Gestetner 3245 get lighter wen run 50 to 100 pgs
Wat is the problem my copier become lighter or gray every 50 to 100 copy .. wen it become lighter or gray i push the toner 2207 and it return darker agen... can any1 help me on diz problem... tenkz
  • Tim Babcock
    Tim Babcock May 11, 2010
    What is the total count on the copier?
  • 135 Answers
The amchine runs a density patch every 50-75 prints if you run long jobs it cannot run patch till job is finished which is why your copies get lighter the longer the job
Posted on Apr 20, 2009
Gestetner 3235 copier speed only 35cpm it true that
replace the board and the main motor and the polygon mirror motor( not recomended)
3245 45cpm
3235 35 cpm
Oct 30, 2009 | Gestetner Office Equipment & Supplies
Gestetner 3245 dev.bias setting....
Hi how you doing the main problem with changing the dev bias is that the gap between the drum charge and dev bias has been brought closer and so more toner is being put onto the drum for image density.. I take it you have cleaned the optics on the scanner mirrrors and that the laser **** glass has been cleaned as these effect the copy quality too.. if the dev hasnt been changed at the pm intervals it slowly looses its charge holding capabilities.. you should change at least at the 160k marks to keep quality good.. you could also adjust the laser power up so you have a stronger image formation..hope this helps..if you know the machine I would take the laser unit out too and take the cover off to see if there a dust coating in the image mirrors as this can cause faint copies over a long period.. Good Luck A
Jul 01, 2009 | Gestetner Office Equipment & Supplies
Hw many grams dv is needed in afficio 450 or gestetner 3245
I just responded to your other thread, sounds like you are trying to use a generic dev, or something. You are asking for big trouble.
Mar 02, 2009 | Ricoh Aficio 450 Copier
Afficio 450 or gestetner 3245 calibration
Dev. Change Process
1. Check that Dev. unit has the lastest seals.
2. replace dev. material.
3. Dump dev.
4. add new dev. material.
5. Hand rotate the dev. unit 10 times.
6. reinstall the dev. unit into machine.
7. cover the toner inlet opening with a piece of paper
8. insert PCU unit.
9. turn the machine on.
10. When machine reaches ready -- enter SP modes and perform SP-2801 (2 times)
11. open the right cover of the machine. Cheat the right cover switch. Examine the drum as it rotates. Afew bands of toner and the ID pattern will be developed on the drum. The drum should be clean -- a slight dusting on the drum is OK.
12. Perform SP-3001 -- ID sensor initial setting.
13. ** Important** remove the PCU unit. Empty the toner from the PCU by sliding the shutter on the bottom of the PCU to the side and tapping the PCU.
14. reinstall the PCU.
15. Run test copies.
Pls rate -- thank you
How to calibrate the dv and toner...afficio 450.or gestetner 3245
Hello sir; Just follow the steps;
1, dump entire dv use vaccunm cleaner to cleanup don't leave any dv inside.
2, thorughly clean out magnet roller by rubbing alcohal.
3, pour in new dv evenly.
4.Do simulation 2801 & 2805, the procedure as follow;
press"clear mode", "107", press and hold "clear/stop" key for 3 seconds, then press 1 for copier sp then enter2801 press start, after that go to 2805. same procedure. Let me know the resolve.
The copy of afficio 450 become lighter
You may want to consider putting developer into the unit. What is the copy count on the machine?
Jan 15, 2009 | Ricoh Aficio 450 Copier
Afficio 450e gray copy or lighter copy
Look into replacing the developer in your copier. It has to be replaced every 125,000 cycles.
Jan 14, 2009 | Office Equipment & Supplies
Gestetner 3245 copy machine
You have a problem in the heater, sensors detected temps over 220c for more than 6 seconds. It will be an expensive repair. Most likely around $400 parts plus labor. Not something for the average Joe to troubleshoot.
Aug 21, 2008 | Gestetner Office Equipment & Supplies
k24674
jasbo
jasbo
