Question about Canon PIXMA MP830 All-In-One InkJet Printer
Canon pixma MP600 wont recognize ink tank. Seldom used
Printer is nearly new, ink tanks purchased with printer. initially whole thing worked fine
  • mreedijk Jan 14, 2009
    Thanks for the info, however i purchased Canon cartridges along with the printer and at first all was well.
  • 404 Answers
Hello!
I have the same printer and the only ink cartridges I use are Canons own.
I've tried these cheaper replacement ones and zip nothing will not recognise them.
It is false economy as now I have a full bank of copy ink cartridges that charity will not even accept.
Hope this helps!
Paul 'W'
Onyer~EDson(:0) {#>< U.K.
Posted on Jan 14, 2009
  • Paul W
    Paul W Jan 14, 2009
    Hi again, As you say standing for a while, Can you get into maintenance and perform a clean? if not then if you a careful remove the cartridges and clean the printed circuit area gently with some quality absorbent paper maybe you'll see results (Excuse pun)
    Paul 'W'
I get the U043 error on my Magenta. Cartridge is set properly.
Ink tank not installed.
[1660]
U043 (Applicable ink tank
icon)
The following ink tank
cannot be recognized.
Install the applicable ink tank(s) properly,
and confirm that the LED's of all the ink
tanks light red.
Sep 13, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Cannon mp600 Not recognizing one of the ink tanks even though it's half full.
hi you have a buggered ink,
these inks are chipped and i have had many come through the workshop like this, just ring canon on 131383 and complain they will replace it for free.
Canon Trech
Apr 13, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Ink Monitoring System
I have this Canon MP600 using unchipped cartridges. Once you have changed the chip over onto the catridge and inseted it should stop flashing which indicates the cartridge is located. The printer will not tell you the level of ink until you run out. When changing the chip over from original cartridge onto unchipped ensure it is not damaged and fitting properly other wise the error sign will show.The printer should print without any problems, i know you can not disable the ink monitoring system. Hope this is some help Mr T
Apr 09, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon mp500 printer
plz check you have placed the ink tank in the appropriate slot otherwise you have to try with new one
Aug 31, 2008 | Canon PIXMA MP600 all-In-One InkJet...
MP500 ink tank cannot be recognized error U043
I had the same problem. My mp630 is also only 4 months old. I replaced all colour ink cartrdiges(inc black), but was only able to release the function for detecting the ink levels for magenta and cyan. Yellow and black then started giving error message U043, with them alternating between working, but never working at the same time. Getting them all clicked in with the lights glowing red does not solve the problem, as once the printer cover is closed, the same error message turns up. The only thing that worked for me is moving the chip slightly out of alignment, by pushing the sliding chip holder, and I only had to do this twice before they all started working and the printer was unlocked.
Jul 30, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Help..
same problem   I brought a new ink tank and put it in and it went fine...I guess the first one was faulty...hundreds of pages later its going fine
Mar 13, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Same problem - two solutions I found helped me work out mine. One said contacts needed to be cleaned and it worked to use a Q-tip and alcohol or just click it in position several times until it recognizes the cartridge - this may work. Another said that they got it to work by installing a brand new cartridge - cool, but I have one full of ink it won't recognize. So I pulled the little circuit board off a used cartridge (like you need to do with some refills) and put it on the cartridge that it wouldn't recogrnize - works great. Still haven't figured out how to get it to acknowledge ink levels though. Canon really should be more consumer friendly since these problems seem to be intended to compel the use of proprietary cartridges.
Dec 27, 2007 | Canon PIXMA MP600 all-In-One InkJet...
PGI5BK Ink tank not recognized on MP600
You say the "original" is 3 months old? You are out of ink. Replace the cartridge. Even when there is still a little ink in the "tank" it reports back to the printer as empty. And yes it will go through all its checks and still show empty. They don't last forever even if you don't use the printer. The ink evaporates out over time.
Nov 21, 2007 | Canon Pixma MP800 All-In-One InkJet...
U150 error?
My dad is having this same problem and has been for the last 5 months. It's not from the printer being new it's a defect in the engineering of the printer cartridge older. The yellow cartridge (being the middle) doesn't snugly fit and so it wiggles around losing it's connection with the printer. I fixed this by taking making tape and taping around the base of the cartridge. It's a tight fit and it doesn't disconnect itself ever. Hope this helps!
Sep 23, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
195 people viewed this question
old marine
old marine
