411 at the following link. http://inkjet411.com/?page_id=1765
Essentially, in most cases, all you need to do is press the 'Stop/Reset' button (triangle symbol inside of a circle) for 5-8 seconds and the ink error ("ink has run out", etc.) indicators should extinguish; two common reset procedures are provided below (please refer to both videos): http://inkjet411.com/?page_id=1765
Canon 30/31/40/41 - Refilled Cartridge Activation Instructions: http://inkjet411.com/?page_id=2709
Canon 50/51 - Refilled Cartridge Activation Instructions: http://inkjet411.com/?page_id=2719
Canon 210/210XL/211/211XL - Refilled Cartridge Activation Instructions: http://inkjet411.com/?page_id=2728
Canon 240/240XL/240XXL/241/241XL - Refilled Cartridge Activation Instructions: http://inkjet411.com/?page_id=2733
Canon 245/245XL/246/246XL - Refilled Cartridge Activation Instructions: http://inkjet411.com/?page_id=2740
If you have already attempted the 5-8 second printer reset without success, then refer to WORST CASE SCENARIO section below.
ADDITIONAL NOTES:
NOTE 1: Providing you can still print, you will need to wait until the "ink has run out" message appears on your computer, before activating the 'Stop/Resume' button for 5-8 seconds. However, if printing is not permissible, then please keep reading....
NOTE 2: If you are able to print the internal self test print, this will demonstrate that the ink cartridge is 'at least' partially functioning. If this is the case, then we suggest you continue printing until the software prompts you to press the 'Stop/Reset' button for >5 seconds. For poor print quality performance issues (as you indicated in your inquiry), we suggest you run a nozzle/cartridge clean test from your Canon software, followed by printing our 'Ink Recovery Test' print: http://inkjet411.com/wp-content/uploads/2013/02/Test-Print_CMYK.pdf
NOTE: To rule out connectivity issues, please ensure BOTH carriage/flex cables (point where the cartridge connects to carriage inside the printer) and BOTH ink cartridge rear electrical contact surfaces are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
      WORST CASE SCENARIO - INTERNAL ELECTRICAL FAILURE OF INK CARTRIDGE:
      If, after performing the suggested 'reset' procedures above, you still have an error condition which prohibits computer/host based printing (or permit copy/scan functions), then the ink cartridge probably has internal electrical damage (micro-electronics failure); such a failure is unrelated to the ink cartridge refilling process. Typically, when the cartridge fails the problem is 'masked' by the ink out/empty condition so it can be difficult to distinguish between the two. Many cartridges eventually do encounter problems or failures, especially after their original ink is gone and they are re-used, and this is often unrelated to the refill process (i.e. typically ~2 years from original manufacturing date). Refer to picture at bottom of this page: http://inkjet411.com/?page_id=1533
      If, following a reset of the printer via the 'Stop/Resume' button, printing is permitted but the 'Ink Low' indicator continues to be lit then one of the inks cartridges may be suffering from marginal internal electrical performance - a potential failure of the cartridge may eventually occur which will prevent printing.
      CAUTION: Be advised, the use of Canon compatible/clone cartridges (i.e. sold thru the internet from overseas) are known to be problematic and may cause printer errors and/or permanent PRINTHEAD failures (due to incompatible ink formulations which may contain volatile organic compounds, or VOCs). We do NOT suggest refilling these types of ink cartridges.....refilling of Canon original/genuine ink cartridges is only suggested!
      Canon 30/31 Ink Refilling Services & Additional Cautions:http://www.youtube.com/watch?v=3khyqBHMPVc
      Canon 240/241 Ink Refilling Services & Additional Cautions:http://www.youtube.com/watch?v=HyEhCOxvdsA
      If you do need to purchase a new ink cartridge (to save on ink costs), we suggest you try a USA remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA, have a high reliability rating and come with a 1-year warranty.
      Alternatively, if you are interested in the top 'refill friendly inkjet printer models', our suggested list is posted on-line and our internal labs have verified there are no issues (in ink compatibility or color output) with all of these models: http://inkjet411.com/?page_id=3585
      Please let us know if you have any questions regarding the technical information provided above by sending an e-mail to us directly: Inkjet411help@gmail.com
      -Thank you
Jul 20, 2014 | Canon Pixma MX452 Wlse All-In-One Printer...
Not printing just sending out blank paper sounds as though it printing
if you have the full software package installed go into the computer interface by double clicking that printer under start, printers and faxes and select the printer. In the popup that appears, select properties and print a test page. If it still doesn't print, use the troubleshooter which should suggest cleaning the printheads (beware this eats up ink). If it still doesn't print and the printer is used often, it needs a new printhead (or you need a new printer if you price it - but that's up to you). Printheads that aren't often used clog and ones that are used alot tend to wear out in about a year.
Oct 31, 2009 | Dell 922 All-In-One InkJet Printer
Unable to print any thing
Remove and re-insert the cartridges.
while plugged in.
Clean nozzles, printhead, align etc...
print a test page off
Easyshare are known for eating ink up,
the ink could be all gone.
possible bad cartridge, swap out.
Regards
Richard.
Apr 20, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
My printer keeps printing the test page every time it's switched on
0.gif Re: HP PSC 1513 all in one by Bert t.gif (9/25/07 1:07 PM) reply + / - http://h10025.www1.hp.com
0.gif Re: Re: HP PSC 1513 all in one test page always pr by Anonymous (12/12/07 6:14 AM) reply + / - Subject : How to disable the test page that always prints when you switch on the HP PSC 1513 all-in-one printer.
Take the test page ( also called : alighnment page ) that always prints when you switch on the printer and place it face down in the scanner.
Then press the scan button on the printer itself.
(this is the button at the bottom of all the buttons on the printer/scanner.)
Make sure that the printer scans the test page.
( sometimes you press the butoon and it doesn't scan )
( it makes a scanning noise when scanning succesfully )
Then it will stop printing the test page ( alignment page ) ever again.
This is a really stupid product feature on HP's part to waste ink and force people to buy more cartriges.
beukes2@gmail.com
Nov 29, 2007 | Office Equipment & Supplies
Printer prints test page each time printer is turned on
There may be something initialised to print a test page everytime it starts, just remove printer, uninstall driver and re start. Re install drivers and connect printer when prompted or when installation has finished. This should revert to default settings.
Jan 07, 2007 | HP PSC 1510 All-In-One InkJet Printer
I had the same problem and it was driving me crazy until I did this. Please follow exactly and IN ORDER.
1. Turn off the printer and wait 10 seconds. Turn it on again
2. Let the printer print the test page.
3. After the test page is printed, disconnect the USB cable connecting the printer to your computer. DO NOT turn off the printer while disconnecting the USB cable.
4. Place the test page on the scanner glass and press the SCAN button on the printer. The ON light will flash as the page is being scanned.
5. Remove the test page when the ON light is steady.
6. Finally, turn off the printer and wait another 10 seconds. Then turn it on again. No more printing test pages! Yay!
(You may now reconnect the printer to your computer via the USB cable.)
Dec 23, 2006 | HP PSC 1315 All-In-One InkJet Printer
HP Photosmart C3180 All-In-One InkJet Printer Logo
29 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
