Question about Fuji FinePix S700 Digital Camera
Fuji s5700 my flash is not popping up on auto
Hi My Fuji S5700, is set on auto flash.
The flash does work but i have to hold it up manually.
It pops slightly up but wont stay in the open position.
Can you help????
  • 3 more comments
  • Anonymous Jan 22, 2009
    My issue is the same as yours! Very frustrating. Seems like it would be simple to fix, but haven't found someone yet without at least 6 hr turnaround time.
  • ag0131 Feb 21, 2009
    hi i have the same problem, but i can see that one part into the flash auto pop up system is broken. I need the ******* service manual but i cant-t find it.
    thanks a lot!!
    From Colombia
  • jdMaint Feb 22, 2009
    exact same problem flash must be held/propped up to take flash pictures.
  • Adrienne Keiffer Apr 18, 2009
    My flash is ownly partially popping up and I have to hold it up to use it. I still have my owner's manual and it doesn't really discuss that issue. Unfortunately, I've had my camera JUST over a year so my warranty is null and void. I REALLY love this camera other than that!!
  • brimest0ne May 21, 2009
    Yup, I have the same problem on my s700, it will release the flash and if I hold it up it will go off. It worked one day and not the next, but seems no one has an answer to the problem yet.
  • 4 Answers
Don't blame the Fuji Designers for this fault - it was the Fuji Bean Counters that are at fault - the flash design is for TWO springs, the plastic casting has the holes for a second spring on the other side - which wasn't fitted so 100% overloaded the single spring mount.
Anyway if you are brave and handy you CAN fix this.
First remove the back of the camera - 3 screws in battery bay, 1 in the side above the memory card door, The two rear most on the bottom, two in the USB/video door, and the rear most on the left hand carry strap bracket.
Carefully prise the back rearward about 5 to 8 mm.
Now take a look at the two screw holes under the flash (when popped - or flopped out now that is broken) now go and bend a screwdriver of the type you used for the previous screws - you will need a 90 degree bend very close to the tip to fit in this gap and be able to turn the screws a few degrees at at time.
A little at a time lock the screwdriver into the screws and undo until the flash cover comes off.
You can then slide the shaft out of the flash to release the spring which will have the end that should fit into the broken bracket now sitting proud..
Make a suitable bracket like the one in the photo attached to slide over the broken plastic bracket.
make sure it fits really well the epoxy into position.
Getting the spring back in is a fiddly job - I found the best way was to fit the end of the spring into the new bracket, slide the shaft just into the spring - the lever the other end of the spring down into the back of the flash body and then slide the shaft all the way into place.
I did have to file down the little plastic "blade" inside the lid which presumably is designed to assist the the (now broken) bracket from breaking....
reverse the dis-assembly and now you should have a working flash Fuji s5700 my flash is not popping up on auto - bb61266_2.jpgbb61266_1.jpg
Posted on Dec 05, 2010
    Problem Solver:
  • 8 Answers
I e-mailed Fuji, turns out my camera has a 3year warranty, so I'm sending it in, Free fix plus the cost on shipping, but hay, I can accept that.
Posted on Jun 12, 2009
If it is of any use to anyone i have found the service manual for this camera. Costs about £6 but is immediate download in pdf format.
To go to the webpage follow the link below
http://store.payloadz.com/str-asp-i.200706-n.Fujifilm_Fuji_Finepix_S5700_S700_Digital_Camera_Complete_Service_Repair_Maintenance_Manual_eBooks_-end-detail.html
hope this is of use all the best
Posted on Apr 13, 2009
Http://www.siue.edu/lovejoylibrary/avs/pdf/FUJIFILM_DIGITAL_CAMERA.pdf Here is the manul but it still not hlping
Posted on Jun 08, 2009
    Problem Solver:
  • 5 Answers
Dear all,
If the camera is in warranty, Plz contact ur nearest Service Centre
for details plz feel free to mail : mdshamim2@yahoo.co.in
9339200878
Posted on Feb 20, 2009
How do I tell if firmware 1.01 is installed on my fuji S5700 camera?
Holding down the Back button while turning the camera on will display the firmwareversion.
Apr 24, 2010 | Fuji FinePix S5700 Digital Camera
had a run in with fuji myself.. if it's going to cost that much to fix. you might as well get a new camera. they don't seem to care to fix or replace parts on their cameras
May 30, 2009 | Fuji FinePix S700 Digital Camera
Night shoot and Indoor photo quality is not good with Fuji S5700
Your Sony camera must be more noise-free at high Iso settings than the S5700. As you view your shots on the camera, press the button with the square and the +/- symbol in it. Now you can see what Iso setting the pic was taken at. The 400, 800 and 1600 settings are all noisy on this camera. The only solution is to use a tripod with long shutter time and Iso 200 or less.
Apr 01, 2009 | Fuji FinePix S5700 Digital Camera
Flash isnt working finepix s5700
try to pull it up to get it out and then choose the lightning button to activate flash....
Nov 11, 2008 | Fuji FinePix S5700 Digital Camera
Changing Shutter Speeds
The +/- button is located on the bottom right corner on the back of the cam. If you do not find it on your cam, probably "you are not using a Genuine Fuji S5700".
Aug 07, 2008 | Fuji FinePix S5700 Digital Camera
Accessories for Fuji Fine pix S5800
You Can not put additional flash on S5600, S5700 and S5800.
Jun 18, 2008 | Fuji Finepix S5800 Digital Camera
Fuji FinePix S700 Digital Camera Logo
1,529 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
