Question about VIA Gigabyte GA-K8VT890-9 K8T890 Socket 939 DDR 400 ATX Motherboard w/SATA RAID, LAN(Gb), USB 2.0&Au... (MGAK8VT8909)
Gigabyte k8t890 m/b cannot find sata wd7500aacs drive
I cannot get the Gigabyte k8t890 m/b cannot find sata wd7500aacs drive. Any thoughts about this?
  • 14 Answers
You must creacte a Floppy disk with SATA drivers so windows can recognize your SATA controller.
To creacte this disk you can boot whit your motherboard CD, or you can download dirver on gigabyte website and then copy it to a floppy.
If you are installing WinXP, you must press F6 when it asks if you have a third party scsi our raid controller.
Posted on Jan 14, 2009
A8VE-SE won't recognize SATA HDD
If you are trying to install Windows XP then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Jan 08, 2013 | VIA Asus A8v-e Se Socket 939 Pci-e K8t890...
I want to buy a hard disk for my PC. Model of mother board is GIGABYTE 8VM800M. How much size of HDD does it Support.
The specifications for this model Gigabyte moterboard is available from this WEB site.
http://www.gigabyte.com/products/product-page.aspx?pid=1931#ov
This motherboard supports IDE and SATA hard drives.
There is no size linitations on SATA hard drives and they are a lot faster than IDE hard drives.
I recommend to install a SATA hard drive with a capacity to suit your needs.
Jul 09, 2011 | Computers & Internet
What kind of hardesk can installed to it sata or ide
This motherboard can use a SATA or IDE hard drive since it has connector for both SATA and IDE, but I suggest you use SATA hard drive for faster data transfer.
You can check this link for the complete specs for this motherboard.
http://techwiki.hardwarecanucks.com/product/2NTEyNzM3NzU4MA/Gigabyte-GA-8I945P-G/#spec
Aug 08, 2010 | Gigabyte GA-8I945P-G Motherboard
Gigabyte k8m800-8237 wont boot with hard drive installed, hard drive beeps and computer shuts down. when I unplug the hard drive the computer boots with DVD drive. Hard drive is good, but used a 2nd one...
sound like you either have a dead SATA socket on the board, use another one, or at worst try a PATA hard drive, second thought is possibly go into the bios and make sure you have no previous hardware raid arrays left behind, sounds odd.. but i have seen it cause similar problems before.
Feb 12, 2010 | Gigabyte GA-K8VM800M Motherboard
I am using a single SATA II Drive in a new system, GIGABYTE GA-MA790X-UD4P, AMD 790X & SB750 chipsets. I know I can let the SATA II be a "Native IDE" but isn't that loosing any benefit of the SATA II...
The "Native IDE" mode causes the motherboard to "report" to the Operating System that the installed SATA drive is an IDE drive, rather than reporting "no IDE drives installed", and then requiring the Operating System to load a SATA device-driver to interface with the SATA drive.
Using RAID to "mirror" your hard-drive is a very-cool way to provide a "real-time" and "up-to-date" backup.
Should one of your drives suddenly "die", the other will continue to work, and you can buy another hard-drive, re-establish the "mirroring", and continue to work productively -- no fiddling with offline/stale backups.
Sep 18, 2009 | Gigabyte GA-MA790X-UD4P Motherboard
Pc cannot boot, cannot find SATA HD samsung160JJ
CHECK THE sata CABLE...IT MIGHT HAVE SOME PROBLEM....
Jan 28, 2009 | EliteGroup K8T890-A (V1.0A) (MBK8T890A)...
Re on MB GIGABYTE GA-MA74GM-S2H AMD740G R Motherboard
You have two SATA connectors but only need one SATA hard Drive. It has two because Gigabyte has a optional RAID setup. Some have 6, it depends on the nodel.
Alright, i looked it up online.
First, It has Dual Channel DDR which means you have to have two sticks of memory the same amount of memory on each stick, or just one. Whichever, you cant mix up different speeds or different size memory stix.
You need to have a SATA Hard Drive not IDE as this model appears to be SATA only. The IDE is meant for the CD Drive.
motherboard_productimage_ga-ma74gm-s2h_big.jpg http://www.giga-byte.com/Support/Motherboard/Driver_Model.aspx?ProductID=2775
Is that your Board? Or close? the link is to the website.
Did you get this new? how old is it? This board is meant for setting up a raid system so if its not what you intended, get a smaller or less expensive board. Take it back and say it didnt fit your case just didnt meet your specs that you thought.
Dec 02, 2008 | Computers & Internet
Ga-k8ns pro motherboard/ pc self build
Hey me too. Just bought a sata drive. I have the same mobo (AK86-L), and now the same problem. Updated the bios and SATA is enabled. Updated the driver. Tried both sata 1 and sata 2 connections on the mobo. It will not recognize the drive although it picks up that something is connected to the mobo. Its a WD Caviar 500 GB drive. Anyone have any thoughts?
Mar 30, 2008 | Computers & Internet
Open Questions:
Official Toshiba Support ' Toshiba Toshiba as a brand has continued living up to the expectations of its customer for nearly three decades now, by maintaining the high quality of its products with the help of delivering a combination of useful software and attractive hardware in a package, which is required for providing the needed technological expertise. With laptops becoming an indispensable and integral parts of our lives, it is important that companies today equip their laptops with all the advanced technologies along with a sleek and stylish design for that attractive feature that would add to its plus point. Our Toshiba technical support team members are available all the time on our Toshiba Support number +1 888 784-9316 and are highly adequate in resolving issues related to Toshiba printers. The fact that everyone today knows about Toshiba Support brand and most people who have tried Toshiba products like them, makes them one of the most reliable in case of printers especially. Toshiba makes business portable laptops, with highly durable features of being sturdy and long- lasting for use in all walks of life. Most laptop owners would agree to the fact that Toshiba products are designed to provide quality portable solutions and highly acclaimed for their bullet-proof build value. But with time, users might face issues with Toshiba Virus like any other laptop band and these issues can be prevented from causing any severe damage to the laptop by accessing resolution from our technically specialized team members, who are available on our +1 888 784-9316. Issues faced by Toshiba customers: Toshiba Backup BIOS update issues Slow Performance Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Windows 10 upgrade issues Computer Tune-up Issues Virus Removal Issues Data Backup, Transfer and retention issues All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact- +1 888 784-9316.
Apr 19, 2018 | Toshiba Computers & Internet
See all VIA Gigabyte GA-K8VT890-9 K8T890 Socket 939 DDR Questions
VIA Gigabyte GA-K8VT890-9 K8T890 Socket 939 DDR 400 ATX Motherboard w/SATA RAID, LAN(Gb), USB 2.0&Au... (MGAK8VT8909) Logo
439 people viewed this question
Top VIA Computers & Internet Experts
David
David
Tony
KG John Justin
KG John Justin
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
