Question about Dryers
Hi, I ahve a creda tumble dryer T60CW which has sunddenly stopped getting hot. Is this a problem I can fix or do I just by another
  • richardvic Jan 14, 2009
    Sorry its T630cw but no letters
  • Barry Coates
    Barry Coates May 11, 2010
    Can you confirm the mod number, as I do not recognize it?.
    After the T there is usually another letter preceding the number
  • 3,463 Answers
It is more than likely going to be one of 2 things, the stats and /or the heater element need replacing.
You will find these located behind a removable panel at the rear of the dryer.
You need a meter to test them for continuity, it is more likely to be the stats as opposed to the heater element.Disconnect 1 wire from each stat to test them.
Plz rate my solution.
Posted on Jan 15, 2009
How to fit belt on Creda Reversair 37643 Tumble dryer
New belt is very tight, so you have to use more strength. Put it on motor and all other on "drum". Spin it easily and slowly but with strength until its done.
Be carefully, use gloves.
Apr 13, 2013 | Indesit Hotpoint Creda Tumble Dryer Belt...
Hi the door catch for my Creda T522VA Simplicity dryer has broken - where can I get a replacement?
hope it helps
Jul 05, 2010 | Dryers
My creda reverseair tumberledryer won';t work. my
If you can hear the motor running and have also checked the belt tension and they are O.K., then the only thing I can think of is the Motor pulley, where the belt sits on.
Check that out and make sure it is not loose on the motor shaft, so that the motor turns but the pulley slips.
Nov 09, 2009 | Creda IWD12 Front Load Washer / Dryer
No hot air from my tumble dryer
You do not state whether it is a condenser or vented dryer.
the most obvious reasn for no heat is element and/or stats..
The only way to confirm which it is-- is to meter them out with a multi meter..
If you have one then set it on the ohms range and test the components for continuity, you should get full scale deflection if they are o/k.
You must disconnect the wires to the components, or you will get a false reading, and needless to say, have the m/c unplugged.
If all test o/k then the problem could be with the timer and or control unit, or the heater relay if it has one.Unknown to me as I do not know your model number.
If it is a condenser dryer, make sure all filters are clear, air intake and outlet vents clear, water container empty .
Dec 29, 2008 | Dryers
put it in the bin
Sep 12, 2008 | Dryers
Tumble dryer
Check the thermostats. Could also be a reset-able overheating thermostat that needs to be reset.
Jan 20, 2008 | Dryers
Dryers Logo
73 people viewed this question
Top Dryers Experts
