Question about Motorola Mobility MPx200 Pocket PC
Locked phone Changed the orange sim to another orange sim, and all i,ve got now is when you turn it on it just stays on the motorola screen,and it won,t turn of until you take battery out.
0 characters
1 Points
What is puk code samsung orange?
The PUK code belongs to your sim card. When you buy a new sim card you get a new pin and a new puk code. The pin you can change, the puk stays the same. You need the puk, after your phone is locked because you entered a wrong pin 3 times in a row.
Look in the box your phone came in. On the card your sim came out, you find the PUK.
May 10, 2014 | PDAs
Sim card problem
What's the problem with your sim card..As far as I know there are two possibilities to get this kind of error message.One is poor signal of that respective network for which you just need to switch OFF and ON your mobile and the mobile will be able to receive the signal from near by tower.You may also get this error message when you are trying to insert a sim other than which the mobile is locked to.To solve this problem you need to unlock the phone from that particular network or use the same sim to which the mobile is locked to.To unlock your Motorola phone purchase unlock code from any vendors online like
Feb 27, 2014 | Motorola PDAs
Code passwod unlock
The unlock code is different for each mobile phone.
You need to scan the Sim Card and look-up the unlock code for your phone. The only two options that you have as alternates are to format the Sim Card or buy a new Sim Card.
Sep 19, 2013 | Motorola Mobility W173 Unlocked Cell Phone...
How to setup my Orange sim card in TMobile nokia
You have to unlock your Nokia E61 from T-Mobile network lock....Visit the site get the unlock code and unlock your Phone from network lock,Then use with other network sim card like Orange...
Oct 01, 2012 | Nokia E61 Smartphone
How can i Motorola MOTOROKR E6 unlock??
There are lot of ways to UNLOCK THE phone from NETWORK lock,But Unlock code is best in that,Specify the Network and Country it locked now?
Get the NETWORK unlock code from here and follow the instructions below and Unlock it step by step!!!!
Warning : Do not enter any wrong unlock codes on your Motorola E6 mobile phones. If you enter over a certain amount of wrong unlock codes on your Motorola E6 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Motorola E6 with a NOT ACCEPTED SIM Card,
2 - Phone will display "Enter Special Code",
3 - You can now enter the Unlock Code.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Motorola E6 is locked to.
WARNING: If one of theses messages appear :
- "Contact Service Provider"
- "Tampert Alter"
- "Wait before enter special Code"
- "Contact Service'
Aug 29, 2011 | Motorola Mobility MOTOROKR E6
Please my phone doesn't read other sim cards from from different operetors please what can i do to make it read the sim cards.
Your phone is Operator-locked by default. Only a firmware upgrade would help you unlock your phone. If your phone is not under warranty and if you are not using Orange's phone service, approach a local mobile phone service center and ask for unlocking the phone.
Many mobile phone service shops unlock the phones for a fee.
Mar 06, 2011 | Orange SPV M3100 Smartphone
Uk unlocked blackberry 8310. call failed
Are you sure your phone is unlock properly ?
check the status of your set & also call orange for Vendor ID.
This site will help you a lot in every thing
Feb 02, 2010 | RIM BlackBerry Curve 8310 Smartphone
I turn my phone phone on and it says invalid usim card and not let me on my phone how do i get my phone to work ?
the sim is either not of the same network that the phone is locked to , ie orange phone orange sim or the phone was lost or stolen and is now blocked and will not accept any sim in uk ,(ever) , the phone will still work in japan and america , also india though
Jun 05, 2009 | LG KU990 Viewty
Non tmobile sim card?
I assume you are asking about unlocking your phone. If you are a tmobile user than any tmobile sim will work in your phone even if your phone is locked. When a foreign or different compatible sim is inserted your phone will ask for the unlock code if your phone is locked. When you have an unlocked phone it automatically accepts the sim and does not ask for the unlock code since your phone is unlocked.
Jul 05, 2008 | Orange SPV M2000 Pocket PC
Unlocking my HTC S710
Turn off your phone, then press both soft keys next to D-Pad. (these are the buttons above the number 1 and 3 on your key pad) and power on device. After moment a black screen will appear and offer to restore basic settings. release both soft keys. NOTE you will clear the phone completely!!!!!!!!!!!!!!!!!!!!!!!
press "green phone" button and wait couple minutes for phone to initialize. good luck
Jun 22, 2008 | HTC S710 Smartphone
Motorola Mobility MPx200 Pocket PC Logo
19 people viewed this question
Top Motorola Mobility PDAs Experts
David Payne
David Payne
Abby Carter
Are you a Motorola Mobility PDA Expert? Answer questions, earn points and help others
