Question about Sony KP-53S25 53" Rear Projection Television
Sony projection tv mod. no.KPR-S53MH1 wire diagram
Plese send me wire diagram Sony KPR-S53MH1
4 Suggested Answers
wyoed1
  • 211 Answers
SOURCE: SONY
It sounds as though you have a damaged the main board ( power supply board). First I would suggest you check the fuses, in both the main board and also the convergence board ( there are two main boards in your set ). Before you start, always use caution by unplugging the set from the wall. To check the fuses, remove the bottom panel cover in the back of the set by removing the screws. Use a flashlight and observe all the fuses you can find and see if any are opened or burned out. ( if the fuse is burned out, it will be black, you may not be able to see if the fuse is just opened without using a continuity checker ( volt ohm meter ) ). Any fuses you find open or burned out, replace with a like fuse ( voltage and amperage ). The set should work fine if a fuse is the problem. If the set doesn't have a bad fuse or won't work after replacing a bad fuse, then you will probably have to seek professional help. Check www.sony.com for service in your area. Good luck. I hope this has helped.
Ed
NC Electronics
Mills, Wyoming
Posted on Feb 18, 2008
  • 298 Answers
SOURCE: Looking for lights....
You can find replacement parts for this model from the following Sony OEM parts distributor. Here's the links to order the original Sony blue CRT, green CRT, and red CRT (the 3 "light bulbs") for this model from that major parts distributor if needed:
Sony KPR-53CX35 Replacement Part Blue CRT Bulb / Lamp
Sony KPR-53CX35 Replacement Part Green CRT Bulb / Lamp
Sony KPR-53CX35 Replacement Part Red CRT Bulb / Lamp
Posted on Apr 01, 2009
sethdileswar
  • 253 Answers
SOURCE: i have SONY KPR-S53SN1 rear projection tv.it have
pls, check magnet ring wchich is locate on picture of nack, and for folding problem pls check horizantal section
Posted on Apr 05, 2010
Kpr-46cx10 picture issues
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Televison & Video
I Got a Sony Projection TV Mod. KDF_E60A20 that's
lamp is probably at the end of it's life replace it.
Sep 15, 2009 | Televison & Video
Apr 01, 2009 | Televison & Video
PROJECTORS UNALIGNED(SONY)
Not sure what your asking here?
Marc Engineer
Mar 24, 2009 | Panasonic CT-20G22 20" TV
Color distortion for Sony KPR-46cx35
there maybe cold solder around the chroma section, or in the CRT board....
Aug 11, 2008 | Televison & Video
Sony kdf55-wf655
I hit the "display" on the remote for the Sony TV
Jan 23, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
SONY KPR-46CX35
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
· http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Dec 15, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
KPR-53ex35
Your black and white board may need to be replaced.
Dec 11, 2007 | Sony KP-53V35 53" Rear Projection...
Open Questions:
See all Sony KP-53S25 53" Rear Projection Television Questions
Televison & Video Logo
226 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
