Question about HP DeskJet 3940 InkJet Photo Printer
HP Deskjet 5850w won't print.
Printer icon in Printers Folder say Door Open. Happened once before. I fixed it with a Hard Reset,but that did not work this time.
  • Anonymous Apr 05, 2009
    i have the same problem...the printer door "Won't Close" and it won't print. i used to just hit the door very hard but that works less and less every time the gets opened i don't know what to do
    Problem Solver:
  • 17 Answers
Hmm normally it should have problem with your door micro switch. you can find it by looking for plunger at side of the door.  i did know exactly but you have to find it. if you found it you can play with the swith push on and off (spring loaded off)  try to push firmly while on the printer see if the problem occurs. if it does not, confirm your door microswitches.
to overcome this you can spray contact cleaner to the switch or putting something to the door which touch the microswitch to make it long and actuate the microsw.
Posted on Mar 06, 2009
HP Deskjet f4100 printing everything too small
Hi Nebin,
Open Control panel >> Printers and Faxes Folder
Right click on Printer icon and click Printer Preferences ( or Printing Preferences )
On Advanced/Layout tab - Select Regular printing ( uncheck option which says Fit to Page )
Try to print.
Regards,
Sean
Apr 19, 2013 | HP DeskJet Office Equipment & Supplies
Cannot get HP Deskjet F4280 to print in Windows XP
Please try this steps below.
At first switch off the printer then Open Control Panel from windows Start menu after that open the Printer folder then right click on the printer icon select properties after that delete all pending print jobs after that try this steps below.
Click "Start"
Click "Run.."
Type in "services.msc"
Click OK
Find Print Spooler in the list of services
Right Click on it and select "Stop"
Once the service has stopped, restart it by right clicking and selecting "Start"
Shur down and power on the Printer.
Aug 28, 2012 | HP DeskJet F4280 All In One Printer InkJet
My deskjet 5550 printer stopped printing in color it only print black ink i have replaced the color cartridge still only prints in blank only; i have tried calibrate printer and clean cartridge options;...
If the Cartridge and printer alignment is successfull and you are still not able to print in color, mostly the Color print is disabled in your pc
Click on START Button
Click on CONTROL PANEL
Open Printers and Faxes folder
Highlight the Printer icon for Deskjet
Right click on the printer icon and choose Printing Preferences
Under Printing preferences, you will find Printing mode - It must be on BLACK or GREY SCALE, Change to COLOR/ ALL
try printing.
Jul 03, 2010 | HP DeskJet 5550 InkJet Printer
My printer has a backlog to be printed.I want to erase the backlog and start fresh.When I turn on the printer it starts to print the stuff I don't need anymore.How do I do this?
Pause the printer by taking it offline.
At the bottom right of the screen, you should see a printer icon. Double click on that icon to open the print queue.
Once the queue is open, highlight the print jobs that you want to clear and then delete them.
Don
Nov 23, 2009 | HP DeskJet F4280 All In One Printer InkJet
My printer isnt printin?
If the printer is connected with the usb then just delete the printer icon from the printers folder
then go ahead and remove the USB cable from the computer and plug it back again it will search for printer drivers which are there and an ICON will up
After that u can print
Oct 16, 2009 | HP Deskjet 6940 InkJet Printer
How can I do a test print? on Hp deskjet 9800
>press start
>go to control panel
>go to printers and faxes or printers folder
>right click on your printer icon
>go to properties
>click on print test page button
Sep 23, 2009 | HP DeskJet 9800 InkJet Printer
HP Deskjet 6940 stopped printing
Try This :
Delete the printer icon from the Printer and faxes folder; Disconnect the USB cable (If connected through USB);
Put in the driver disc; Goto my computer; Right click on the black HP logo click on Explore;
Click on UTIL(Folder)- click on CCC(Folder)- Click on Uninstallation L1 ;
Take out the CD restart the computer
Download the sofware from hp.com;
Link:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=467980&lc=en&cc=us&dlc=en&lang=en&cc=us
Select the OS;
Click on download
Save it to your Desktop
Run the software;
Click on Add a Device and reinstall the driver;
This should resolved the issue
Regards
Soumajit
Aug 11, 2009 | HP Hewlett Packard Deskjet 6940 InkJet...
Printer says "door open", but nothing open.
try opening it and unpluging it then plugging it back in
Dec 28, 2008 | HP Deskjet 6940 InkJet Printer
Check printing
Open HP Solution Center, Click Settings ---> Print Settings.
Click Features tab, select the Paper Type as Plain Paper.
Select appropriate Paper Size under Size. Click Ok.
Now Print Cheques from Quicken.
If the issue still persists, Navigate to Printers folder, right click on the printer icon and click Properties. click Advanced tab, enable Print directly to printer. Click Apply.
This should now Print the Cheques.
If the issue still persists, install alternate drivers in Vista.
Here are the steps:
Click Windows logo ---> Control Panel ---> Printers.
1) Click Add Printer
2) Select local printer
3) Choose Port as LPT1
4) Choose HP and then select HP Deskjet 6500
After the driver is installed, perform below steps:
1) Right click on HP Deskjet 6500 printer icon in Printers folder
2) Click on Properties
3) Click on Ports tab
4) Choose USB001
5) Click Apply and click Ok
Now try to print.
Mar 19, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Printer problems
Microsoft Windows XP Click Start and then click Printers and Faxes to open the Printers folder. Locate and double-click the Printer icon (not the fax icon if one is present) for the HP All-in-One. A window opens with a list of print tasks currently assigned to the printer. Highlight the first document in the list and click Printer . If Pause Printing or Use Printer Offline are checked, click to remove the check mark. If the page does not print, click Document and then click Restart . Microsoft Windows 98, Me, and 2000 Click Start , click Settings , and then click Printers to open the Printers folder. Locate and double-click the Print er icon (not the fax icon if one is present) for the all-in-one. A window opens with a list of print tasks currently assigned to the printer. Use the following steps to fix the stalled all-in-one. Step one: Restart the computer Click Start . Click Shut Down . Click Restart or select Restart from the drop-down menu, if available. Click OK . Check the print queue once the machine has restarted. If this step did resolve the issue, you do not need to continue to the next step. If this step did not resolve the issue, continue on to the next step. Step two: Restart the Print Spooler service Open Administrative Tools . For Windows 2000: Click Start . Click Settings . Click Control Panel . Double-click Administrative Tools . For Windows XP: Click Start . Click Control Panel . Click Performance and Maintenance . Click Administrative Tools Double-click Services . Click Print Spooler . Click Stop to stop the service. Click Start to restart the service. Click OK . Restart the computer.
Sep 13, 2007 | HP DeskJet F380 All-In-One Printer
HP DeskJet 3940 InkJet Photo Printer Logo
330 people viewed this question
Ben Johnson
