Question about Fedders X Chassis A6X05F2B Air Conditioner
No power plug in to 220volts instead to 110volts. stop working
Probably blew out the thermistat and the compressor, along with the the capacitor. Probably not worth the repair. good Luck
Posted on Jun 13, 2007
They plug it 110volts to 220volts
if the unit is built for 110 bolts and it is plugged into 220 volts, either the unit or the outlet circuit breaker is the problem. Circuit breaker can be reset - not so much for the coffee maker.
Check the circuit breaker and then see if another appliance will work. If not, the circuit needs troubleshooting. If the circuit works, then have the coffee maker serviced.
Mar 06, 2015 | Keurig Platinum B70 Coffee Maker
110volts face lifting machine plugged in to 220volts..can it be repaired?
ck to see if it is fused , you may get lucky if not did you smell something burning when you did it , if so you burned it up ,trash it ,
Dec 26, 2014 | Office Equipment & Supplies
Hi, i want to purchased a microtek ups and i want to bring it to my home town in the philippines but im not sure about on how to install it the proper way. can you send me a wiring diagram on how to...
in the philippines were using 220volts you must first identify the voltage rating of your ups if its 110volts or 220volts if 220 you just plug it in just remove the metal ground extending in your plug the round in the middle.
Oct 10, 2010 | Kitchen Ranges
MY DRYER TAKES A LONG TIME TO DRY CLOTHES. HAD IT FOR 5 YEARS. MOVEDTO NEW HOUSE AND HAD TO CHANGE POWER CORD BUT IT WORKED FINE AT FIRST. DO I NEED A NEW HEATING ELEMENT?
It sounds like you may have hooked it up to 110volts while most dryers need to run on 220volts. If your new house has gas then a gas dryer would run on 110volts as it gets it's heat from the gas flame. If this is the case you would need to run a new 220volt line to the unit. this can be costley and you may be better off trading your electric one for a gas one as that will probally be cheaper to run in the long run.
Aug 21, 2009 | Dryers
Power requirement for the imageRUNNER 400s
it depends which country the IR 400 was installed ,there are two types of Power supply
110volts-50/60 hertz
220volts/240volts 50 Hertz
if you have 110v machine and you want to connect it 220v supply you can use a 1.5kw stepdown transformer
Jun 30, 2009 | Canon imageRUNNER 400S Copier
KENMORE DRYER MODEL #96263800 WON'T HEAT
Need to know brand name and model#..........but it sounds like your only getting 110volts to the dryer instead of 220volts........The moter and controls will run on 110v. but the heaters require 220v. carfully remove small cover on back or if you have a outlet(wall plug) you must check for 220volt...PROBABLE CAUSE 1 fuse blown,,,, or bad circiut breaker. FIRST is there 220v. at plug This will tell us if it's a wiring prob. or dryer prob.
Mar 25, 2009 | Kenmore 62602 Electric Dryer
Dead set of beosound 4000
an expensive repair,at least power pcb and maybe even contol pcb also
Feb 17, 2009 | Bang and Olufsen Beosound 4000 Shelf...
Nintendo64
Time for another one, You probably fried the mainboard.
Apr 18, 2008 | Nintendo 64 Console
Power plug
I think that the console got fired by now then.
Apr 17, 2008 | Nintendo 64 Console
Fedders X Chassis A6X05F2B Air Conditioner Logo
124 people viewed this question
Top Fedders Heating & Cooling Experts
Donni Steen
Sheldon Dedek
Mike
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
