Question about Canon Pixma iP4500 InkJet Printer
PRINTER REFUSES TO PRINT YELLOW
HI
THIS IS THE SECOND PRINTER THAT I HAVE BOUGHT THAT IS GIVING ME THIS PROBLEM.
AFTER THE ORIGINAL CARTRIDGEDS HAVE FINISHED I REPLACED THEM WITH COMPATIBLE TANKS WITH THE SAME CHIP AND, JUST RELEASED THE PRINTER FROM DETECTING THE TANK AS BEING EMPTY.
IT PRINTED FINE FOR AWHILE BUT THEN THE YELLOW GOT LIGHTER AND STOPPED ALTOGETHER.
THERE IS PLENTY INK IN THE TANK, AND THE JET IS CLEAR, BUT IT REFUSES TO PRINT YELLOW! - IS THIS SOME SORT OF FAILSAFE CANNON HAVE IMPLEMENTED? CAN ANY BODY PLEASE HELP????
    Guru:
  • 859 Answers
Derrick, Came across something the other day and thought of you even though we know that there are a lot of yellow tanks with bad chips in them.
Lift the ink tank carriage body up and expose the print head, there is a lever to lift up and pull out the print head. Now soak that print head in ammonia for several hours and then rinse it out with a warm water jet, using a water wand or just the faucet head. The print head has a rather large hole with a screen to accept the ink from the tank. You can wipe it off and blow it out using your mouth too, just don't **** on it. Canned air is the way to go and blow the canned air on the bottom too and then wipe the print head forward and to the right on a paper towel damp with rubbing alcohol. Do this until you are getting some yellow color easily. Then reinsert the yellow print head.
Now, put everything back and latch it down. Unplug the printer pulling the cord from the back. Hold the OK and Cancel/reset button down at the same time and reinsert the power cord. Hodl these buttons down for about six seconds until the lights blink or you get a message and then release. Now press and hold the On button down for five seconds. Now, turn the printer off and wait until its finished. Unplug the cord from the back and leave it out for 20 minutes, then reattach the power cord and turn the printer on and print a test page using the menu. See if your yellow is okay now.
Regards,
Worldvet
Posted on Jan 26, 2009
Unrecognized ink cartridge
The problem with generic print cartridges are they are hit and miss. Every time you replace a cartridge ideally you should replace the print head with a new one ( little metal connector on the cartridge). When using a generic cartridge the print head isn't new nor original and the printer may realise this depending on the print head condition.
another point to watch is, using generic cartridges void your printer warranty, assuming its in warranty. Generic cartridges are a quick fix but not reliable.
Mar 23, 2014 | Office Equipment & Supplies
My printer was printing pictures great... until we had to change one of the cartridges. Now we're having trouble gettting the pictures to look as good as they did originally. Anything we can do to fix...
you must use the original toner cartridges, if you want to have a best results. Not original toner must be removed from printer. Call to professional.
Dec 17, 2009 | Samsung CLP 315 Laser Printer
Installed new yellow print cartridge for HP printer, prompts to install new cartridge but my ink level says full
I have this same problem and some sites said to uninstall the software then download the software from the HP site and reinstall it. So I am giving that a try tonight
May 29, 2009 | HP Photosmart C5180 All-In-One InkJet...
Can't switch up my Canon iP3000 printer
Problem solved - I bought a new printer. On a long run it is cheaper.   Thanks    Mila
Apr 10, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Printer paused-unable to read
HI there,
1. First, clean your printer. Get some spray-n-wipe cleaner and a clean cloth and clean the entire inside of the printer. Also ensure your paper isn't dirty. Now print a test page. Does the symptom persist?
2. Remove all jammed paper. Check the paper tray first. Look closely at the paper rollers nearest where the paper exits the printer; this is a common source of jams. If you’re trying to print labels, they will often jam just before exiting the printer.
3. Try to print a test page. Does the printer still jam? If you can find no source of the jamming, check the printer's message display window and refer to your user’s manual to look up the printer error code.
Oct 04, 2008 | Brother HL-2070N Laser Printer
Cartridge
whats your printer model?clean the catridge contacts and the print head insert it again properly then switch off and on,do a hard reset from the menu button ,and make sure your using a genuine catridge most especially if your printer is hp product.that should work
Aug 23, 2008 | HP OfficeJet 6310 All-in-One Printer...
Cartridge
did you do a clean cartridge and re alignment first?
http://tinyurl.com/6qcpgy
Aug 08, 2008 | HP PSC 1410 All-In-One InkJet Printer
Printer refuses to print Error Message
i suggest you inspect the bottom, to see if anything is compromising the connection pad.
Feb 27, 2008 | HP DeskJet 950c InkJet Printer
Printer refuses to print black
Hi, I have question?
The ink that yuo are change are original epson cartidge ink?If yes , try to head cleaning twice and then nozzle check ,then the result of test print are soild in color are good , the unclean head having plenty spaces within the color in test print.
Jan 07, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Canon Pixma iP4500 InkJet Printer Logo
165 people viewed this question
old marine
old marine
