Question about Nokia 3650
Have a motorola v3X Suddenly not charging
Have tried direct connection via USB to PC get blue flashing light for a second then nothing, do you think its the batterry, cable charger or connection on the phone?
Thankyou
  • 2,071 Answers
Just replaced a new cable or a new charger so you sure where is the defected even if battery defected it will charge but the battery it will not last long.If you replaced already new cable but problem still exist then the problem is the cellphone hub is crack or cold solder,you need to rebuild or resoldered it so it will works normally.
Got to cellphone to perform the soldering.
Hope it may help you;
Regards;
VOTIT
Posted on Jan 28, 2009
Why wont my unit charge?
If it is steady blue then it is ready to be found by your phone. If you see the headset in your phone remove the pairing and repair again. You should hold the multifunction button after turning on until it goes steady blue if you aren't getting a steady blue light in order to pair it.
Jun 26, 2014 | Motorola Mobility Bluetooth Hands Free...
I bought a motorola razr off the street and i dont have the password to unlock it
I remembered fixing my old Motorola by connecting it to a pc with the USB search the internet and find out how to start the phone in the 'Flash' mode then reflash the phone with its firmware but its been a long time since i've done so you will have to find all the stuff on Google to find it
You need to find...
Your Phones Model Firmware
Usb Cable
& Flashing Software (I think motorola supplies it otherwise its 3rd party)
Aug 26, 2009 | Motorola Mobility RAZR V3x Cellular Phone
I have the same problem but I can't enter the debug menu using
I have a Motorola RAZR V3x which has worked reliably for about 3 years. Very recently (having been recharged a couple of hours earlier & without any prior suggestion of impending battery failure), the phone has refused to turn on and attempts to charge it with the factory charger do not even light the blue charge indicator. An attempt to charge it through the computer's USB port lit the blue charge indicator for about 1 second but also failed to charge the battery.
Aug 19, 2009 | Motorola Mobility RAZR V3
Dear forum-freinds, I have Motorola cable modem type SB5101E. From a month ago up to now I can't use my cable Internet because it's been dropping connection after 5-9 minutes after restart. Nothing happens...
If you say the lights are going out on the modem when it boots you off the network then the problem is your modem and not your internet connection, if the modem is new take it back and have them swap it for another one.
Regards.
Jul 01, 2009 | Arris SURFboard SB5101 Cable Modem
How to download java game from PC to Motorola V3x phone?
copy your .jad and .jar files to /a/mobile/kjava/ on your phone. once copied, on your phone, go to games, install new. your done. I use M-explorer to view/edit files on my phone and Jadmaker to convert my .jar files. Note: you must have both .jad and .jar files copied to your phone.
Jul 27, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Motorola V3x won't turn on
ok! battery is problem in your mobile! change the your battery! thats it!
thanking you...........
keep rating meee
Jul 08, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Sony Ericsson K770i Phone won't turn on red light apears on the top left, any suggestions?
This has happened to me twice - the first instance occurred when I'd only had the phone a few days and the second occurred today after months of trouble-free use.
On both occasions the phone wouldn't charge via the mains charger - it wouldn't switch on even when plugged in and neither the battery or the charger were warm to the touch after hours of charging, indicating that nothing was happening.
The solution for me was to connect the phone to my PC via the USB cable - nothing happened at first, the PC didn't recognise the phone and it remained lifeless. However, I left it attached to my PC and after 10-15 minutes it suddenly whirred into life.
The battery was COMPLETELY flat despite my attempts at mains charging, so I let it charge via USB for a while then transferred it to the mains charger. This time the mains charger worked.
I've no idea why, but this has worked for me twice so give it a try.
Jun 07, 2008 | Cell Phones
Dead Creative Zen M
Usually this problem is due to the firmware. When the firmware is updated to version 1.62.02, this problem usually will be corrected. The older firmwares have problems in recognizing the battery and allowing the battery to power the unit.
You will need a wall/AC charger for the operation. Plug in the wall charger and USB cable at the same time. Your Zen should power on when connected to direct AC power via the wall charger. Once it is powered on, connect the USB cable to your computer. Then begin the firmware download.
If your Zen does not power on when connected to the wall charger, your unit is dead and its time to replace it or get the motherboard replaced via one of the Repair services offered on this website.
If the upgrade button on the firmware window is not available, it is also time to replace your motherboard due to corruption of a chip on the board.
Mar 13, 2008 | Creative Labs ZEN Vision:M Digital Media...
Is it really like that?
well that is strange would have to think you may need to download the USB driver from www.motodev.com and see it that allows the phone via pc to recognised the mcard
Jan 29, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Sansa e250 - Won't power up unless connected via USB
Sounds like the battery may have come loose. Remove the 4 screws on the back, remove and reinsert the battery. Charge the device for a few hours. Best of Luck.
Oct 04, 2007 | SanDisk Sansa e250 MP3 Player
Nokia 3650 Logo
146 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
