Question about Syntax LT26HVE 26 in. HD-Ready LCD Television
LT26HVE issues I have a LT26HVE that will show a lit power botton in stand-bye, but when pushed it will only turn on for 2sec. and deactivate the led. If you push the button again it lights the led in stand-bye again. I think the supply is ok...at least I get 24v,5v,14v and 6.7ish where it's labeled on the card. Any suggestions????????? Is there a secret latching circuit?
  • 1 more comment
  • achuck Jan 25, 2008
    i have the same tv, same problem. They say it's the motherboard at 230.00 (with shipping). They (Syntax) also eluded to a ballast that fires the LCD up much like a flour. light. I wonder if that alone is replacable
  • Anonymous Nov 02, 2008
    Same problem as originally stated, only mine doesn't turn on at all now (still a blue light).
  • Anonymous Nov 30, 2008
    same issue
    Problem Solver:
  • 15 Answers
Definetly inverterbaord. Check each inverter with a voltmeter or check your wires running from your inverter board 2 your screen. They might b getting hot and r arcing. U will have 2 rap the burnt spots with black tape.
Posted on Dec 05, 2013
  • 18 Answers
I THINK IS THE INVERTER BOARD !
Posted on Aug 24, 2009
Maybe a class action lawsuit is the answer
Posted on Aug 09, 2008
TCL 21K77 power on for 2sec then turn off
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. ..
Oct 10, 2016 | Televison & Video
Seiki tv SE50fy28, stand bye light is on until powwer botton pushed then i get only s black screen
Aug 31, 2016 | Seiki Televison & Video
I have a 56' that wont show picture
Power board is bad.. I had the same issue.
Apr 13, 2010 | Samsung HL-S5679W 56" HDTV
My lcd model # 1901FP when power on dispaly on after 2sec diplay off at this time power led show green .again power on /off button off and on the same (power on dispaly on after 2sec diplay off at this...
Hi, This is a common problem with LCD monitors and is usually a result of blown capacitors or it could be a failed backlight as the inverter will shut down if it detects this. You will need to open up your monitor and you will be able to see if any capacitors have "blown" but failure of a lot of components will cause this symptom.
Oct 14, 2009 | Dell UltraSharp 1901FP 19" Flat Panel LCD...
My Brother MFC-235C shows print unable 32 read user manual but I dont have a manual
The message "Print Unable 32" or "Machine Error 32" will appear on the LCD display if paper or labels are stuck inside the printer or drum unit.
This will also appear if there is either a mechanical issue or just a problem with a sensor possibly software.
1) The way to resolve this issue is to make sure there is no paper in between the rollers or on top of the print heads (if applicable).
2) If there is no paper the you will need to hard reset the printer which will restore to manufacuter settings and reset software.
Hold down the Menu botton while plugging in the power cable. The display should read "Maintenance." let go of the menu button and then punch in 91. The display should read "Param Init." The unit will beep once. Then type 99. The unit will exit maintenance mode.
This only works for maybe 30% of the time.
3) If this does not work then : Refer to Manufacturer or return the item.
IF PRINTER DOES NOT HAVE A MENU BUTTON:
1)Turn the printer power switch OFF. Check that the front cover is closed.
2)Turn the printer power switch ON while holding down the GO button until the Toner, Drum and Paper LEDS are lit.
3)Release the GO button. All LEDs will be off.
4)Press the GO button 8 times. The Ready LED will flash briefly while the printer is reset. After the printer is reset the READY LED will be lit.
Feb 19, 2009 | Office Equipment & Supplies
Olevia LT26HVE Power issues?
Finally recieved an email from syntax olevia customer support after 1 month. a standard desktop computer power cord is all you need for your Olevia LT26HVE flat screen. We lost ours in a move and FINALLY have it up and running again...for only 9 bucks at RadioShack!
Dec 07, 2008 | Syntax LT26HVE 26 in. HD-Ready LCD...
Codes to program the RCA Universal remote control for a Magivox T.V.
My dear friend if your remote control got the code search button try with this.
Push and hold code search button until the led stand lit,now release him push and release the tv button the you need to push and release the power button until the tv set turns off push and release the button set and the code get in the memory of the remote.
You need to turn the tv manually.
Good luck
Sep 13, 2008 | Televison & Video
TV WILL NOT TURN ON
The power supply, and or one of the circuit board is defective. The set will require shop service.
Jerry G.
Jul 26, 2008 | Audiovox FPE3000 30 in. HD-Ready LCD...
Power button won't shut off
First thing to do is unplug the reciver for 12 to 24 hours. Sounds like it needs to be reset.
Sep 18, 2006 | Denon AVR-1803 Receiver
Syntax LT26HVE 26 in. HD-Ready LCD Television Logo
546 people viewed this question
Top Syntax Televison & Video Experts
Computer Repairing
Computer Repairing
Kolbrun...
Are you a Syntax Televison and Video Expert? Answer questions, earn points and help others
