Central heating my horstmann centaur c11 central heating unit has turned off its display and is just showing a red light.
Hi, l doubt this is still an issue for you and l'm certainly no electrician. But many timers seem to be packing in regularly, of all different brands.
I saw a forum post that directed me to this website: http://www.seered.co.uk/sunvic.htm
I have had a similar problem with a Drayton SM2 timer - it is basically roasting itself as l speak, and yes l got the red light problem too, light came on, but no heating on, funny smell too. Solved it by flicking the fuse switch on and off (the switch that controls the entire house's electricity). I think powercuts might have something to do with all of this, who knows? But according to the website above, plain shoddy components are the real problem, and yes, the manufacturing companies all seem to be aware of your problems already, however much they deny it when you phone them up and they are chomping away on a sarnie and dismissing your concerns. Make sure you point out if you still have the timer on warranty and get a new one free of charge, pronto.
And think twice before an electrician tells you it could be a fault with the entire house's wiring. No ... everyone but you and l seem to be aware that timers just break because of their shoddy manufacture. Of course yes it could be a wider problem with the house's wiring, or even the powercuts that l mentioned. Just keep an open mind and don't get ripped off by the manufacturers or the electrician, both vultures l tell thee!
Posted on Aug 18, 2010
Can I put my central heating on a different time from my water horstmann didam 425
It appears there are 4 trippers on the daily time dial that control all timing. 2 On and 2 OFF
On the right side are override switches for Hot water and Heating
You can only separate Hot water and Heater programming a little bit.
You can choose to have Hot water ON all day, or turn on-off once per day or turn on-off twice a day. Or OFF all day.
The Heater has the same options and the same on-off times as the Hot water.
Manual:
http://www.horstmann.co.uk/files/2513/9867/2118/user_guide_425-TiaraDiadem1.pdf
For fully separate programming, where Hot water and Heater can each be programmed differently, you would need a 2-channel controller like the Grasslin QE2
http://www.grasslin-controls.co.uk/towerchronqe2.html
http://waterheatertimer.org/pdf/Grasslin-QE1-QE2_GB-instructions.pdf
Gene
Oct 11, 2014 | Water Heaters
We have a horstmann 525 and can't get the heating
TURN POWER OFF FOR 30 SECONDS THEN BACK ON & TRY AGAIN.
Dec 27, 2012 | Heating & Cooling
Vaillant Boiler 628 suppling no Central Heating
If the zone valve was replaced and wired correctly then it is likely the zone controller if u have one. Manually open the valve and turn the tstat up if it begins to circulate then it is a controller issue. If you still get no heat (circulation) than it is the circulator pump or the pumps controller. Its best to test those individual parts with a multimeter to avoid buying parts not needed
Nov 29, 2017 | Water Heaters
How do i change an old style honeywell room stat
Shut the furnace off for starters. Remove the old Thermostat. As you remove each wire write down what terminal it wen to.
Example:
Red wire usually goes to R-Power
Green Wire usually goes to G-Fan
White usually goes to W-Heat
Blue or Yellow usually goes to Y-Cool
Jan 04, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
I need an operators manual for a centaur plus central heating system NLC 17 to get the heating up and running, and to set the timer clock, this is for a large building, it is a royal british legion club.
http://www.heatingcontrolsonline.co.uk/horstmann-centaurplus-c17-day-timeswitch-p-303.html
let me know if you can either open or copy and paste this link. You should see a blue link on the web page then that says "Please click here to download the user guide" i believe you will need to have abobe acrobat reader installed to view the file, you can also save it to your computer then. Hope this is what you were looking for and hope it helps you out. Tom
Dec 02, 2009 | Hardware & Accessories
Central air unit/ Lux500 thermostat
There is usually an overflow tray which has a shutoff valve when the tray is about to overflow water into your house. It is not located outside on your unit but inside where ever the condenser unit is. IF that tray is full of water, your unit will not turn on until it is emptied. Then you need to find out why the tray isn't draining...do you have a blocked drain pipe?
Jun 21, 2009 | Jackson 25 in. TempStar HH70 Free-standing...
Central heat/air unit for home blows cold air
could just be heat trapped in ductwork for attic temp or from not running for more than a few hours.
Jan 13, 2009 | Haier HC48C1VAR Central Air Conditioner
Temp display shows 444
If everything on your B1691N0GB oven seems to be working, i.e. all the lights are on and fan comes on in fan oven setting, but there is no heat from fan oven, conventional oven or grill, try turning your oven off at the mains, then turn on again. If the temperature display then shows 444, your oven is locked. To unlock, make sure the central control knob is in the "out" position, then press the fan oven and light buttons simultaneously for 10 seconds or so, until 333 appears on the display. Your oven is now unlocked.
Apr 08, 2008 | Neff B1641 Single circotherm super...
197 people viewed this question
k24674
jasbo
jasbo
