Question about Singer Quantum XL-5000 Computerized Sewing Machine
I have a Singer XL5000 machine, the normal looking bobbin is not spinning with the shaft and wont wind what have I done wrong?
Is your bobbin case holding in place right? See if you can jiggle it back and forth to see if it moves. If it does move, it may have unattached itself in it's inner-casing.
My bobbin case would just go back and forth in the casing. Make sure that your needle plate is inserted right, as it locks the bobbin case in. You may have to unscrew the needle plate, take out the bobbin case, place it back in - pushing it to your left as you glide the needle plate back into place. (go from front to back while inserting). It should catch your bobbin case and lock it into place. Hope this helps. If not I would suggest you take it in for repair. Good luck.
Posted on Jan 31, 2009
On closer observation I found I had the brother bobbin, got them mixed up, I have a brother machine as well! What a relief! All is well now!
Posted on Jan 15, 2009
My bobbin winder was working but now it wont start winding have a 1950s model no ah766517 singer
Will it start if you give it a push?
If the motor has brushes then when these wear they have intermittent contact with the spinning shaft of the motor. I would expect it's an easy and inexpensive job to replace them. If the motor works OK then a belt or something has come off.
Oct 21, 2017 | Singer Sewing Machines
Code 88 starts flashing as well as all the stitching lights on the panel when I try to thread the bobbin. I can sew, that is NOT the problem, threading the bobbin is. What is Code 88? I am not interested...
Turn your machine off and leave it off. Remove all bobbins - in the machine & from the pin. Remove all thread - from threaded machine and bobbin thread path. Clip the machine thread at the spool and pull the needle thread towards yourself. Clip bobbin thread at spool and close to bobbin, then pull towards you through thread guides. This keeps the tension where it belongs. Move the bobbin winding shaft from normal sewing back to winding bobbin a couple times. It should click in place when moved to the winding position. Check to see if there is any thread that has slipped under the bottom of the bobbin and wound itself around & under the bottom of the shaft. Carefully unwind to clear. If the shaft does not easily move back to the sewing position it is probably stuck in the winding position. Don't force it, but try to get it out of the winding position. Leave it to the left in the normal sewing position (unclicked). Check to see if there is any thread caught anywhere along the path from spool to the winding pin. Pay close attention to the first thread guide and the two discs the thread slips between that control tension. Hand wind the wheel on the right towards you to raise and lower the needle a couple of times. Stop with needle in highest position. Do NOT wind hand wheel backwards (away from you). Make sure the bobbin pin is not in the winding position. Now turn on your machine. Needle should jump to default position. Move the stitch length and stitch width guides to the far right, then far left, to attain the green lights. Press the reverse stitch button to raise lower and raise the needle. It will stop in the highest position. If you still have the error code - make sure the bobbin winding pin is NOT in the winding position. Remove the needle. Lower the presser foot and run the machine without any thread a bit. If the needle bar does not go up and down most likely the bobbin pin is stuck in the winding position. If the code has cleared use your manual to carefully wind a new bobbin. Make sure you are using a 15J bobbin which this machine requires. It will not work with just any bobbin. Next, raise the presser foot then carefully thread the machine. If you don't have a manual you can download one from the Singer website. You might consider cleaning the entire machine paying special attention to the hook area and feed dogs while the power is off. If you find a lot of lint do this more frequently to prevent buildup. Take special care when replacing the bobbin care. Hope this helps. If not call Singer. It may take some time but you should be able to reach someone to help you troubleshoot. If this is an older machine I recommend taking it for repair yourself instead of sending to Singer
Mar 28, 2015 | Sewing Machines
Winding bobbin problem Brother NX200
the machine should be checked to see if there is something wrong with the bobbin spindle..
May 16, 2013 | Brother Sewing Machines
Sewing machine Singer Advance 7422, I try to fill a bobbin on the top of my machine. I put the bobbin in position and the shaft will not turn. The machine is treaded correctly and put in the right...
some machine, you have to push the bobbin winder spindle to the
right so that it will wind the bobbin, I have to on mine.
but if you've already done that then the machine needs to be checked
to see what wrong with the bobbin winder spindle
Aug 21, 2012 | Singer 7422
The bobbin shaft will not spin
make sure the bobbin winder spindle has been pushed to the right
if you've done that, & it doens't wind the bobbin then the machine
will need to be checked
Singer 7444 trouble winding bobbin
It sounds like you don't have any tension on the thread when winding the bobbin. Make sure that you are running the thread through the tension disc on the top of the machine before going to the bobbin winder.
Feb 28, 2009 | Singer 3116 Simple
Singer 2010
If model 2010, the problem is a part metal- part plastic part attached to the bottom of the bobbin winding lever, the white tear-shaped thing with the arrow on it. If that will turn past the center of the bobbin it's broken inside. to try a do-it-yourself fix, turn upside down, remove 4 screws, including one by the plug (which must be pulled out for safety anyway) remove bottom case. looking at left end of the works, move the bobbin lever and you'll see the broken part move. The plastic part should be broken about half-way down. You can see how the part should push the white plastic bobbin winding shaft up and down when lever moved. the part can be removed by loosening the 2 tiny hexnuts holding it on the metal shaft. you'll need the smallest size allen (hex) wrench there is. NOTE where the part is at bottom of the metal shaft for when you put have to put it back on. be careful to hold the bobbin winding shaft itself in place, but it's easy to see how it goes back in if it pops out. if the break is clean (like my wife's that I just fixed this way yesterday!) you can put a drop or 2 of good crazy glue in the break, making sure lined up on the sides, then clamp in a vise (or hold firmly together with pliers) for at least 10 mins, longer better. wait at least an hour before putting back. putting back on is a little tricky but you move the bobbin lever to left (open) position, make sure it's just on the end of the shaft (shaft barely protruding) and see where the part isn't pushing the bobbin winding shaft. re-tighten with hex wrench then see if the repaired part now pushes the bobbin winding shaft up and down when you move the lever back and forth. Turn back over and move the lever without a bobbin spool- you should see shaft move up in the middle of bobbin case where it will engage the bottom of the bobbin spool where the x is.
Now if part can't be fixed it is available from auth Singer service center in you state but runs $40 or so. they'll try to tell you they have to install it because of special anti-static gloves that wont fry your motherboard on the machine's computer, but the center in Michigan finally said they would mail it to me. hope this helps! funny I just saw this after fixing our machine which hadn't been used for a long time until I decided I might as well look inside if I was going to have to buy her a new machine!!!
Aug 30, 2008 | Singer 132QRFB Mechanical Sewing Machine
Singer Quantum XL-5000 Computerized Sewing Machine Logo
346 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
