Sound device problem
I`ve got voipcheap on my laptop, using vista but when I try to call it`s saing "call failed due to sound device problem on this computer"
It`s a bit strange, I switch to headphones with microphone but still wont work.
Cheers
  • Anonymous Jan 14, 2009
    MY SOUND CANT PLAY
  • maciey_twin Jan 16, 2009
    Hello
    I`m not using any device but my laptop, so it`s build in speakers and microphone. Maybe it`s a poblem with settings.
  • 50 Answers
Try to reconnect your device, if it fails again, download it with a driver
Posted on Jan 14, 2009
Lenovo 3000 N100 vista 64-bit problem
I don't follow your assumption. Not unless you didn't have Vista 64-bit originally, and have installed it.
Driver: Small piece of software that allows the Operating System, to communicate with a device
However;
Lenovo Support > Lenovo 3000 N100 Notebook PC > Drivers download page,
http://support.lenovo.com/en_US/detail.page?LegacyDocID=MIGR-63572
My thinking is the laptop is dirty inside.
Air cools the hardware components inside the laptop.
The cooling fan draws air from the Bottom of the laptop.
Dust, dirt, hair, lint, food crumbs,....you name it; is drawn in.
The Processor and graphics chipset, are the two hardware components that give off the most heat.
When a Processor overheats, it turns off. (BIOS turns it off)
This is a fail safe feature built in.
Keeps the Processor from burning up.
ALL power removed, (AC adapter {Charger}, and Battery), and blow-ing air in the intake port, (Fan opening), will NOT repair.
At most it is a temporary repair. Kind of like putting a Bandaid on a hole in a dam.
Laptop needs to be partially disassembled, and Q-tips, soft small brush, (Old makeup brush?), plus a can of compressed air for computers; needs to be used.
http://www.youtube.com/watch?v=AkAeE5I5E_A
http://support.lenovo.com/en_US/guides-and-manuals/default.page?
Click on the bold black subheading - Hardware maintenance manuals
It is a Service Manual in PDF file form.
http://www.youtube.com/watch?v=JQRAjlUYL90
Also remove the Ram Memory module/s ('Stick'), and clean the gold plated contact pins, with a pencil eraser. Use air to remove the eraser dust, reinstall.
For additional questions please post back in a Comment.
Regards,
joecoolvette
Nov 25, 2012 | Lenovo 3000 N100 Notebook
How do I diagnose and fix my laptop's sound problem? Should I just throw it out the window?
which operating system
You receive an error that states: There might be a problem with your audio device
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
hope this helps
Jun 26, 2012 | Fujitsu Siemens Amilo Pi2515 Laptop...
Can't Recover Vista CD ROM Device Driver
You can download the device drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -
http://welcome.hp.com/country/au/en/cs/support.html
Mar 09, 2012 | HP Presario Computers & Internet
My integrated wepcam on my Hp Pavillion 6915nr Laptop, is not being recognized. I can not find it in the device manager. I've update bios. and pretty much all of the updates. How do I locate in the...
You can try to install Webcam driver. You've not mentioned your OS; i think you use Windows 7. But HP only support Vista. You can give a try to download and install Vista driver. In most cases it solves the problem.
Here is the links for Vista 64 bit Webcam driver:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-47244-1&cc=us&dlc=en&lc=en&os=2093&product=1842155&sw_lang=
Alternatively, you can solve the driver problem by installing HP Software Update
Aug 11, 2011 | HP Pavilion dv6000z Notebook
Ng ha2ng kc ung laptop ko. pg inoopen ko xa mya2 dko na mpindot ung mga application khit ung sa start... tpos ndi dn lmlbas ung sa tbi na prng bnubuklat.. i hope m2lungan nyo ko
There are 3 common causes why a computer hangs or locks up.
1. Overheating - kapag nag-oover heat ang cumputer, naghahang ung computer, or ung processor.
2. Incompatible or corrupted device driver or system file
3. Faulty RAM (Random Access Memory)
Para macheck mo kung related sa overheating ung unit, punta ka sa BIOS setup (either pressing F2, Del, F10.. just after ng manufacturer's logo..depende sa brand ng computer). Pag naghang siya sa BIOS, pacheck mo nalang sa computer technician due to motherboard/cpu issue. Pwede mo rin pacheck baka loose connection ng RAM mo, or faulty at kelangan na palitan.
For incompatible or corrupted driver or system file naman, reinstall mo lang ung driver (usually graphics driver ang cause ng freezing) or reinstall mo ung operating system (xp, vista, 7 or linux)
Hope this helps.
May 09, 2011 | Computers & Internet
I dont know why that when i use voipcheap the sounds like a computer sounds. However, when i use skype to talk with my friend, the sounds is normal~ can i ask why?
If the sound quality is cheap, then you may try to uninstall and reinstall the audio driver. Go to start/type device manager on the search box/look for sound, video and game controller/uninstall the high definition driver or the audio drive, do not check the delete box. Once the driver is uninstalled, restart the NB. The audio driver will be reinstalled automatically once laptop is restarted. Then test the sound.
Hope it works.
Mar 13, 2011 | Computers & Internet
HI ! My name is Vinod. I hava Compaq Presario V6604 AU 2007 model. I am using dual booting system in my laptop with windows vista home basic and windows 7. My laptop came with windows vista pre-installed....
I know of problems running Vista and Win7 from the same hard drive and it is usually fixed by having Win7 as the main boot on "C" and Vista on "E" a separate partition.
The sound drivers are very similar and usually only give trouble when mixing 32 bit with64 bit.
Hope this helps
Dec 24, 2010 | Compaq Computers & Internet
Voipcheap: Configure audio device error :(
Dear All,
I have found solution in a web.
Right clic on a voip icon. Then choose Properties.
Next go to Compatibility and select to run the exe file in XP (service pack 2) compatible mode.
I hope this will help you too.
Tomasz
Jan 07, 2009 | Computers & Internet
Sound device problems
right click on the program shortcut and change the compatibility to windows xp, it will work then...
Nov 13, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
125 people viewed this question
David Payne
David Payne
