Question about Dell Latitude D600 Notebook
Dell latituded600 charger lcd off,
Dell latitude d600 charger lcd switch off when connected to charge the battery,
  • 1 more comment
  • aderemiadewu Jan 16, 2009
    WHENEVER I PLUG MY CHARGER OF DELL LATITUDE D600 TO MAINS THE LCD INDICATOR OF RHE CHARGER WILL GO OFF AS IF THE SYSTEM DRAWS CURRENT FROM THE CHARGER.
  • abbcd Mar 07, 2009
    yeah i have the same problem as aderemiadewu as soon as i plug the power cord in the labtop the green led on the charger turns off
  • Biju Thomas May 11, 2010
    Charger LCD? can you elaborate further?
Problem In charger
Contact Dell service centre
call 9829081513.
Posted on Feb 26, 2012
  • 88 Answers
Ok... that makes a little more sense... Here is what i want you to check... Disconnect the AC Adapter from the system and plug it into the mains, check the LED light (Should be Green). Then plug in the connector to the laptop, check the LED. If the LED turns off when you connect the laptop. Your Laptop motherboard needs to be changed.
Posted on Jan 16, 2009
The battery of my Dell Latitude D600 is not charging fully. It only runs for 10 minutes when fully charged. Moreover, the battery indicator flashes 4 times red and one time green. Is it the battery problem...
That sounds like a bad battery. Be sure not to leave charger plugged into your computer while not plugged into power or the power switched off. That will really kill your weak battery and then you won't have 10 minutes. You can live okay with a battery like yours but if you ever need to replace ram or do a serious BIOS update the bad battery will not alallow it.
Sep 12, 2012 | Dell Latitude D600 Notebook
I am looking for a right hinge for a dell latituded600 do you know how i can find it.
It should be easy to find in either Ebay or Amazon. Just do a search for dell latitude d600 hinge. Should be pretty inexpensive too.
Aug 31, 2010 | Dell Latitude D600 Notebook
Charging problem
Charging port needs re-soldering.
Jul 30, 2010 | Dell Latitude D600 Notebook
Dell Latitude D600, installed new battery, but still won't charge.
Try to use another ac adapter or charger,.. If that doesn't work you'll need to replace the motherboard.
Usually this issue gets fixed by updating the BIOS of the computer but if the battery is less than 10% charge then you won't be able to flash the BIOS that will end up replacing the motherboard.
Feb 13, 2010 | Dell Latitude D600 Notebook
My dell d600 been shorted after using defective charger
try connecting a known good ac adapter if fails then remove battery then try it again if still fails then replace the motherboard.
Oct 14, 2009 | Dell Latitude D600 Notebook
Hi...thx for the solution for another monitor problem. my dell d 600 is not charging its battery . i have installed new battery but laptop is not charging it.
just connect the charger and remove the battery and turn it on. if ur laptop does not get on on charger only then there is a problem in board's power supply section
Sep 12, 2009 | Dell Latitude D600 Notebook
Dell latitude d600 blinking battery light
I would say its defective. Bring it back to where you bought it and show them. Bring your laptop charger also so you can show them it in action. Hope this helped.
Jan 04, 2009 | Dell Latitude D600 Notebook
Dell Latitude D 600 battery is not being charged
some problemwith ur motherboard circuit..so check up in service center...
Dec 01, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600 new battery won,t charge
the charger in the laptop is not functioning. pc will need repaired
Dec 28, 2007 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
210 people viewed this question
Alun Cox
