Question about Canon CFX-L4000 Plain Paper Laser Fax
Check printer sendng fax no problem but when it start printing im getting a msg of ##324
  • 2 more comments
  • zalo casilang Jun 24, 2007
    msg 324 explain its about the scanner assembly im waiting for the part i will replace before i will go to the fuser thanks
  • zalo casilang Jul 15, 2007
    I replace the scanner assembly fixthe problem
    the scanner assembly was theproblemas the msg 324 was about.
    I had a Sony Viao Laptop model PCG-R505JL WONT POWER UP CHECK POWER ADAPTER GOOD.
  • 186 Answers
The machine probably needs a new fuser assembly. Not easy or cheap!
Posted on Jun 21, 2007
Incoming fax does not print, and also cannot get printout of faxes received. Memory was received. Regular printing and photocopying works fine.
if you found the msg on lcd like "toner empty" & red light near the lcd
then you have to reset toner counter through tech mode.
MENU # 1 9 3 4 MENU pres continues you will find tech mode on lcd
then press 3 times right arrow key "new cartridge" will come on lcd bottom line
then press 2 times ENTER button & swicth of the macine for 5 second then on
all samsung mfds stop printing FAX when "TONER EMPTY" msg comes.
Feb 10, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Check printer msg and audible alarm sounds. If I unplug the fax and wait 30 seconds and plug it back in alarm stops and check printer display is gone
If its a ## error its a internal fault like the fuser or laser!If it the fuser just before it starts to print it will say check printer and stop!Take it to the nearest dealer and let them have a look at it!
Apr 16, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
I have Panasonic KX-FL612 fax machine , the paper gets jammed and the fax is saved in memory . when i release the jammed paper I can not print the fax in memory . How can I print the fax in memory ?
when fax gives msg ,fax in memory,just remove jammed paper .put fresh papers in tray.if the msg is coming on screen that fax in memory just press START key.there is a green button labeled as fax start .u will receive all faxes in memory.MIAN AKHLAQ .do not forget to rate the solution.
May 13, 2009 | Panasonic Office Equipment & Supplies
CHECK PRINT ##324
This error is a laser motor error. You can try to lube the laser bearings by taking apart the laser assembly, most likely you will need to get a replacement
Feb 25, 2009 | Canon LaserClass 2060P Plain Paper Fax
Pc fax msg
The display msg means that there are a few faxes in storage and they just need to be printed from the memory:
on my mfc-7440n:
Printing a fax from the
memory 6
If you are using the Fax Storage feature
(Menu, 2, 5, 1), you can still print a fax from
the memory when you are at your machine.
a Press Menu, 2, 5, 3.
Remote Fax Opt
3.Print Fax
b Press Start.
c Press Stop/Exit.
Aug 07, 2008 | Brother MFC 7420 All-In-One Laser Printer
Keep saying check printer
5.5.3.3 ##324 [Rx] Printer section scanner motor rotation rate abnormal 0003-5251
Cause
An internal mechanism is faulty.
Remedy
1) Check the connection between the laser scanner unit (J802) and SCNT board (J6).
2) Replace the laser scanner unit.
3) Replace the SCNT board.
Jun 05, 2008 | Canon L220 Plain Paper Laser Fax
Msg
I'm not that familiar with your model, however, the ##324 error is a scanner failure. On some of the Canon models, there is a provision in the menu for re-calibrating the scanner. You try this but I can't guarantee it will fix your problem. If I'm thinking right, your model corresponds to the Hp LaserJet 3100 series (but then again, why should I start thinking right now?). They where notorious for that problem. You'll need a blank sheet of white paper, look through the menu to find "calibrate scanner". I'm still trying to find more information on this, but I don't have it yet Hope it helps Ed
Jun 10, 2007 | Canon CFX-L4000 Plain Paper Laser Fax
Canon CFX-L4000 Plain Paper Laser Fax Logo
161 people viewed this question
Clive
Clive
old marine
old marine
