Question about Ultra Products Ultra Defender Intel Gaming Desktop PC - Intel Core 2 Duo E4700, nForce 680iLT SLI, 2GB PC6400, 500G
New builded pc wont install, system is schut down.
DFI NF680ILT board.
EVGA 1GB Screancard in top port 16X, working fine
2 DVD burner
1 80 GB sata disk
INTRL CORE DUO 300
450 WATT powersupply
4 X OCZ REAPER PC2 6400, 4-3-3
We have tryed combinatione in orange slot with ram, we have tryed in the yellov, but the pc very seldomne start to install, and when it goes to install Windows Vista, den it shut down the system, whot are we doing wrong with this board??
I hope you are able to solve this problem for us, becourse we would like to get this high end mashine to run.
Regards
Henrik from Denmark
  • 404 Answers
Hi Henrick,
Are you using the correct spec R.A.M.? or is it faulty.
I relate to your problem and all looks fine apart from memory.
Don't rule out the possibility of a Mother Board fault? I have had similar& severe grief in the past, tried all routes and replaced loads only to find sata circuit connection dry joint/ un soldered. (So New Motherboard under warranty)
Good Luck!
Paul 'W'
Onyer~EDson(:0) {#><U.K.
Posted on Jan 14, 2009
How to install GH22nS50 Rewriter into my computer
These are the steps for installing your optical drive:
1. Remove both side covers on your PC case. 2. Locate a free 5.25 in bay on your desktop computer. This is usually located near the front/top part of a PC ATX case. 3. Remove the front/external cover for your chosen drive bay. This cover is usually not screwed in. You just have to pry it open. 4. Screw in the optical drive to the drive bay. You need 4 screws, 2 on each side. 5. Power connection : Locate a SATA power connector from your power supply and plug this into your new optical drive. The SATA power connector looks like this rjbautista.jpg
6. Data Connection - Locate the SATA ports on your motherboard which looks like this rjbautista_0.jpg
You need to plug in a SATA cable from your motherboard to your new optical drive
SATA power and data ports on the back of the optical drive
7. That's it! Your new optical drive should now work. it's plug n Play so you don't need to install any drivers for this device.
Mar 21, 2011 | LG RETAILSUPER MULTI DVD REWRITER DVD-RAM...
When I hit the power button it wont turn on. I have replaced the RAM with a known working DDR400 1GB stick, no fix. Tried switching power supplies, no fix, tried new videocard since when it was last on (a...
When you say the CMOS is set to reset, this should not be the case for normal usage. and maybe the problem if left in the on position the system will not start (which sounds like your problem).
Mar 18, 2011 | DFI NF4X INFINITY Motherboard
My PC is an IDE. the dvd/cd burner went bad. I baught this new LG burner today with an IDE to SATA adapter with the needed cables. I installed it all and it wont even come on, not working. So I am guessing...
It is not the dvd driver problem but more likely to have the adapter issue. The generic Microsoft cd/dvd dirver should be fine, I never have to install and driver for the replacement DVD/CD drive on any of my repair works.
Did you try this setup with another PC?
http://www.cooldrives.com/satoidecofor.html
Jan 01, 2011 | Computers & Internet
How 2 install in my new hp also have a burner on same cable burner works but both dont work 2gether
a dvd burner on same bus as a hard drive..the cable needs to go to hard drive first then the dvd drive..is that the case? also, if it's SATA, the order on which cable comes from the board to hard drive SATA 0 is critical
Dec 06, 2009 | Maxtor (6L250R0) 250 GB Hard Drive
I want to install a 2nd dvd burner. But I don't know how to hook it up. My new pc does not have the ribbons like my old one does.
If your 2nd DVD burner is on IDE interface, you may need to get an IDE to SATA cable. Please refer to the picture below as to how it looks like:
Oct 29, 2009 | Compaq Presario 5000 PC Desktop
I need sata cd driver software
Check for free down loads from netby of google
Aug 22, 2009 | LG Black 8X BD-ROM 16X DVD-ROM 40X CD-ROM...
Pc died
Hello, I have had similar problems with that same motherboard in the past and have found that resetting the cmos (see users manual) or just taking the battery of the motherboard for a few minutes can solve this. CAUTION please remove the power lead on your tower before touching any components inside, and earth yourself first by touching metal.. as static discharge kills pc components..
Hope this helps.....
Tony.
Sep 09, 2008 | ASUS K8N4-E Deluxe Motherboard
Won't Recognize Blank Maxell DVD+R Disks that I Try to Burn!
sounds like your loose 4 prong may have shorted the burner drive on a power on- it may just be that simple- it died...
Jan 15, 2008 | Lite On Lite-On LH-20A1L-06 SuperAllwrite...
Ultra Products Ultra Defender Intel Gaming Desktop PC - Intel Core 2 Duo E4700, nForce 680iLT SLI, 2GB PC6400, 500G  Logo
61 people viewed this question
Top Ultra Products Computers & Internet Experts
Laxman Bisht
Laxman Bisht
John Hong
John Hong
David Payne
David Payne
Are you an Ultra Products Computer and Internet Expert? Answer questions, earn points and help others
