Question about Roper RT12VKX Top Freezer Refrigerator
Parts diagram where can I find parts diagrams for Roper refrigerators: RT12VKX and RT12DKY??
  • suz4sure Oct 01, 2008
    I have a Roper with the freezer on top and the freezer leaks water into the refrigerator. I need a diagram for parts to see if it is missing a catch pan or sonething! The water drips through the open holes in the middle of the top of the frig and fills the drawers full of water!
  • 478 Answers
  • mark milligan
    mark milligan Mar 12, 2009
    www,sears.com/parts
How can i get a diagram to show me how to put new part on my roper refrig.
go to appliance pros.com they will show a diagram of your model
Apr 09, 2014 | Roper Refrigerators
Loud noise when unit stops. what is it?
Good day,
If it makes a loud clanking or rapping sound when shutting down, it is usually a broken spring inside the compressor itself. Pull the machine out when it is running and see if you can isolate it to the compressor itself.
If that's the case, there is no way unfortunately to repair it except replacing the compressor.
Oct 27, 2010 | Roper RT12VKX Top Freezer Refrigerator
Sometimes water is flooding to the bottom of the refrigerator.. I know the drain hose is stopped up. I found one end at the bottom in the back. However I can't locate the drain in the freezer to blow out...
The drain is behind the panel inside the back of the freezer. It is under the coil. You may need to run hot water through the drain line to defrost it before you can blow it out. Good luck
Apr 30, 2010 | Roper RT12VKX Top Freezer Refrigerator
Will a broken bulb inside turn the frig off
no bulb is just an on and off switch if bulb broke because someone hit it check the thermostat possible loose connection most units have both light and stat in same housing
Oct 31, 2009 | Roper RT12VKX Top Freezer Refrigerator
SLOW WATER SPILL IN THE FREEZER. FRIDGE CONKED OUT
It should go on through . Whatever got on the coil (probably nothing) will get gone on the next defrost cycle. There should be no damage, except to your boyfriend's pride.
Best regards to you both, --W/D--
Aug 03, 2009 | Roper RT12VKX Top Freezer Refrigerator
Icemaker leaks water into bucket when it dumps ice
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the second one.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Apr 09, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Need to install defrost Timer
Check the following link for internal diagrams for this model
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=251062
On the left side bottom in "search by keyword" enter "defrost timer" and the display will show you the location and the part name in the diagram.
Please do rate my solution also please do post your comments on this solution.Good luck.
Apr 08, 2009 | Roper RT14DKX Top Freezer Refrigerator
Fridge doesn't get cold enough
 If the evaporator fan is not running. The fan itself could be faulty or the door operated light/fan switch could be faulty.
If the evaporator fan is running. The fridge is not defrosting and ice has built up on the evaporator and the air is not circulating properly into the fridge compartment. The fan circulates cold air into the fridge and back through the fridge control which is normally just an adjustable flap which allows more or less cold into the fridge depending on the setting. If the fridge is not defrosting, the defrost timer could be faulty or heater element could be blown.
Nov 03, 2007 | Roper RT12VKX Top Freezer Refrigerator
Roper refrigerator leaking from pipe
hey moses, how old is the unit?? what it sounds like is that the unit is low on refrigerant, if the pipe that is cold is one of the coper pipes that are part of the sealed system. if this is the case there is not enough "gas" to keep it compressed untill it reaches the evaperator in the freezer compartment. Some units have a sealed sytem warranty for 5 or 10 years. parts and materials would be covered but labour is not. you need to be licensed to handle refrigerant so you will need to call a tech.if it is a plastic tube it is the drain and there should be a catch tray under it that allows the excess water to evaporate. hope it helps.
Sep 24, 2007 | Roper RT12VKX Top Freezer Refrigerator
Roper RT12VKX Top Freezer Refrigerator Logo
726 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
