Question about Sony Cyber-Shot DSC-P32 Digital Camera
Sony dsc-p32 memory limitation?
Net effect: While taking a video with a 1 GB mem stick - got message I was out of memory - checked on my PC - still had 600 MB - only used around 240 MB.
    Sergeant:
    Champion:
  • 326 Answers
Hello, please give me the details of the memory stick. Brand, where did you by it? If it is not the original one... (there are some copies of bad quality - smaller capacity). Thank you, Arpi
Posted on Jun 15, 2007
SOURCE:
I have an sony cybershoot DSC-T 100 8.1 mega pixels I just got a memory stick pro dud 2GB of sony I turned my camera on, and I get memory stick error C:13:01 blinking. What is this, and how do
The root cause may be one of the below listed reason-
1.The internal memory has experienced a media error.Required measure to correct
this, "Turn the set power off and on again".
2.The internal memory has experienced a format error.Required measure to correct
this,"Format the internal memory."Please my blog for more.
Aug 15, 2012 | Sony Cyber-Shot DSC-P32 Digital Camera
I have a Sony digital camera model # DSC S75. I would like the largest memory stick available for still photos. I get confused with GM and MB. I found one for 32 GB, is that the lrgest and about how much...
I did a bit of research on this, and you're going to have to be very careful. Your camera is only compatible with the very first generation of "memory stick". That sounds like a generic term, but it's actually a Sony specification. Please take a look at the wikipedia page on memory stick, and note all the newer versions. Also note that the 'memory stick' is no longer manufactured. Here is a list of memory sizes, I agree that the Mb and Gb are confusing. Each one is double the size of the one before.
8 Mb
16 Mb
32 Mb
64 Mb
128 Mb
256 Mb
512 Mb
1 Gb
2 Gb
4 Gb
8 Gb
16 Gb
32 Gb
64 Gb
Now, you will have to find a genuine Sony "memory stick" and not the Pro, or Duo, or anything like that. When they were manufactured, the largest one was 128 Mb, so that is the limit for your camera. Anything in "Gb" or Gigabytes cannot be a memory stick. I did find 128Mb memory sticks on Amazon. The review page on DPreview will tell you how many pictures you can store on a card half the size, just double it.
Feb 10, 2011 | Sony Cyber-Shot DSC-S75 Digital Camera
Bought used camera Sony Cyber Shot Model DSC-P32. What Memory Stick do I need?
You can use Memory Stick standard, pro or pro duo up to 2GB with the Camera.
    A dedicated adapter (MSAC-M2) must be attached to use Memory Stick Duo™ or MagicGate Memory Stick Duo media.
I have provided the Memory Stick compatibility chart for your reference.
http://esupport.sony.com/US/perl/support-info.pl?&info_id=12&mdl=DSCP32
Feb 09, 2011 | Sony Cyber-Shot DSC-P72 Digital Camera
Sony DSC-P32 Memory Stick Error, "C:13:01"? When I went to review pics on memory card, camera would not scroll through and it would immediately shut off. Assuming it was the batteries, I...
The C:13:01 error code is the self diagnosis display of the camera to identify the cause of the issue with the Camera. This error code indicates the issue with the medium used in the Camera. You can try few steps to check if the issue can be resolved.
Try using different Memory Stick in the Camera.
Make sure that the Memory Stick used is compatible with the Camera. (The maximum capacity that can be used in the Camera is of 2GB Memory Stick PRO Duo.)
Format the Memory Stick in the Camera and check if it works. (Formatting the Memory Stick will delete all the files saved in it).
This may happen if the files in the Memory Stick is damaged or corrupted.
Try turning the camera power off and on.
Remove and re-insert the Memory Stick several times.
Insert another Memory Stick in the Camera to check if the issue is with the particular Memory Stick.
Try resetting the Camera and check if it helps. To reset the Camera, press the RESET button located inside the jack cover using a sharp pointed object.
If the issue happens with different Memory Sticks after performing all the steps, service may be required.
Thanks for using FixYa.
Dec 05, 2010 | Sony Cyber-Shot DSC-P32 Digital Camera
Can't use the video function of my SONY CYBERSHOT DSC-T500
Please reduce memory stick size as 8 GB is too much for it and 2 GB would be fine in DSC-T500
Feb 10, 2009 | Sony Cybershot DSC-T200 Digital Camera
Duplicates
It sounds like you don't clear the stick after taking the pictures. Try re-formatting the stick through the camera menu.
Oct 23, 2008 | Sony Cyber-Shot DSC-P32 Digital Camera
Help Sony Cybershot Freezing with ACCESS Message on Screen
This can be the cause of your mem stick. Try formatting your mem stick or try restting your camera's setting. This restting might help to put everyting back to normal. And try to format the mem stick.
Feb 13, 2008 | Sony Cyber-Shot DSC-P100 Digital Camera
DSC-W35 file error
It sounds like the memory stick would be full why not format it and limit your number of pictures to its capacity.  Download pictures to your PC to have more space.
Oct 23, 2007 | Sony Cyber-shot DSC-W30 Digital Camera
Sony Cyber-Shot DSC-P32 Digital Camera Logo
50 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
 Russ Hill
Russ Hill
Are you a Sony Camera Expert? Answer questions, earn points and help others
